O2 sensor is not gonna cause it to turn off.
After the CPS and it's plug, there is a bunch of harness that an have enough resistance to drop the output voltage from the CPS to the ECU.
Altitude compensation is done by the MAP.
The injectors are not running near their capacity as they are and there's plenty of "headroom" should more fuel be requested.
Haha. Glad to hear this. You'll see me driving around in my white longbed...Most likely with a black Doberman in the passenger seat.
Found an 88 white longbed 2WD here in town with 130K or so on it. Dana 44 rearend, bench seat and column shift. Big ton?? package..16 or 17 inch wheels.
Needs a rear main seal for sure.
Test your CPS. Post 7 in my Tips.
Keep in mind that te signal for almost all of your critical sensors goes through the C101 connector...Post 2.
I would do posts 1 through 5 as a preventative step anyway.
94 to 98 ZJ. Be sure to get the studs that hole the caliper bracket to the housing. They're longer. And also be aware that you need longer rear axle wheel studs.
Another thin is to use a 3/4 " wrench/socket and grab the "guts" out of the donor vehicle's proportioning valve to transplant into yours.
There was an issue from the factory when they used Girling cylinders.
There was also an issue with the HOSE between the master and slave. The fluid they used reacted with the lining of the hose to form an abrasive crystalline substance which would keep taking out cylinders... Unless of course you did as they finally recommended and always replace the original hose.
5 quarts Rotella T3, 1 quart Marvel Mystery Oil, Wix filter. Drive it. Monitor the progress by shining a light into the oil filler hole. Safe, easy, effective.
Look up at the top of the brake pedal. There are 2 switches. The metal one is for brake lights. The white plastic one is for unlocking the torque converter and dumping the vacuum to the cruise control servo.
I just did my truck this weekend and there are definitely a few that change colors so do as Cruiser says and go pin to pin. I also had 4 wires that didn't go anywhere on the other side of the connector so don't let that confuse you. And just to let everyone know I didnt have any problems with my truck before eliminating the c101 but it does feel like it runs more smoothly now.
Typical.
