6
Everything posted by 13 Legion
Pics... or it didn’t happen....
1989 Jeep Comanche Pioneer
13 Legion replied to PSiTSi's topic in Craigslist/eBay... i.e. Not Your Stuff
Originally a southern truck from... West Virginia? I guess when we live in the rust belt the majority of the country is classified as a Southern state. -
You did an awesome job! That’s the first I’ve ever seen of those lights. Was the wiring difficult? The pieces you fab’d....do they fit tightly to the door? Did you have to put some type of sealant or gasket around it on the outside for water protection? Again nice work, they sure are bright!!
Setting a bridge over the Fox River in Illinois. Having been an Ironworker for over 20 years this has got to be one of the more scenic and serene job sites I’ve ever been on.
Front Driver's Side Blinker Not Working
13 Legion replied to Cox's topic in MJ Tech: Modification and Repairs
Had the same type issue. Turn signal would not illuminate when running lights were on. Would only illuminate when used as turn signal. I had a bad socket. The ground wire wasn’t making good contact inside the bulb socket. Swapped in new socket and soldered wires. Good to go. -
Starter relay blown fusible link
13 Legion replied to Cheapamanche's topic in MJ Tech: Modification and Repairs
I’ve cleaned the connection. I mean it’s not the most cleanest setup creating electrical power loss I’m sure over 32 years but my truck starts and runs fine. Eliminating is an option. One step at a time. Don’t. There’s good basic info in there. Yes it’s not a Chiltons. A leak onto the fuse block was/is a common problem. It sounds like you’re doing a good job trying to locate electrical problems. I’m sure if you PMd Cruiser he’d point you in the right direction. He’s helped many members in the past. He patiently literally walked me through(held my hand!) in how to properly diagnose a headlight problem. -
Rocker Arm pivot bracket
13 Legion replied to 13 Legion's topic in MJ Tech: Modification and Repairs
Thanks Jeff. I PMd a fellow member and got the same reply. Appreciate your insight. Thank-you! -
While swapping lifters on my 2.5 I kept all components removed together. I didn’t realize the brackets as well as rockers have grooves in them for what would appear to be oil flow between the two. Are these grooves positional? Meaning should I match the grooves when putting back together. Common sense says yes but well sometimes common sense isn’t so common so I’m second guessing myself. Like I said I kept the whole cylinder ‘kit’ together and orientated,minus the bracket. The grooves have a wide side and a narrow side.
What is your budget? How far of a trip is it?
Well the bench is out......
13 Legion replied to 13 Legion's topic in Member Projects: Your Comanches
Little update. Trying to diagnose a lifter tick. Removed valve cover, took out rocker arms, and pulled lifters out. One lifter looked pretty sketchy. Looks to be clogged. Swapping them all out though. Gonna soak the rockers, bridge and pushrods in some parts cleaner overnight. Already have new lifters soaking in oil. -
My truck was hit from behind
13 Legion replied to Virginia's topic in MJ Tech: Modification and Repairs
Agree with all the above. Don’t total it out, unless like JeepDriver said, they give you a crazy amount of money, or it meets a price you feel your truck is worth. The damage you have is all repairable. -
You can see how I interpreted your response by you replying. If it was a genuine question my apology. I just read it as ‘oh you went to college, and you’re still flipping burgers...’ So if not , again my sincere apology. Just seeing you put ‘education’ in quotes, I believe it to be the latter. The sarcastic way I read it.
Where did this take you? what did you do with it? Was this an honest questions? Or an attack on someone? I hope the first.
I’m in on the Illinois or Indiana stops if I’m not working!
They make XJ floorpans, they can work on your MJ but require some mods since the floor is different. How bad is it? You can grab some sheet metal at your local hardware store to cut up and patch in.
https://eugene.craigslist.org/cto/d/springfield-1987-jeep-comanche/6928477912.html https://eugene.craigslist.org/pts/d/springfield-1988-jeep-comanche/6911994930.html
Where in Cali are you located? What specifically are you looking for? 4.0,2.5, 4x4, year, daily driver, rock crawler, weekend driver? There’s many for sale. You may have to travel to find what your looking for! What’s your budget?
A little more info...2.5, 4.0? Last time it’s had a tuneup?
Congrats. I figured the underneath would be clean if it had spent its life out west... clean??? That looks immaculate. Sweet buy.
Another Street Comanche for sale... CA
13 Legion replied to Gjeep's topic in Craigslist/eBay... i.e. Not Your Stuff
That’s great news!! Saved another one! -
Is this post worthy of a sticky? Thinking it would be ideal for guys looking for non- Comanche items. Just so the wanted section could remain strictly MJ/XJ. The post may get a little cluttered though. Maybe another wanted/ looking for post in the classifieds?
I think so. If you’re close enough go take a look. You know it’s not running so check the body rockers, underneath, the floorboards. Worst case scenario you have at least 800 in parts. Has a rebuilt trans with engine at 156,000. It should be pretty clean body wise I’d imagine if it spent its life in Cali.
Showing your age! Well played!
