MAP sensor tube
There is a brittle little tube. It comes out of a rubber plug, low on the engine side of the throttle body. It runs back to the firewall, then up to your MAP sensor, behind the valve cover, higher up on the firewall. It has one vacuum line as already mentioned, with a 3-wire plug in the bottom.
CRUCIAL!! The MAP sensor will tell the ECU to dump fuel with little to no vacuum to the MAP. Any crack or blockage and it will be pig-rich. ( black smoke, fouled black plugs, must hold your foot to the floor to keep the engine running). You can pull the line off the MAP sensor and feel for vacuum with your finger. If it runs!
A visual inspection usually reveals any issues with the line from the throttle body to the MAP sensor.
