voltageyz0
    carpentersville, il
  • Interests
    bikes, jeeps, fords
voltageyz0's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. my sliding window broke in january and all the glass is still in my truck untouched
  2. ya me and my brother tried to jump it and it didnt do anyhing.
  3. wouldent i still get power to my lights and radio?
  4. i have an 88 comanche pioneer, 2wd, 5 speed, 4.0L. i drove to the grocery store today and everything was working fine. i got into my truck and tried to start it and nothing happened. all the lights were dead except for the light in the rpm gauge that i added (witch normall turns on with the lights, and this time did not turn off at all). i checked the fuses under the dash and none were blown. every once in a while the dome light would turn on when i opened the door and when i tryed to start it i would just click once and that was it. i tryed checking for loose wires and did not find any. i tryed tapping the started and nothing happened. my battery is brand new as well at the starter, distributer, spark plug wires and plugs. any ideas would help. thanks, kevin
  5. i got the rustys intake package and the 9'' k&n and i noticed a power increase but no mileage
  6. that truck is sweet. thanks. i want to do the dually conversion it the futcher. does anyone have any more info on it? kevin
  7. does anyone have any pictures of the flat bed dually?
  8. thanks for your help and the discount code. and when i put the throttle body spacer in they were not rusty so it is probally rhe iac. thanks
  9. ya when i looked into the throttle body it was pretty dirty. soon I'm gona take it all apart and clean everything. with the injectors i will most likley buy new ones. thank you
  10. hi ive got an 88 mj 4.0 5speed 2wd and when i start it up it stays at 2500 rpm and when i press the gas it bogs down then goes. then when i let off the gas it stays at what ever rpm i was at for about 2 or 3 seconds and goes down slowly. every once i a while my gas pedel feels hard to depress but when i try again it works fine. the motor has even shut off on me while driving. and this is a different subject but the last few times i have filled up on gas i have been getting 8 mpg and before i got 8mpg i was getting 11mpg. anyone know of ways to improve that? any help on both topics would help. thanks akot. kevin
  11. i think somthing is wrong with my truck becausse the last few times i filled it up i have been getting 8 mpg
  12. i have decided that when i get some money i am gona get the hell creek 4.5 inch lift and i wanted to know if anyone here has it and if they recomend it. and if anyone had pictures that would be great. thanks
  13. ok thanks
  14. what do you guys think about the rustys 4.5 soa lift? http://rustysoffroad.com/mm5/merchant.m ... sus_xj_kit
  15. ok thanks
