Everything posted by MiNi Beast
mini beast Project: Stock To Beast!!!
MiNi Beast replied to MiNi Beast's topic in MJ Hardcore Tech: Epic Journeys to Greatness
stock MJ brake swith set up vs the bolt in WJ set up with a ford brake switch -
WJ Booster and Master Cylinder Upgrade
MiNi Beast replied to Comanche County's topic in MJ Tech: DIY Projects and Write-Ups
XJ proportioning valve??
MiNi Beast replied to CEThomas's topic in MJ Tech: Modification and Repairs
you mean it will tap right in as if like it belong there or something? :rotfl2:
yeah thanks, I found it later, if you see the last post in the link. :yes: but good to have it here though for someone searching for the same. Side note, I have the WJ set up with XJ valve, pulled the rubber out of the valve, running dual piston ford calipers in front and chevy fron calipers in the rear with my 44/60 combo. everything was a direct bolt in, no grinding no anything, Used a ford brake light switch. post a pic in a bit. I am very happy with the results, pedal feels great and I stop like a brand new truck. :D -
this is correct, it is not necessary to pull the old seal.
yes you are correct, have to pull the carrier and install the "inner axle seal" as matching the other side (drivers side) then the old seals are pulled and just rtv the flat plate or cover to block off the shift fork housing that is no longer needed. :thumbsup: rush or no rush sounds to me like the shop guy should of know that. :hmm:
took it on a little test drive :D http://www.facebook.com/photo.php?pid=2 ... 1387163525
test drive made me smile :D -
ok back from Creeping Death's, just finished the ream job on the steering, thank you good sir, now off to install it and take a quick test drive. :brows: -
Well I have brakes. now justfinishing up the brake light switch then hoping buddy calls so can ream out the last of the steering. :wrench: -
Project "Eliminator"
MiNi Beast replied to 89eliminator's topic in MJ Hardcore Tech: Epic Journeys to Greatness
that would do it. -
what size tube is that? seems kinda weak to be bent up like that unless you bend it on a point so to speak. or you try out the hi-lift? :rotfl2: -
well picked up a resivour today with another MC, as he wouldn't split it up, oh well only $20. So thus far I have $50 into the whole brake set up, booster/MC complete, new brake pedal, and brake switch, and XJ prop valve. -
picked up WJ booster and MC so working on installing that, and be swapping out the MJ prop valve for a XJ one to do away with the rear valve on the MJ. Picked up another pitman arm today as well so hope to have the steering done this weekend. -
found it, was looking for this thread. :wrench:
with the pedel set up I have I do not have to grind on anything nor drill the hole in the WJ rod bigger, will be using a old school ford brake switch, something about simple really makes me smile. :yes: -
who has the pics of the different prop valves, XJ, MJ and etc on which one to plug? I had it the other day but forgot which one again. Wanting to install the XJ valve in the MJ and loose the MJ valve(s) -
working on mine now, went to get my booster at jy today and someone took the plastic resevoir off it, damnit so have to get one of them, like $20 I think, but got everything else. Doing something different with the brake light switch though as I no have grinder so will try it a different way. will post pics later. :D -
I remember when it first came out and was limited to only Harvard and other Ivy League college students. My uber-smart friends wouldn't STFU about how awesome it was, but I was just at a lowly NJ state school and it wasn't until about the summer of '04 that my school was allowed on it. Back then, there was another site called collegefacebook.com that all of the non-Facebook colleges were on, but once Facebook opened up to the world, that site vanished. Before Facebook was opened up to EVERYONE with a valid e-mail address, it was a lot more interesting to me. I don't really like to use it much anymore now that my parents, aunts, uncles, girlfriend's mother, and girlfriend's relatives are on it. I moved out of my parents house to have more privacy and freedom, but it seems like every time I put up a status or make a comment on someone's photo or wall, I will get a nonchalant comment about it at the next family gathering. Dunno why, but it bothers me. just don't add them as friends or block them from seeing it. ignored my moms request, told her umm no. :rotfl2: if want to add me then write in your screen name so i know who you are. :thumbsup: http://www.facebook.com/MiNiBeast93
them damn wives! :fs2: :shake: good find for her. :yes:
my next step. :yes: -
oh I understand where your coming from, I think its funny to see mall crawlers wave too, but you got to start somewhere, but the VW is just to much. :rotfl2:
get there in a running jeep. :fool:
- 897 replies
- dana 44/8.8
- arb lockers
- (and 3 more)
yeah cause you live on long Island :thwak:
