That depends a lot on the headunit you get. A lot of double din head units these days actually only use a single slot. Either way, there is plenty of cutting. The lower air duct has to be reshaped. I used a hot knife and just kept trimming until everything fit nicely. Then i sealed the duct back up. Many who do this swap delete the center vent but it is typically the best ac vent in the truck since it’s the first one after the evaporator
Squaring axle and pinion angle
ghetdjc320 replied to rylee144's topic in MJ Tech: Modification and Repairs
You could point your pinion up maybe 1-2 degrees if you like. Won’t hurt anything and can give slightly better clearance. -
I swapped the location of both and installed a double din CarPlay unit. I think my write up is in the diy section
Step away from the drawing paper lol. I have never seen someone measure the angle of the tcase, it just isn’t that important. Your pinion should just be parallel with the ground. Unless your truck is nose high there is no reason to worry about your tcase angle. Are you running a tcase drop? If so, remove it and toss it -
1991 Eliminator Resto-Mod
ghetdjc320 replied to ghetdjc320's topic in Member Projects: Your Comanches
So... much... work... This is my daily driver so I’ve got to get it back together soon. Drivers side wiring has all been repaired and connectors for sensors replaced. Header installed and intake manifold cleaned up. Arb harness integrated and sub power also worked into the harness. -
Fox Shocks vs Old Man Emu
ghetdjc320 replied to shipp_m's topic in MJ Tech: Modification and Repairs
Fox has a huge lineup and wide variety of designs so it’s not easy to compare. Entry level mono tube Fox shocks would probably be the most comparable to ome. I’d vote fox since most can be custom tuned and rebuilt. I did run OME on my YJ and they were ok. Bilstein is another strong contender and what many here are running currently. -
Correct, the one from the op is a one piece molded unit
It’s an sbec2 ecu and can be socketed and chipped with an eprom. The stock eprom is encased in epoxy but can still be removed and replaced. It can be completely tuned just like any other aftermarket system once the ecu has been socketed. There are several that perform these services but Chris @christuned has lots of experience tuning the 4.0 based platform and is a great tuner. To create a new base map, a data logger is required like a zeitronics unit. AFR is needed for sure but the more sensory inputs the better. MAP, TPS, exhaust temp etc can all be used to fine tune the map. The stock ecu can also be programmed to handle boost. -
TJ ones fit just fine. Checkout the instructions for the JKS acos setups for the XJ and you’ll see how they all get assembled and removed.
Relooming and repairing all my wiring. Also replaced the sheet metal under the batter tray which was rusted out. I snagged a 97 xj pdc and will mount it side by side with the original pdc. Will run all my extra circuits through the new box. Also Por15’d all the sheet metal seams and pinch welds. Followed by a couple of brushed on coats of chasis paint. -
Stripped some parts from a 97 XJ today. Going to be relooking my wiring harness and cleaning UI the wiring a bit. Will integrate another relay box for accessories and get everything in tip top shape. Thought about pulling the header panel from that 97 since it was already off. May still do that but not sure. -
Negative. Your pinion needs to be parallel to the transfer case main shaft. Do not rotate your pinion up towards the tcase output or you will have a driveshaft that is out of phase. (Note that this only applies to driveshafts like yours where there is a single u joint at each end). Here is the info and explanation you need: https://4xshaft.com/blogs/general-tech-info-articles/driveshaft-angles and here is the pinion angle you’re looking for: -
I’ll echo the above comments. Not a worthwhile swap. Only non 4.0 I’d consider this oils be a diesel like an om617 or perhaps an LS swap. All swaps are pricey though.
Is this for a double cardan driveshaft and an sye tcase? If it’s for a traditional style driveshaft (1 u joint on each end), then you want the pinion parallel with the t case main shaft. If using a double cardan style driveshaft then the pinion shout point about 1-2* below the tcase output. This way acceleration and cargo loads are accounted for as @MiNi Beast mentioned -
Great minds think alike
Never was a fan of whataburger. But I’ll take a spicy chopped breakfast taco from Rudy’s every day. I felt like whataburger always covers over their burgers with so many extras but the fundamentals of a good pattie just aren’t there. Have plenty of friends who love it though
In-n-out is in Texas because all the Californians are moving there lol. I’m from Austin originally and the influx of Californians over the last few years was quite large. I didn’t mind in-n-out but it wasn’t anything special. I do appreciate anyplace that can deliver a consistent experience though. Heck even McDonalds is from Cali.
There is no going back from hydroboost
Need a folding tonneau cover
ghetdjc320 replied to ghetdjc320's topic in MJ Tech: Modification and Repairs
Awesome, thanks. I was able to get ahold of a rep there and they found the Comanche bed dimensions. He’s going to get back with me tomorrow to order. -
Starting the brake lines! Advice?
ghetdjc320 replied to 87ComancheMJ's topic in MJ Tech: Modification and Repairs
X2 90 and up D35s went to the 9” drums. -
Do you know what model you got for yours and what dealer you used? Trying to get this ordered up. -
For this setup I actually trimmed and molded a switch trim holder from the left of the column and molded it into the actual bezel overlay. I have a hot knife setup now with plastic shaping tools that works very well for these kind of things. The cutout for the cigarette lighter is slightly smaller than the ones for the switch panels but there is still plenty of room to fit them in nicely. Was also looking at the clock area as a candidate but had just swapped in a really nice 91 clock. I’m going to install a Zeitronics logger and program my ECU so I wanted to mount the logger display in the dash in one of the clock panel windows. Hopefully o can get that to come out nice and clean.
I believe 92 was the first year for the police package XJ. You could definitely swap in the speed sensor for a 91-92 mj and have an electric speedo. There’s also plenty of room for custom gauges in the cluster if you wanted.
Thanks! I kept the other bezel from the police package model also which is all black. At some point I’m going to do some custom gauge faces to match everything together. I was about to go with a new 12” Holley pro dash but this looks good for now. Trying to stay true to the “resto-mod” theme.
Are you referring to the switch cover bezels with the symbols? I’ve been reproducing them in the vendors section for some time now. Good call on those stupid self tapping screws. I’ll be removing that trim piece to fix some cracks in it at some point and will swap those out.
