MiNi Beast
Everything posted by MiNi Beast
  1. tested my rear locker, it works. :yes: kids wanted to play so we played in the driveway. :shake: We got mud...puddles!
  2. wired up the heated seats and my buns are very pleased. :yes: also found me a nice topper.
  3. no more then a inch and you will be fine. Like I said I run soa and have just over 3/4, which if you look at the yoke you can tell where it was before polished and dirty looking. How it should look L To R Stock yokes; 94 XJ 4wd, 93 XJ 2wd, 94 YJ 4wd. All fit AX-15 trans.
  4. so the yoke should be pulled out 1.5" at level load? i don't think so. :thumbsup:
  5. Will the v8 grand Cherokee coil spring go without modification to the Spring mount? yep. basically same spring as the up country springs
  6. XJ up country coils-1" lift over stock MJ/XJ coils Grand cherokee V8 stock coils- 1" lift over stock MJ/XJ
  7. very soon hope to have mine like that. That is bad @$$.
  8. what mine has and I have a 60 in the rear.
  9. Should have half a day of some good weather. Have fun and don't get dirty. :shake: let me know how the gas tank skid holds up as well. :thumbsup:
  10. I surly want to try within the next few years. It is my goal.
  11. you leaking some oil there? :hmm:
  12. installed new valve cover gasket, cap and wires, and took it for a cruise with the kids, said "dad can we take the doors off?" ok I said. :yes: was a decent day.
  13. sooner then later you will see it happen. :brows:
  14. Congrats and wish you both greatness in life with each other. :cheers:
  15. I tell that to people often, I usually get a laugh out of them. well well I think it is done right insulting and you no friend of mine you meany. :fs2: :rotfl2:
  16. MiNi Beast
    1JTMU6416JT041663
    looks like a rear 44 to me, anyone take a guess? :brows: tails look good enought to grab as well. :thumbsup:
  17. thats, umm different. :hmm:
  18. yeah I had a rail do that on me as well before. I have had more rails laying around then I would ever use, Just scraped 4 of them. :shake:
  19. worked a little last week on my new wheeling camper
  20. pull the doors and still have windows. :nuts: yeah once its dented might as well let it go and just add protection where needed. :yes:
  21. i don't have a grinder as it burned up on me so I was hoping to not have to do that and well forgot to go to work Friday and spent half the day at the junk yard and cam up with this stuff and only got me with a bill for $55. and have an extra mc :D
  22. you did not duck tape towels to the cab? :rotfl2: :rotfl2:
  23. had it left over from my old ford I had, just look up a 79 F250 and should pop right up. :thumbsup: My MJ was converted from manual to auto so had the manual pedals in it when I got it so pulled the clutch pedal out when first got it, then figure I swap in a auto pedal later on and now was a good time, so just pulled a pedal from a 93 XJ and everything bolted right in. and you can see no grinding/ drilling was needed. :yes:
  24. that sucks. :fs1:
