Egm89
2
Everything posted by Egm89
I was thinking sticking with the same one. I mean a saw a post on Fb of a guy running something very similar to it. He said everything was stock that you just need to "tap" into the sensor. Makes me wonder tbh
Hey fellas! So its about time to guve my interior some love so I'm planning on a 97+ dash swap, and then I came up with this idea for a new cluster setup. https://www.jegs.com/i/JEGS/555/41290/10002/-1 With this to as well https://www.autometer.com/jeep-tj-direct-fit-gauge-panel.html?utm_source=google_shopping&gclid=Cj0KCQiAno_uBRC1ARIsAB496IX0EsV4JSA5wCuEHb0OfepNnHWuwW5S-c7uIoAfzY-i68mvxa6mZeEaAvkDEALw_wcB&gclsrc=aw.ds Si what do you guys think? Doable? Crazy idea? Keep the oem ones? Btw 1987 swb 4.0 4x4 All stock renix things
Sounds good to me. Ill send you a pm!
How much would you part with one of them?
I will look into that thanks pete! Yeah my ultimate dd would be 94+ ax15 external slave Tc from a 97 Dif from a 97 as well 3" lift well done (done already) 8.8 at the back lsd with 4.11 gears 30" or 31" tires I'm almost done just need the 4wd swap and I'm set๐
Yeah pretty sure I'm going to need to drill one, bcs I'm aiming for a 94+ ax15 with the external slave. But over around my area finding stick xjs its a bit tricky to say the least Yes I'm looking for a 94+ ax15 with an external slave, will look for a tc on the same year range aswell. But xjs with manual trans are kind of hard to find around here. And I found one online trans with a matching tc case but wanted 700 bucks for it and I though that was abit steep
Hey fellas! So I've been doing my research to do my 4wd swap. I mostly know what I'm going to need to do it which is: Ax15 4x4 manual tran Transfer cafe Transmission crossmember from the ax15 Both shafts (rear and front) D30 dif which I'm probably going to need to change the gears ratio to 4.11 (I have an 8.8 4.11 gears on the back) But here's whsts been bottering me, its the transfer case transmission specific? Like manual on manual, or automatic on automatic? If any of you with more experience would like to chime on this it would be great! Thanks! Btw picture of my baby
Not hijacking this treat or anything, but at topic at hand its actually not that hard if you take your time to do the research and not just here at CC, but also at Naxja etc etc. And I'm saying this because I think I'm on the same boat as you are my friend, mine its also a 4.0 2wd trying to convert it to a 4wd very close to Pete's specs actually. And not an accomplished mechanic or anything but this truck are so straight forward (not counting electronics; those are a PITA) that after all month of research I decided to pull the trigger on parts. Ax15 94+ come with the external slave (you want that trust me) And the transmission thing that volts into it (forgot the name) you need that aswell. Come on man! Lets do it
Upgraded Battery Cables!
Egm89 replied to MeanLemons's topic in Vendors- members making products for MJs
Is it to late for this?๐ฌ -
Lund visor repops
Egm89 replied to frankspeed420's topic in Vendors- members making products for MJs
Ill contact you during the week. -
Pm sent and paypal as well Thanks pete!
Bored throttle bodies
Whenever you ready to sell lmk, very interested on the renix one๐ -
Yeah lol, I called him today and send him the pics, he quoted me 30 bucks lol Sorry man but my truck its still over there, as soon as I cross it ill call you. And probably tom ill send u a video hows that sound. You got your paint?
I did some research on that, i think imma go with the welding route thanks! Yeah thats the route I'm taking thanks for the info man!
And it seems that it was caused by that foam like on the inside of the firewall. Well I think now I have to clean it till i c healthy metal and cut it right?
Yeah turns out it was much worse than expected, now I have a half a fist size hole at the back of my brake pedal.
Welcome to the club! Kind of miss my ol' 2.5 tbh And that engine bay looks clean!
- 657 replies
- 2.5litre hurricane
- pioneer
(and 2 more)
Tagged with:
Hello fellows! Well as the tittle implies, I'm a rookie when it comes to rust, well as I pulled my carpet I found what I think its surface rust. What I'm doing right now its put a wire cup brush on my drill and start "cleaning it" till I see bare metal (or what I think its bare metal) and then clean it with alcohol Ill take better pics tom. So should keep doing the whole thing the same way? Or just where I c the bubbles?
180
Ohh the dmv, I'm not going back there without an appointment. Wait time are plain terrible
Hahaha as soon as I'm able to swap the e brake lol Hey! Next weekend sounds good to me, truck its still on my gf house so Ill have to go pick her up and well meet up Shipping might not be that expensive lol humm
X4 on the @krustyballer16 hitch I bought one couple of weeks ago and the quality its amazing man
Beutifull truck Welcome!
No sir, the truck was painted in Tijuana Mexico, but the paint and clear a friend of mine gave them to me, and he work at the Toyota plant in Tecate Mexico. Yeah a bit confusin haha Thanks man!
