MuddFoot
Everything posted by MuddFoot
  1. Just put cooper at3s on my dad's f150 had them on my ex-wife's liberty got about 50k on them before the divorce now I really don't care. Sent from my Z982 using Tapatalk
  2. Wish I knew that a year ago. I made some for my Dakota seats pima Sent from my Z982 using Tapatalk
  3. Sounds like it's not clipping in all the way. I just redid mine on my 95 obd 1 mj and don't remember any quick disconnect on it. Maybe their is. I don't remember I'll. Look tomorrow. Sent from my Z982 using Tapatalk
  4. Try tightening it looks open to me. Because when you swap to 134a it switches that valve out that wouldn't have a Schrader on. So free on wouldn't come out until you open the valve so if you press on the Schrader valve and Freon comes out or air valve is open. Sent from my Z982 using Tapatalk
  5. Sorry running a 98 Dakota tank and fuel pump.should have posted that also Sent from my Z982 using Tapatalk
  6. The xj tank is wider. I used a Dakota tank on my 87mj- with 95 xj swap. My fuel gauge worked with the first fuel pump and sender. Bought a new pump and sender and it doesn't work now. I now have purchased a aftermarket gauge that works just have to install fully. Sent from my Z982 using Tapatalk
  7. Did you change the pressure plate. Did you torque the bolts on the pressure plate or did you just tighten them until good. I had an issue similar to this on my first mj it was the bolts on the bellhousing coming loose. Have a friend push the pedal in as you watch. Sent from my Z982 using Tapatalk
  8. Mine just said dark green. Sent from my Z981 using Tapatalk
  9. I sprayed mine it was super easy Sent from my Z981 using Tapatalk
  10. Yep love mine too can get any color you want now too Sent from my Z981 using Tapatalk
  11. I used a angle grinder with a wire cup brush. I had 3 layers of paint from previous owner. The kit comes with 3 gallons material after mixing comes with a spray gun and all I did was prep the truck make sure your primer is dry. Not dry to the touch fully cured cuz it will Bake It Off when the bed liner cures. Sent from my Z981 using Tapatalk
  12. I did mine with liner Xtreme. Sent from my Z981 using Tapatalk
  13. Looks like it's the alt. I'd also check the harmonic balancer. Sent from my Z981 using Tapatalk
  14. I'll look at my parts jeep next week sometime I have 4 doors to look at lol Sent from my Z981 using Tapatalk
  15. Rockauto.com or Napa but I'd go ahead and change the injectors. Order off Amazon or eBay you can get a set for about 60 bucks and comes with o rings Sent from my Z981 using Tapatalk
  16. Use quarters lol. Or glue them in with black rvt silicone and do not open them. Sent from my Z981 using Tapatalk
  17. On mine I also just used the 95 Cherokee donor lines to the filter and then used everything else off the mj. But I'm using a Dakota tank and modified the rest to work with it. Sent from my Z981 using Tapatalk
  18. I 100% agree but it did come from camping world Sent from my Z981 using Tapatalk
  19. Look when people go camping in the woods if they like tents good for them I don't mind them but I'd rather be in my dad's 38ft fifth wheel with ac heat tv stove hot water and a nice bed. I work hard and I don't mind a day or 2 in the woods any more than that I'd want at least a pop-up. Sent from my Z981 using Tapatalk
  20. Where are you located in Florida Jim Sent from my Z981 using Tapatalk
  21. Make sure it says 12 volt vdc or dc I just looked at a small tv I had here it's 12 volts ac. So it would definitely fry. It says it's .8 of an amp at 120 volts so 96 watts so buy a cheap inverter. Use ohm's law. Sent from my Z981 using Tapatalk
  22. Only reason he did because it had new drums and shoes Sent from my Z981 using Tapatalk
  23. I sold a Dana 35 in good shape with new drums for 50 bucks Sent from my Z981 using Tapatalk
  24. I do HVAC and electrical. If your in the southern States you can make ok money but being on call is what sucks. Crawling into an attic at 2am to change a fan motor or cap is not high on my list. Ive been doing HVAC for 3 years now and make about 45k year but I'm honest if I was like others I could make 80+ a year but then your a salesman and not repairing anything. I worked at Publix for a few years wasn't for me so I delivered pizza and eventually bought my own Domino's Pizza with a partnership and was doing great. But had to start over because of that business partner. Lost just about everything I worked for. There's good decisions and bad just do what makes you happy and money isn't everything I made 80-120 year when I had my Domino's but I'm happier now with the company I am with and have time for friends family and most importantly my jeeps. Sent from my Z981 using Tapatalk
  25. Do you have an advance Auto near you order online pickup in store. Code is SCW377 30%off make 2 orders for 2 batteries Sent from my Z981 using Tapatalk
