MiNi Beast
Everything posted by MiNi Beast
  1. gotta read more then just whats on the front page. ive been on here long enough i have to go back and figure out what i did to my jeep as i work on it. you keep track of your build and you have made your own repair manual.
  2. Well here we go again.
  3. always interested in good info but appears the link no work anymore. bummer. thanks for sharing. Jeep Comanche All the Time 0!!!!!!!!!!!!!!!!!!!!!0
  4. lifts are over rated. tcase out and now i shall relax a bit and decide weather i disconnect the battery now before i go about removal of the starter and torqconverter bolts. and then at last remove the aw4 for the last time.
  5. did you check it first? deep pockets eh.
  6. wrong/bad cps or out of alignment. check and replace as needed.
  7. be aware that they may make you responsible for anything after the main. some do the meter but just be ready for he cost. id open my pipes up at meter and ensure no junk in lines. ¹⅔
  8. ummm???
  9. i used a bronzed bushing as had small tip ax15 and big hole 4.0. worked great after 5 years i had to replace it as it did wear funny. but maintenence free and reliable and thats what we are all after.
  10. looks good and broke in. clean it up fresh seals and run it. add a little grease to the needle bearing one. when it warms back up next week ill be where you are currently. so appreciate you sharing whats ahead of me, again.
  11. MiNi Beast
    Spanish?
    my neighbor speaks fluent I could ask him...?
  12. MiNi Beast
    Spanish?
    google translate helps those that do not.
  13. keep that up. you'll learn soon enough you start mixing new with old your going to end up replacing on the old with new as the old gives out faster as you install new parts. like they get jealous or something.
  14. yep replace if got deep pockets like 89MJ.
  15. agreed. like the darkness with the tops under sunlight.
  16. your flex plate can be machined though at local shop. a few bucks but if its smooth, run it.
  17. id spray it down and run it myself. but if you dd it an its a reliability goal, install new now and enjoy longer
  18. what your looking for are bent fingers on the pressure plate, and the clutch disk is like brake pads, want clean and not gummed up with oil or shout. also would like to see good grooves on the disc itself. kinda like slotted rotors as this aides in the stopping and holding power. they are affordable enough to justify installing new while tore down this far. we all been there the first time. you doing good. keep up the good work and youll enjoy soon enough.
  19. how was the clutch before? how was the pedal? they are same clutch plate setup. peace of mind to install new. little grease in pilot bearing and slap it back in with ax15 and run it. worse thing to happen is have to replace it and since you've did it once it will be easier the second time. a breeze after the 5th time. other wise install full kit, fresh bearing and seals and good lube job. next.
  20. i so lost my jbl speaker out the cab as i near missed a knuckle head in front of me failing to utilize the left turn lane. guy followed me for 10 miles and gave it back to me at the stop sign on the exit. and told me of the dummy in front of me they caused our swift maneuvering. His wife and kids also with him all complimented the jeep and wanted to ensure i got my speaker back. very nice of them. hit took a hit and sound quality has gone down.
  21. so just go buy a reman box for maybe $100 at auto parts store. carry on
  22. i use to have grills but they have been kicked once or twice.
