Trapn6.0
    Gilmer TX
1122 profile views
Trapn6.0's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. All MJs had at least one overload leaf. There were, IIRC, two configurations for the metric tonne springs. One was 4+1, the other was 3+2. If I had your truck, I think I would start by removing the shorter overload leaf AND the AAL in the body of the pack, and see where that brought the ride height. That sounds like a good starting point Sent from my SM-G930V using Tapatalk
  2. Any of the 2 over loads on bottom factory? Edit might just remove the two overloads. Keep that extra one in the pack. Sent from my SM-G930V using Tapatalk
  3. Whatever the one or ones that don't belong I might remove. Good eyes thank you. And yes Napier flares, just working out a front end height for the lift. Sent from my SM-G930V using Tapatalk
  4. Here's a pic. Thought it didn't look like factory Mt leaves. Sent from my SM-G930V using Tapatalk
  5. So those aren't stock Mt leaves? Sent from my SM-G930V using Tapatalk
  6. Rear axle is an 8.8. Metric ton leaves I believe. Sent from my SM-G930V using Tapatalk
  7. Gain? Just curiosity of ride heights. I searched a bit but couldn't find quite what I was looking for. Mine just seems tall for a spring over. Sent from my SM-G930V using Tapatalk
  8. Looking to see if anyone who has cutout flares with 33s or 35s could measure ground to bottom of flare. Yes I know some cutouts may be different but looking for round about. Pic for comparison. Sent from my SM-G930V using Tapatalk
  9. Any other color options Sent from my SM-G930V using Tapatalk
  10. Awesome thanks guys. Sent from my SM-G930V using Tapatalk
  11. Looking at picking up a 91. Seller said won't shift into park. Stops at reverse. Any ideas from yall what it might be. Pics show it being a column shift to. Thanks Sent from my SM-G930V using Tapatalk
  12. No buckets. All bench Sent from my SM-G930V using Tapatalk
  13. Thanks guys. FYI junkyard is in longview tx Sent from my SM-G930V using Tapatalk
  14. Sent from my SM-G930V using Tapatalk
  15. Picked up a 10 slot grill and behind the seat cab backing. Pretty stoked just wanted to share. And FYI they had 3 mjs. Not much left but all 3 had functioning parking brakes. And oddly enough only driver side tailight Harnesses. If anyone would like something let me know. I'll ask prices. Sent from my SM-G930V using Tapatalk
