Everything posted by vaquaro
2.5 plastic valve covers commonly have this malady ( overtightening the bolts and heat warp usually the cause ) The plastic VC's are availible from dozens of sources and cheap or switch to 91+ aluminum type but you will have to re-plumb the PCV/CCV and vent hoses . If you stick with plastic use the Felpro dry gasket and change factory shoulder bolts to 1/4 -20 5/8" flange bolts " , Lock-tite and torque to factory spec.s :thumbsup:
:agree: This is an amateur site , if the self-proclaimed " Pros" are frustrated by us trying to understand some concepts , then just opt out of the topic . The name calling is just plain childish :no:
diesel comanche - medicinehat alberta
vaquaro replied to shawn's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
Don't you already have a 91 Eliminator ? you really should get the diesel to round out your collection . I find I get a much better sleep on the couch anyway ( no elbow in the ribs everytime I snore a bit ) :D -
:wavey: Welcome to the club . Red MJ's are my favorite , looks like you found a good one :thumbsup:
94 tags on the plates , you wouldn't have to have DMV inspection to re-regerster it in B.C........"Road Trip" on your horizon ? Great X-mas gift for the wife :thumbsup: -
:thumbsup: Excellent upgrade , if I lived closer I would be trying to buy your old buckets .
smokey cab, where can it be coming from?
vaquaro replied to lostissues's topic in MJ Tech: Modification and Repairs
:idea: The ashtray :hmm: -
'bout the same as most convertible top fabric , flexible but not flimsey :thumbsup:
That's why people your age shouldn't be driving, especially at night. :yes: :rotfl2: :yes: :rotfl2: :yes: :rotfl2: :oops:
:fool: same answers as you got on JF :yes:
MJ studdenly won't start...please help.
vaquaro replied to Disturbed's topic in MJ Tech: Modification and Repairs
CPS -crank sensor , easy fix :thumbsup: -
Just a bunch of street kids from Surrey B.C. practising what they do best , :huh???: ( Surrey , the auto theft capital of :Canadaflag: ) Very cool video :cheers:
New Member. Green to Comanches
vaquaro replied to Rampage's topic in Member Projects: Your Comanches
Try " Edmonds Starter " between Kingsway & Canada Way on Edmonds , they are a local rebuilder in Burnaby . I bought a 100 amp alternator from them for $ 95 installed :thumbsup: -
Welcome aboard :wavey: Good group here to help thru the mysteries of Comanches , as you will find out for yourself . Locally :Canadaflag: you'll find Gary's auto wrecking ( maple Ridge ) and Gemini Jeeps ( Burnaby,Langley ) great places to source parts :thumbsup: -
Great looking example of a MJ ,super clean :thumbsup:
Followed wiper motor DIY, but.....?
vaquaro replied to MJRemi's topic in MJ Tech: Modification and Repairs
It's a long shot considering you live in sunny California but if the wiper assembly is cracked (or rusted ) usually where the motor bracket joins the top horizontal bar it could stress the the assembly causing it to bind . I replaced my wiper motor not long ago and noticed this defect (put on my get around to it later list :doh: ) 2 weeks later the motor quit -burned out the bearings :wall: So I ended up buying a complete assembly (with new motor ) brand new . Problem solved , lesson learned . I had also previously replaced the wiper switch / staulk assembly on the steering column (now there's a nasty job ) Have another look at your wiper drive system before going that route .Good luck :wavey: -
nice looking.. but wow almost 6 bills... I am going to have to get my brother to make a few of his pop up toneau covers that he makes over the winter.. It is a toneau cover with a zipper front nad rear. unzip and fold up the bars, then pull the top up so it becomes a toper... realy nice unit.... Sounds very interesting :idea: , tell us more with pics if possible , BTW landed cost was close as dammit to 9 bills . :cheers:
:eek: Define " bit " ? :???:
:fool: It's a time management thing . A quick way to see whats going on , if you can be of help to someone or find something of interest . Other forms don't have it and it makes it tedious to inter-act , comprede ? :shake:
No holes required , rails clamp on ( same as a hard topper ) . Rear window has zippers on each side , velcro along bottom and corner flaps , also a bar/tube below window that clicks into a bracket at the end of each bed rail . The window can be rolled up and secured or removed completely (front or rear ) Check out the website www.softopper.com . Your comment about not wanting a permanent fixture is the reason I bought this unit , it folds down inside the bed or is easily removed in a couple minutes . :thumbsup:
Opinions always welcome Don . re: cab vents , they're LED turn signals , great for announcing lane chages :thumbsup: Re Topper , Red wasn't an availible option (blk. ,gry. ,tan ) , the gaps are adjustable as is the front angle and roof hieght ( longer-lower , higher-shorter ) Granted there's more tweeking to do as the fit certainly isn't perfect but I'm pleasantly surprized by the quality of materials and workmanship of this product . :clapping:
:D Well guys , here it is , so far I'm lovin' it but getting used to it is a bit of a chore , loosing your side rear vision backing up with only mirrors is a little freeky for now at least :shake: . I'm thinking about painting the cab roof semi-gloss black to pull the look together ( opinions welcome :thumbsup: ) :Canadaflag: for cunucks : Softopper + Cover + Shipping +HST (B.C. & Ont. ) + Exchange =$889.17
