MuddFoot
Everything posted by MuddFoot
I've ordered a few off Amazon never had a issue. Last one I got didn't even come in a box just a plastic top and bottom. I'd order again maybe get another 2 freebies jk but it was definitely a shipping issue. Sent from my Z981 using Tapatalk
AW4 shift cable... column shift
MuddFoot replied to ComancheKid45's topic in MJ Tech: Modification and Repairs
Sorry it got scraped with all the other parts Sent from my Z981 using Tapatalk -
I just got power 6 days without power. First goodnight sleep I've had Sent from my Z981 using Tapatalk
BTW I have like 12k worth of damage eye went right over my area I could hear the shingles ripping off the roof. So much for a easy cleanup Sent from my Z981 using Tapatalk
I install them can't afford one yet if I sell 100 in a year I get one free for myself. I a gen running right now but it's a baby I have my fan tv PS4 fridge and some other small stuff. 5 years ago made 80 to 120 year now I make 50k and divorced. For my home I only need like 12kw I have all gas appliances Sent from my Z981 using Tapatalk
I install generac. A 10kw would almost power your house but it's the starting of appliances a 2.5 ton 14 seer ac pulls about 35 amps starting. If you run your heat avg 10 kw heat strip is drawing 40+ amps so now 10kw not enough add in everything else. Just FYI 16kw and 22 kw are only about 200 bucks different in price because the 22 kw comes with the transfer switch. I install them for 7200. Owner is responsible for ng or lpg hook up from a gas company. Best way is to do a load test so you get proper size I recommend 25%bigger your Neighbors will wanna run a cord to there stuff or if you grow your home Sent from my Z981 using Tapatalk
Ad says it's 4wd where's the shifter and I thought all the streets were 2wd Sent from my Z981 using Tapatalk
I'm here in Haines City Fl in Polk county and when it hits it will drop down. Clearwater area should be ok as long as she's not right on the coast. People are worried about food water ect and our local chain Publix has 95%of stores and warehouses with generators. So we are more prepared than Texas was. I'm going to drink till it fly's over I'm using vacation time so I can enjoy my self. Then the cleanup will be a b*@$£... Sent from my Z981 using Tapatalk
Rock Auto has them also Sent from my Z981 using Tapatalk
I might have one I just did a 95 swap on an 87. I can't look till next week if this hurricane doesn't take me out Sent from my Z981 using Tapatalk -
Still no Tapatalk is it gonna be fixed anytime soon
If it sat for a while you might need to change the fuel pump it's a issue I have if I leave a car sitting a year in Florida humidity I guess gets water in the tank Sent from my Z981 using Tapatalk
I don't think you have to have a sye. 3.5 inches is not much on an MJ. Sent from my Z981 using Tapatalk
Catalytic Converter RED HOT!
MuddFoot replied to parkia86's topic in MJ Tech: Modification and Repairs
If it's getting red I'd say it starting to get clogged. I had one get red hot then not run the next day till I cut a slit in front of it. Sent from my Z981 using Tapatalk -
Starter dragging I'd replace the starter Sent from my Z981 using Tapatalk
I used a multi bit. If you used the apn header you need shims on your intake I used washers cut in half worked like a champ Sent from my Z981 using Tapatalk
Look at this on eBay http://www.ebay.com/itm/401162578411 Sent from my Z981 using Tapatalk
Check the fuse see if it's melted on the fuse panel. I had one that had a bad connection at the fuse panel and would start and stop when the Jeep bounced around Sent from my Z981 using Tapatalk
Ba10 slave cylinder grommet
MuddFoot replied to willi2ds's topic in MJ Tech: Modification and Repairs
Goto harbor freight and buy the grommet set I've used it alot like 5 bucks Sent from my Z981 using Tapatalk -
I swapped to a 95 only issue I had was the fuel tank. Everything else kinda bolted in. I ended up using a 22 gal 96 Dakota tank and sender. Switched to a newer returnless fuel rail. Sent from my Z981 using Tapatalk
Cutting lower control brackets
MuddFoot replied to 88whitemanche's topic in MJ Tech: Modification and Repairs
Most guys I know cut them off with sawzall and cutoff wheels Sent from my Z981 using Tapatalk -
I used a multi bit for the hole. I also had the motor and transmission out Sent from my Z981 using Tapatalk
Yes and yes Sent from my Z981 using Tapatalk
I just swapped my MJ to a 95 xj parts and the holes lined up for the most part. They are not all perfect the factory put them in I just made it straight and used self tapers.the 4wd shifter is kinda a pain you have to overlap the floor shifter plate a little Sent from my Z981 using Tapatalk
Dana 30 quick bearing question
MuddFoot replied to Jacob Ochs's topic in MJ Tech: Modification and Repairs
It's kinda a seal but not really it's just a piece of plastic on the axle shafts. But you can buy outer axle seals Sent from my Z981 using Tapatalk
