dasbulliwagen
    3
  1. www.car-part.com shows 3:73 and 3:31 available in an XJ that year.
  2. If you insist on not changing the core support, you might try looking at a WJ Grand Cherokee rad. I modded the electric fan from one to fit my 2.5 rad.... Same rad a s 2.8. So a WJ one might go in with some custom mounts. Might be a good place to start.
  3. You could find a lighted rearview mirror, and wire it in while the headliner is out. I saw a writup on it somewhere http://comancheclub.com/topic/36069-fancy-rearview-mirror-again/
  4. Chrysler has a service bulletin about those bolts. It is common that they break, so they came out with a revised bolt kit that comes with some little plastic sleeves that are supposed to silde over the bolt and into the hole in the manifold before the nut goes on. I'm not sure what they are accomplishiong doing that, but thats what they want us to do. The bolt kit is available still from Chrysler. here's the TSB. NO: 11-07-98 Rev. A SUBJECT: Outer Exhaust Manifold Studs Breaking DATE: Dec. 11, 1998THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 11-07-98, DATED JUL. 31, 1998, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS** AND INCLUDE THE ADDITION OF MODEL YEARS, CLEAN POINTS, AND NEW PARTS. NOTE: THIS INFORMATION APPLIES TO VEHICLES EQUIPPED WITH A 2.5L ENGINE **(SALES CODE EPE)** BUILT PRIOR TO DEC. 7, 1998 (MDH 1207XX). SYMPTOM/CONDITION:The outer exhaust manifold studs may fatigue and break (Figure 1). DIAGNOSIS:Inspect either manifold stud for breakage. If breakage is noted, perform the Repair Procedure. PARTS REQUIRED: Qty Part No. Description **2 06036193AA Stud, Exhaust Manifold** **2 06036221AA Washer, Flat** **2 06036171AA Nut & Washer** 2 33003332 Spacer 1 53020112 Gasket, Intake REPAIR PROCEDURE:This bulletin involves replacing both outer mounting studs, clamps, and nuts **with new parts** and tightening the outer studs to a reduced torque of **20 Nm (180 in. lbs.)**. Remove the intake/exhaust manifold per service manual procedures to gain access to the broken stud(s). Remove the outer studs from the cylinder head. Use a stud removal tool if possible or drill the broken stud from the head. Install two new outer studs p/n 06036193AA into the cylinder block. **Torque the studs to 14 Nm (126 in. lbs.)**. Clean any carbon deposits or debris from the exhaust manifold. Reinstall the exhaust manifold. **Use only the new parts listed above to attach the outer ends (Figure 2).** Torque the bolts in the order and specification as listed in Figure 2. **NOTE: THE TORQUE SPECIFICATION FOR THE OUTER EXHAUST MANIFOLD STUDS HAVE BEEN REDUCED TO 20 NM (180 IN. LBS.)**. POLICY:Reimbursable within the provisions of the warranty. TIME ALLOWANCE: Labor Op. No. Time 09-45-01-92 2.0 Hrs. FAILURE CODE: Code Description P8 New Part
  5. In order to fit the 4.0 radiator, youll need to change the whole front core support (radiator and headlight mounting sheetmetal). This will take some cutting and welding from a donor. You may also need to change the hood, or redo the hood latches to your old hood in order to get the hood to stay shut as the hood latches were also changed in 87 with the different core support.
  6. Ive been on here long enough to have seen, and been the target of issues like this, but they are extremely few and far between, and are usually moderated very well to take care of any problem children. don't let a couple issues like this cause you to get a bad taste from this site. I don't know your particular history of issues though. And it seems like you have your mind made up already. Just maybe step back from it for a while an come back later . This place is worth it.
  7. There is a lot of varied highly skilled and technical experince on this site. One of the things Iove about this place.
  8. One week of that being in there isnt going to hurt anything. The sulfer damage is cumulative, over time... it wold take a bunch of years to cause any real damage. Change it and see what happens before you tear this thing apart.
  9. Did you put new oil in the trans while doing the clutch? I once changed the oil in my Hyundai Accents manual trans with full synth 75W145 and noticed problems like you are describing due to the heavier oil, especially in colder weather.... though when I say cold, it was winter in Michigan. It would shift hard and sometimes grind like you are describing.... until it got warm, then it was fine. Are you thinking of rebuilding it yourself? Its not a job for a novice. You may be better off outsourcing something that in depth. Good luck, and let us know what you end up doing.
  10. dasbulliwagen
    Ferrari
    I can't say Ferrari to myself in my head without doing the accent from the little Fiat in the "Cars" movies.
  11. dasbulliwagen
    Newbie
    Please don't take this the wrong way, I'm not trying to sound mean. Just realistic. Sorry to say, but our trucks arent really worth enough to have the need to keep them 100% stock. There isnt going to be any collector out there wanting to dish out big bucks for a bone stock MJ. That and most if not all the mods listed are reversable. So if you keep all the original stuff, you can put it back if the need ever arises. I'm just saying, you can leave your options open! And have a more enjoyable ride to boot! I guess Ive never been one of the type to want to keep something bone stock. It was like that for when I was heavy into air cooled VW's. I rode mostly with resto guys in the Michigan Vintage VW Club. It was all good though. They did their thing, and I did mine, all together for a common goal of showing off our cars. I do respect that you want to keep it all original though. Good luck, and enjoy it!
  12. When I converted my truck to AC, the donor HVAC box out of my 86 was full of stuff like that. Needless to say it got cleaned real good and doused in lots of Lysol.
  13. Dual Certified- Chrysler Dodge Jeep Ram, and Mazda dealer tech.
  14. Craigslist deletes postings after 30 days or so. If it hasnt been relisted you probably won't find it. That too is assuming jimoshel didnt buy it already!
  15. I agree about using oils rated SL or earlier for the zinc content. Our engines were designed to be run with more zinc additive than what oils today have. And the Mobil 1 High milage oils are no longer all SL rated. Some are now SM or SN, so I stopped using it and will be searching soon for something else to run. Some people reccomend the diesel oils, and some reccomend Motorcycle oils, so I guess Ill be looking into them. Hope this helps for when you get her cleaned out.
  16. To find an axle you may try www.car-part.com this will search all junkyards that are in the system and can be set to search by distance, price or whatever.
  17. Classic car pricing guide strikes again!!!
  18. dasbulliwagen
    Newbie
    Welcome.... If you have to replace the steering box, why not convert to power steering..... best upgrade I ever did. My truck was the same as yours... 2wd, 4 cyl, manual steering, no AC, radio delete, rear bumper delete, bench seat, rubber floor, and bought from the original owner.... didnt even have a cig lighter (not that I need it). There are many things you can do to upgrade here and there and still stay true to the truck. Ive added said power steering, power windows, power locks, power mirrors, AC, lighter, clock, 4wd, and added other upgrades like an XJ country sway bar, JK shocks, Limited wheels, electric cooling fan, "cold" air intake, and Flowmaster 50 series muffler with gutted and sleeved cat converter. It still looks like a stock truck, only its better now. Let us know what you end up doing, and we would love to see some pics. Thanks.
  19. Find someone lifting a JK Wrangler, and get their shocks either for free or real cheap. To install the front ones youll need to press the bar pin from the bottom of your old shck and install it into the JK shock, then it will bolt into the MJ. For the rear, youll need to press out the lower metal sleeve in the new shock, and then it will bolt onto the MJ. They ride real nice, and for me the price was right... free.
  20. It won't fit. Its totally different back there.
  21. It says V-6 2.8 on the grille. I'm not sure what a 2.8 starter looks like, but I'm sure someone here can confirm.
  22. The 86 XJ waggy I got for parts didnt come with a key. I took some channel locks and just turned the ignition with them... broke all the tumblers and was able to turn it to unlock the column in order to steer it on and off the trailer. I assume that this would start it as well if it was running.
  23. Nice truck. Looks like you have a good start. The thing on the rear axle is the rear brake proportioning valve, that adds braking power to the rear when there is more weight back there, and your is installed incorrectly, thus making you have almost no rear braking power. The rod needs to be straight up and down, and the lever needs to be about parralell to the ground going the other way. There are write ups on this site to remove this thing if you want to, or you could just unhook the rod and hook it back up correctly. Looks like you have the coveted rear dana 44 axle too. Nice score! And I assume youre in North Carolina.... where are you?
  24. Many of you may have already heard about Chryslers problems with early build 3.6 engines in the new Jeeps, minivans and cars. Ive recently had the displeasure to try to fix one of these engines. If you don't know about the problems, it involves the improper macining of the cylinder head valve guides causing valves to burn well witin 36000 miles causing a misfire, usually on the 2,4,6 cyl head. In order to change the head you need to pull the front cover, in order to pull the front cover, you need to drop the oil pan, in order to drop the oil pan, you need to remove both axle half shafts, front diff, right side strut, and steering rack assy. And on top of all that, the 3-Bond Mopar adhesive RTV has to be heated up a lot before you can get it to let go and take the covers and pans off without destroying them. And I'm not even going to start on all the hidden fasteners. I'm not sure this posting can really convey the frustration I'm having doing this job. Bad thing too is I have another one sitting right next to it waiting on parts. Warranty time for all this only pays 12.1 hours..... needless to say, my butt hurts.
  25. There are plenty of things you can do to a HP 30 to beef it up. As was said, stronger axles and U joints, you can also sleeve it internally for extra strength, and as you know, trussing always helps. Combine this with WJ knuckles and brakes and steering, a WJ or late style dual diapragm booster, and an 8.8 with welded tubes and disc brakes, and wheel spacers, I would think youd be all set for what you plan on doing. Good luck, and let us know how it turns out!
