i still have yet to own one let alone have the know how of being able to understand how to use one. Ive gone this long with only a 12v test light. Either has power or dosent.
Simple solution....battery disconnect. doesn't solve underlying problem but does give you an opportunity to find the source if still driving truck. Been there done that.
I was corrrect about the lack of wiring and that he doesn't know how to go about the problem. He needs more guidance thinking a better alt will handle his fan issues.
Constant power wire for memory is backwards. I did that before. Good if you turn it off personally everytime, but easier when it shuts off with the key.
Got a package today from @Torq_Shep. Good man helping me out from his local yards. A manual trans wiring harness to replace my auto harness and clean up some molested wiring. plan to swap this one in with a new rebuilt 4.0. All in good time eh!
The jeep has yet to move since I got got back. Forgot how tiring it was to drive it over the road for hours on end. Still love it. however the bike has been a welcome ride for these last few muggy days.
2 fans to what original wires? Are you not replacing the mechanical fan with no wires? Your accessory fan has wires. You will need a fan controller to turn fans on at certain temperature.
You should do more research as you going for a bigger alt seemingly first seems as if you don't know how to go about this.
I have a aluminum radiator in mine. Only got hot in the tunnel on way back. I need new head or rebuild engine for that matter. My issues have mostly been due to the motor mounts shifting and putting clutch fan into radiator. No longer an issue 😌
I'm not sure 😕 ive had similar issues with the tps and iac and after replacing 4th time, i replaced the regulator which helped with startups and since replace the fuel pump and also went to a 62mm tb. All is good now. 😆 did any of that help?
Whats the pressure rating for the factory ls setup? After messing with my unit there i couldnt see why you couldnt fab a bigger pump to it.. be just a matter of having the right pressure figured then go from there. Also i could still see a fuel cell being mounted in factory location and perhaps might be the better option for your setup.
