Oizarod115
Everything posted by Oizarod115
  1. its not much worse than living in metropolitan $#!&hole and paying 3.59 when you're also stuck in traffic all the time
  2. I'll get right on that #II :chillin: I have heard if you put some pantie hose on the vent outlet (say you vent goes into a garage or room) it catches every bit of lint.... hey hey hey, this is a family oriented forum, noone said anything about hoes in the garage! :popcorn:
  3. we've had many lines blow running a similar setup but with about 2 feet of copper hard pipe before the hose...blew the hose after a while, then repaired and blew out like 5 minutes later. i suggest running higher temp lines, whether they be braided or pipe until you get out from under the hood to let things cool down some. cool setup though, i like the quick disconnects there.
  4. hahaha, :cheers: wife and kids in tow, BANG. i wouldn't mess around with family involved. just myself i'd warn, then shoot the knee.
  5. if you were truly drunk rednecks you would've used it as the base of the nights bonfire... sorry, you lose. ;) better luck next time, it does make sense though cause you couldn't really scrap it then. :roll:
  6. whats the big deal? :dunno: sounds like fun to me...
  7. 125k on a 4.0L is low mileage man... ever seen one with that many miles that was hurt? i agree with the other guy, i laugh when i see cars with 100,000 HIGH MILEAGE... high mileage is 200+ 125k is like break-in period or something on a 4.0L isn't it?
  8. both my indicators came on exactly like you described, blinkers worked but no parking lights, and dimly lit indicators all the time. fixed the problem with new sockets from the HELP! section at the auto parts store. :cheers: wish i had seen this thread earlier, but at least all your bulbs are new now :brows:
  9. pulling the rear shaft would=fluid on the ground. so i wouldn't do that. i'm pretty sure you can run it with thte case in N but i'd try and get a trailer
  10. i might snatch up that class 3 thanks for the heads up man!
  11. on my 89 there s a relay on the inside of the passenger fender. the orange wire going into the relay is the ON wire wire a 12v through a switch to that wire and viola! the e-fan should come on.
  12. only problem with that is they get dirty offroad
  13. this is easy, did it to my brother's old cherokee so the new tank wouldn't get beat on the rocks. just figure out a way (other than bungie cords) to hold it down, and the filler neck will just stick out, oryou could figure out a way to make a cool one. some wires and fuel line and you're good to go we used long gr.8 bolts through the floor with large fender washers on them and bolts the stock straps to the floor in the cherokee.
  14. Oizarod115
    piggy.
    i guess not? he said you can always tell real easily which pig it is cause he's the real PISSED off one. :brows: :D just kiddin, i don't know the guy
  15. Oizarod115
    piggy.
    his uncle? had a pig born with no poophole. and its still alive, close to 2 months now right?
  16. For the record.......that don't work. Tried that last week when my pump died, and only got a faceful of mud/rust for my troubles :oops: :D Jeff (although it did releive some of the stress of admitting to myself that the pump actually was dead) it works about 50/50 we get alot of dead pumps, some of them you can kick and drive in the shop, some of them you've gotta push :redX: it's alot more fun to drive the car that just got a 80 dollar wrecker bill in ;) than it is to push em
  17. Oizarod115
    Drive By
    i had a guy offer me 500 at a gas pump once... i gave him the cheezits ad... helll no! GET YOUR OWN!
  18. pull through buddy! you can't bail now that build will be historic! hope all goes well man. maybe they'll give you the good $#IT they've been hiding in the back room :chillin: ;)
  19. the one thing they did do that would be worthwhile is upgrading wheel bearings. the stock d30 ones won't last long on 35 inch tires with any wheeling in th emix
  20. this is why you organize your toolbox and keep stuff put up, you can't make money if you can't find your tools. :cheers: hard to beat time on things when you're diggin around, staying neat and organized is the only way to do it.
  21. there is some trick with a piece of rope where you slip the rope between the frame and the gasket and tug around it and slip it out. reverse procedure to install... i'm not sure though, never seen it done, just had it explained to me. magic? idk... try youtube or DIY websites?
  22. BUY IT
  23. i say it REEE NICKS you know like them gee-tars and mud terr-rains :roll: we're from the south ;)
  24. that picture made me get up off my lazy butt and clean out my truck/rearrange the 6x9s and sub box thanks. your interior looks CLEAN man.
  25. my truck was acting up between shifts and it turned out some dumbarse... (coughMEcough) had put the TPS in improperly. check the TPS to make sure its working, it would only do it between shifts and it felt like backfiring.
