3
The A904 is not a bad trans. Its a lighter version of the TF727 from Chrysler. There are a couple of easy upgrades you can do to it just at the valve body. Here is a link to an article that has a lot of good info and in it at the bottom is a link to the fix I mentioned. Does your current 2.5 have an auto already? If so, you can just re use your old flex plate (just FYI, on an auto its not called a flywheel), If it doesnt already have an auto, youll need the correct flexplate, sounds like you might have one for a carburated 2.5 from 84-85. Good luck and let us know what you come up with.
Diesel!
I used to be able to do them like that, but something has changed on my puters and the cut and paste is funky now. Sorry.
Could you re check your VIN for me. It comes up as not found through Chrysler. Theres no reason I shouldnt be able to look up Canadian Vehicle VINs this way as well. Thanks Just looked your VIN over, It appear there are too many numbers at the end. It should only be 6 numbers. I Changed the 1 to an L and have a good Canadian VIN lookup, just want to make sure its yours. let me know.
I'm not sure if anyone has asked, but I persoanlly would like to see what mods were done underneath one of these to make this all work. Including the axles and wheel ends to see how it was all adapted. I too agree you should have a long wheelbase gas tank 23.5 gallon in that thing. The extra gas cans don't hurt though.
Renix 4.0 To 4.2 Stroker Questions
dasbulliwagen replied to big66440's topic in MJ Tech: Modification and Repairs
Anyone have any more info or a link to the mentioned Keith Black pistons? -
When I got my truck, it would intermittantly act like it had a horrible miss, I tried almost everything to get it to stop, before replacing the O2 sensor. Hasnt done it since. This wouldnt cause the tach to drop out, but when it acts up, it can certainly be misconstued as a miss. If I were you, I would start with the Crank sensor. They are a common problem and fairly easy to fix. I'm not sure about the renix years, but in newer ones they come with a cardboard spacer on the tip. When you install the sensor, you set the spacer down against the flywheel and when you start it the spacer gets ground off leaving the proper gap for the sensor. If you pull yours out and reinstall it be careful about the spacing. If you put your old one in this way with no gap, youll chew up your sensor. Just FYI
What Is The Difference???
dasbulliwagen replied to motodh1983's topic in MJ Tech: Modification and Repairs
Lol will you do mine as well? Please and thank you! <IJ7FJ26S4NL177579> You VIN comes back as not found. Is yours an 86??? And I did change the ist digit to a "1" instead of an "l". -
Standard Equipment Code Description Code Description Code Description APAS Monotone Paint BAUS 117 Amp Alternator BCDS 500 Amp Maintenance Free Battery BGAS Power Front Disc/Rear Drum Brakes CDBS Reclining Front Seats CFMS Rear Fold w/Removable Cushion Seat CGGS Traveling Inboard Seat Belt Buckle CGWS Next Generation Front Air Bags** CKAS Carpets - Floor and Cargo Area CKNS Cargo Compartment Carpet CKTS Cargo Tie Down Loops CKXS Plastic Liftgate Trim Panel CSRS Passenger Assist Handles CSSS Lift Gate Assist Handle CUFS Full Length Floor Console DGSS 4-Speed Automatic AW4 Transmission DHNS Command-Trac Part Time 4WD System DJHS Dana M30/181MM Front Axle DRAS Corporate 8.25 Rear Axle GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GNAS Rear View Day/Night Mirror HGDS Deluxe Insulation Group JCDS 100 MPH Primary Speedometer JHAS Var Intermittent Windshield Wipers JJAS Cigar Lighter JJBS Dual Note Electric Horns JJJS 12V Auxiliary Power Outlet KGPS DESCRIPTION NOT AVAILABLE KRPS DESCRIPTION NOT AVAILABLE KTPS DESCRIPTION NOT AVAILABLE K3XS DESCRIPTION NOT AVAILABLE LAJS Headlamps On Warning Chimes LBCS Glove Box Lamp LMAS Halogen Headlamps LPSS CHMSL Lamp MCAS Front Bumper Guards MHAS Black Windshield Moldings MMCS Rear Qtr Solid Window Insert MMGS Belt Moldings MMKS Body Color Drip Trough Molding MNAS Black Door Handles NBKS EVAP Control System NFAS 20 Gallon Fuel Tank QX8S Black Clear Coat SBAS Power Steering SDAS Normal Duty Suspension SHAS Front Stabilizer Bar SHCS Rear Stabilizer Bar TBCS Compact Spare Tire TBLS Inside Mounted Spare Tire XCYS Upgraded OBD-II Connectors XJFS Tethered Fuel Filler Cap YAAS Build To U.S. Mkt. Specifications Z5BS Payload Rating - 1800# 1AAS U.S. Dealer Retail 151S Zone 51-Chicago 5ITS XK-Vehicle Family 5IWS JS-Vehicle Family 614S Illinois State Code 914S Illinois State Code Optional Equipment Code Description Code Description Code Description *DL Prem Leather Trimmed Bucket Seats -C3 DESCRIPTION NOT AVAILABLE ADAP Light Group ARXP Country Decor Group AWHP Power Equipment Group A20P DESCRIPTION NOT AVAILABLE CACP Low Back Bucket Seats CBZP Prem Vinyl Door Trim w/Map Pocket CLEP Front Rear Floor Mats CSAP Spare Tire Cover CSC Cargo Compartment Cover DGB All 4-Speed Automatic Transmissions DHAP Lock-Up Torque Converter DHSP Floor Mount Automatic Shift Lever DMDP 3.55 Rear Axle Ratio EAAC All Engines ERH 4.0L I6 Power Tech Engine GAL Deep Tint Sunscreen Glass GEEP Deep Tint Sunscreen Liftgate Glass GFA Rear Window Defroster GNCP Sun Visors w/Illum Vanity Mirrors GTZP Power Mirrors, Fold-Away GVBC All Vehicles W/Power Mirrors GXMP Remote Keyless Entry HAAP Air Conditioning JAYP Instrument Cluster w/Tach JBGP Instrument Panel Woodgrain Bezel JHBP Rear Window Wiper/Washer JPAP Power Windows JPBP Power Locks JPSP Power 6-Way Driver Seat KBSP DESCRIPTION NOT AVAILABLE KCPP DESCRIPTION NOT AVAILABLE KYPP DESCRIPTION NOT AVAILABLE K2XP DESCRIPTION NOT AVAILABLE LBBP Courtesy Lamps LCDP Map/Dome Reading Lamps LDAP Underhood Lamp LDBP Cargo Compartment Lamp LHDP Headlamp Off Time Delay MBPP Body Color Front Bumper MBQP Body Color Rear Bumper w/Step Pads MDAP Front License Plate Bracket MFKP Body Color Grille MWGP Roof Rack NAA Federal Emissions NHMP Speed Control PX8 Black Clear Coat RAAC All Radio Equipped Vehicles RAZ AM/FM Cassette Compact Disc Radio RCDP 4 Speakers RDDP Fixed Long Mast Antenna SCGP Leather Wrapped Steering Wheel SUAP Tilt Steering Column TRVP P225/70R15 Eagle GA OWL AS Tires TZAP Goodyear Brand Tires WJ7P 15X7.0 Luxury Aluminum Wheels WLZC All Aluminum Wheels YGFA 8 Additional Gallons of Gas ZFJP Spring - Left Front ZFUP Spring - Left Rear ZUJP Spring - Right Front ZUUP Spring - Right Rear 2THA Customer Preferred Package 2TH 26H Customer Preferred Package 26H 3J3A No Charge Air Conditioning 3VUA Customer Preferred Discount
Vehicle Service Information Year/Model: 1997 JEEP CHEROKEE SPORT UTILITY 4-DR Last Odometer: 18,075 miles on February 11, 2000 Body Style: XJJL74 In-Service Date: July 23, 1997 Engine: ERH-4.0L I6 Power Tech Engine In-Service Odometer: 5 miles Transmission: DGS-4-Speed Automatic AW4 Transmission Odometer Type: miles Color 1: PX8-Black Clear Coat Car Line: S Color 2: QX8-Black Clear Coat Build Date: July 2, 1997 Current Market Register: U Hour: 06 Complete Recall Recall Number Description Launch Date Repair Date 860 AIRBAG CONTROL MODULE May 17, 2000 August 2, 2000 879 FRONT BRAKE ROTORS June 1, 2000 August 2, 2000 Vehicle Sale Information Selling Dealer: 66272 - NAPLETON'S NORTHWESTERN CHRYSL Sales Type: 1 - DIRECT RETAIL City: CHICAGO State/Province: IL Country: USA Telephone: (773)334-3400 Rob, Chrysler has you listed as the current owner.
Vehicle Service Information Year/Model: 1991 JEEP COMANCHE Last Odometer: 8,129 miles on September 22, 1992 Body Style: MJTL61 In-Service Date: November 22, 1991 Engine: ERH-4.0L I6 Power Tech Engine In-Service Odometer: 33 miles Transmission: DGS-4-Speed Automatic AW4 Transmission Odometer Type: miles Color 1: PAC-Silver Star Metallic Clear Coat Car Line: P Color 2: QAC-Silver Star Metallic Clear Coat Build Date: April 17, 1991 Current Market Register: U Hour: 12 Vehicle Sale Information Selling Dealer: 23911 - UNDERHILL MOTORS Sales Type: 1 - DIRECT RETAIL City: DICKSON State/Province: TN Country: USA Telephone: (615)446-8855 Standard Equipment Code Description Code Description Code Description APAS Monotone Paint BGAS Power Front Disc/Rear Drum Brakes DGSS 4-Speed Automatic AW4 Transmission DHAS Lock-Up Torque Converter DMDS 3.55 Rear Axle Ratio DRJS 175MM Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass GUAS Pwr Htd Drvr Memory Mirrors, F/Away JAZS Analog Instrument Cluster JCAS 85 MPH Primary Speedometer KDNS DESCRIPTION NOT AVAILABLE KWSS DESCRIPTION NOT AVAILABLE K3ZS DESCRIPTION NOT AVAILABLE LBCS Glove Box Lamp LMAS Halogen Headlamps MB1S Black Front Bumper MFFS Black Grille MHBS Bright Windshield Moldings MMCS Rear Qtr Solid Window Insert MMGS Belt Moldings MMJS DESCRIPTION NOT AVAILABLE NAAS Federal Emissions NBKS EVAP Control System NF2S 18.5 Gallon Fuel Tank QACS Silver Star Metallic Clear Coat RA8S Delete Radio SCES Alcantara Wrap Steering Wheel SFAS Standard Duty Shock Absorbers SGAS Rear Shock Absorbers TBCS Compact Spare Tire TBMS Tire Carrier Winch WJKS 15X6.0 Styled Steel Wheels XBSS Pickup Box YAAS Build To U.S. Mkt. Specifications Z1AS GVW/Payload Rating 1AAS U.S. Dealer Retail 164S Zone 64-Memphis Optional Equipment Code Description Code Description Code Description *B1 DESCRIPTION NOT AVAILABLE -SA DESCRIPTION NOT AVAILABLE ALA SE Decor Group ALK Motown Package BAFP 130 Amp Alternator BCDP 500 Amp Maintenance Free Battery CBAP Straight Back Bench Seat CKJP Black Vinyl Floor Covering DGB All 4-Speed Automatic Transmissions DHTP Elec,Shift-on-the-Fly,P/Time T/Case ERH 4.0L I6 Power Tech Engine GRVP Left Manual Mirror HAA Air Conditioning JJAA Cigar Lighter MBJA Black Front Bumper PAC Silver Star Metallic Clear Coat SBAA Power Rack and Pinion Steering TNCA P195/65R15 BSW AS Touring Tires TZHP Michelin Brand Tires WLYC All Steel Wheels YGEA 5 Additional Gallons of Gas Z01P Rear Spring Group I Z58P Left Front Spring Group Viii Z78P Right Front Spring Group VIII 3VQA Customer Preferred Discount
^^^^ That one is NOT an M715!
Thats all Chrysler has on your 87. The build codes are the three digit (Letters) in between all the "descrition not available" things. Like I said, you might be able to look the codes up somewhere. Hope this helps. Sorry, can't give you the original or last known owner info.
Build Date: September 8, 1987 Last known and original owner lived in Fort Drum, NY Selling Dealer: 23149 - SCERBO AUTO CENTER Sales Type: 1 - DIRECT RETAIL City: PARSIPPANY State/Province: NJ Country: USA Telephone: (201)335-1313 Optional Equipment Code Description Code Description Code Description *B1 DESCRIPTION NOT AVAILABLE -YY DESCRIPTION NOT AVAILABLE AGC DESCRIPTION NOT AVAILABLE APA DESCRIPTION NOT AVAILABLE CBA DESCRIPTION NOT AVAILABLE CGX DESCRIPTION NOT AVAILABLE DCB DESCRIPTION NOT AVAILABLE EPD DESCRIPTION NOT AVAILABLE GAC DESCRIPTION NOT AVAILABLE GSC DESCRIPTION NOT AVAILABLE JJA DESCRIPTION NOT AVAILABLE KD8 DESCRIPTION NOT AVAILABLE LAP DESCRIPTION NOT AVAILABLE LMA DESCRIPTION NOT AVAILABLE MDA DESCRIPTION NOT AVAILABLE NAA DESCRIPTION NOT AVAILABLE PE4 DESCRIPTION NOT AVAILABLE QE4 DESCRIPTION NOT AVAILABLE SBA DESCRIPTION NOT AVAILABLE TBG DESCRIPTION NOT AVAILABLE WMC DESCRIPTION NOT AVAILABLE
Vehicle Service Information Year/Model: 1990 JEEP COMANCHE Last Odometer: 0 miles on November 27, 1989 Body Style: MJJL61 In-Service Date: November 28, 1989 Engine: ERB-DESCRIPTION NOT AVAILABLE In-Service Odometer: 0 miles Transmission: DDQ-5-Speed Manual Transmission Odometer Type: miles Color 1: PW7-Bright White Clear Coat Car Line: P Color 2: QW7-Bright White Clear Coat Build Date: November 9, 1989 Current Market Register: U Hour: 23 Last Known owner lived in Liberty, TN Vehicle Sale Information Selling Dealer: 23151 - CELEBRITY JEEP-EAGLE Sales Type: 1 - DIRECT RETAIL City: MASSAPEQUA State/Province: NY Country: USA Telephone: (516)795-1193 Standard Equipment Code Description Code Description Code Description APAS Monotone Paint BGAS Power Front Disc/Rear Drum Brakes CSRS Passenger Assist Handles DHNS Command-Trac Part Time 4WD System DJHS 230MM Front Axle DMMS 3.07 Rear Axle Ratio DRJS 175MM Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GNAS Rear View Day/Night Mirror JCAS 85 MPH Primary Speedometer K3WS DESCRIPTION NOT AVAILABLE LAPS Shift Indicator Warning Lamp LBCS Glove Box Lamp LCJS DESCRIPTION NOT AVAILABLE LMAS Halogen Headlamps MB1S Black Front Bumper MMCS Rear Qtr Solid Window Insert MMGS Belt Moldings NAAS Federal Emissions NBKS EVAP Control System NF2S 18.5 Gallon Fuel Tank QW7S Bright White Clear Coat SFAS Standard Duty Shock Absorbers SGAS Rear Shock Absorbers TBCS Compact Spare Tire TBMS Tire Carrier Winch XBSS Pickup Box YAAS Build To U.S. Mkt. Specifications Z5AS GVW/Payload Rating 1AAS U.S. Dealer Retail 132S Zone 32-New York Optional Equipment Code Description Code Description Code Description *Q7 Cloth Low-Back Bucket Seats -SA DESCRIPTION NOT AVAILABLE ADAA Light Group ADL Skid Plate Group ALR ST Value Group ARM Radio AM/FM Cassette BA1P DESCRIPTION NOT AVAILABLE BCYP DESCRIPTION NOT AVAILABLE CACP Low Back Bucket Seats CDBP Reclining Front Seats CKAP Carpets - Floor and Cargo Area CUFA Full Length Floor Console DBBC All Manual Transmissions DDQ 5-Speed Manual Transmission ERB DESCRIPTION NOT AVAILABLE GEC Front Left Side Sliding Window GFDP Rear Sliding Window GNBP Driver Side Illuminated Sun Visor GNCP Sun Visors w/Illum Vanity Mirrors GRZP Left Remote Mirror GSZP Right Remote Control Mirror GTZA Manual Remote Mirrors HAA Air Conditioning JAYP Instrument Cluster w/Tach JGBP Digital Clock JHAA Var Intermittent Windshield Wipers JJAP Cigar Lighter KLHP DESCRIPTION NOT AVAILABLE K2BP DESCRIPTION NOT AVAILABLE LAJP Headlamps On Warning Chimes LBBP Courtesy Lamps LBDP Ash Tray Lamp LBEP Cigar Lighter LDHP U/Hood, Removable/Rechargeable Lamp LHDP Headlamp Off Time Delay LNJP Fog Lamps MBJP Black Front Bumper MCAP Rear Body Color Applique MDAP Front License Plate Bracket MFKP Body Color Grille MHAP Black Windshield Moldings MMKP Hi Black Gloss/Black Mirror Molding PW7 Bright White Clear Coat RAAC All Radio Equipped Vehicles RAFA AM/FM Cassette Radio RCDP 4 Speakers SBAA Power Rack and Pinion Steering SCGP Leather Wrapped Steering Wheel SUAA Tilt Steering Column TAAC All Tires TRNA P225/75R15 OWL Wrangler AT Tires WJHP 15X7 Aluminum Wheels WLZC All Aluminum Wheels YEP Manuf Statement of Origin YGEA 5 Additional Gallons of Gas Z01P Rear Spring Group I Z66P Left Front Group XV Z85P Right Front Spring Group XIV 4EA Sold Vehicle 4SPA Supplemental NY Consumer Protection 5KRA Midland Corporation -
The 86, 87, 88 build sheet info is sketchy due to being under AMC ownership and not all the info transferring over. If you post your VIN here or PM it to me I can probably get you a little info, like where it was sold, when, and build date info through Chrysler. If there is a build sheet it will only be codes with no descritions. You might be able to find a Chrysler build code book in that case and translate the codes.
I don't think anyone here is bashing anyone elses education. I have seeen way too many time where something was engineered so wrong that there is absolutely no reason for it, other than the fact that the engineer doesnt have to work on anything he designs. There is some really stupid stuff out there! Stuff that doesnt have anything to do with the constraints of an engine bay, or parts availabilty. The only common sense answer for some of this stuff comes down to an engineer that doesnt have any hands on mechaincal experience. Ive had Chrysler tech trainers, guys who have an inside scoop to all means of the company, tell me the same thing. I know it takes a skilled person to design this stuff and that there is tons of comprimise to made in many facets of car building, but for some of these things there is no excuse.
Ive been saying this for years. One of my biggest beefs being a Chrysler tech, is that on most PT Cruisers one of the AC port fittings is way down near the compressor. You have to take the grille out and the upper core support out to get to it.... freaking stupid!
Get the sta-bil that is made for gasoline with ethanol in it. Ethanol will rust a tank out if let sit too long and most gas nowadays has ethanol in it. I too like the idea of getting the tires off the ground, but for 6 months only you probably won't have a problem as long as they arent leaking out slowly already.
Hey I'm A New Member, Just Got My Comanche, Please Hit Me Up
dasbulliwagen replied to jeepmarine312's topic in The Pub
I think I like the keep it orange but do the trim and badges in black and lower edge camo. Do a search for orange and black camo. I did and there are some really cool patterns that would set this truck off nicely! -
86 Comanche Questions
dasbulliwagen replied to redwolf624's topic in MJ Tech: Modification and Repairs
I think you need to start going farther up the ladder with this inspection thing. The people you are dealing with have no clue what they are talking about. You CAN NOT be failed for something your vehicle was not built with or not required to have when it was manufactured. Either these people or you may just be getting lost or confused about terminology for certain parts. Are we talking about a true auto trans style nuetral safety switch which allows the engine to only be started in park or nuetral, or are we talking about the reverse light switch, which has nothing to do with the manual trans being in nuetral. Are your reverse lights working, and if not, is that the reason they are failing you and they are calling it a nuetral safety switch??? Something isnt right here. I hope we can help you figure this out. -
To Those Of You Driving Newer Vehicles, How Do You Manage Driving An Mj?
dasbulliwagen replied to JeepcoMJ's topic in The Pub
Ive always loved a red or burgundy interior. Though the black one in my MJ fits it nicely. -
Those bus drivers are bat shiznit crazy. Ive been run off the road more than once by a tour bus like that that was in a hurry or just not paying attention. I have no idea where they find their drivers or what pressure those companies put the drivers under, but it aint good!
Are the "DECALS" going to be a-la Dukes of Hazard?
