mjeff87
    8
Everything posted by mjeff87
  1. by wiring harness, we mean the COMPLETE harness both underhood and interior. Since you're using an XJ donor you'll also have to splice in the MJ sub-harness in the cab that feeds the rear lighting circuit and fuel pump (MJ is slightly different than XJ in rear lighting circuitry). Your list is pretty much complete, though. I'd suggest you strip the MJ engine bay bare first, then swap the XJ harnesses in and start transferring everything from under the XJ hood into the MJ. Jeff
  2. Chad Smith (drummer for Red Hot Chili Peppers and Chickenfoot) has also formed his own all-instrumental band......the premier album releases today. Go......see........do........ Here's one of the tracks (my favorite, bread balls :chillin: ):
  3. The frame horns on XJ/MJ's are bolted on (not like TJ's that are welded). You'll need a set of 4.0 horns, the bolt holes/studs are there already so you can just bolt them in. 2.5 engine mounts look very similar to 4.0 ones but won't work...you'll need 4.0 ones. Couple other things that are different, aside from all the wiring: -throttle cable -radiator (remove the 2.5 radiator shroud brackets and the 4.0 one drops in) -coolant overflow bottle of some kind for open system (I reused the 2.5 one but had to modify the wiring harness on the driverside fenderwell and eliminate the EGR solenoid) -cover plate on transmission tunnel above shifter -fuel lines, you'll have to splice the 2.5 ones into the 4.0 fuel rail (I used rubber fuel line, some barbed fittings and clamps) -fuel pump (you need a 4.0 one, runs at a higher psi) Have fun :D Jeff edit: disregard the coolant overflow bottle.....you can use the stock HO one out of your XJ. I couldn't use the HO setup on my renix swap because of the way the overflow mounts by the coil area, that's why I reused the 2.5 one.
  4. I ended up going 36H X 72W X24 deep on it…..I gotta be able to get the MJ in in front of it. $40 in lumber in the bench, so far. I’m gonna do pegboard on the back wall and extend the shelf unit over top but I ran out of time today. Wahoo stopped by after the weekend race since he was in town and we had a few brews…. :cheers: Jeff Image Not Found Image Not Found
  5. Thanks guys. There will be some girly crap, but it's all going on that very top shelf where I won't have to look at it :D Gonna run to Lowe's and get some more lumber and build the workbench now. Nothing huge, just something to mount my vise on. 6' X 18" X 40", with a shelf underneath oughta do it. Jeff
  6. Built me some shelves in the garage today…….used a buncha 2X4’s and some OSB Workbench is next Image Not Found Image Not Found
  7. for the front line, there is a metal clamp/bracket that holds it that you have to take off. Carefully pop that large plastic vaccuum "tree" connector (that big gizmo with all the vac lines running into/out of it) and remove the nut from the stud beneath it. Then you can pull the clamp off the stud.....freeing up the metal fuel line. That will give you more movement and help you get the line out of the QD. There isn't much room on the back fitting, but it will come apart eventually. Try hitting both with some silicon spray as you try to work them apart. Jeff
  8. if they're Renix lines, you don't need the disco tools.......squeeze the "ears" inward and push backwards while twisting the rubber line. If you've never had them off, they can be quite stubborn but just keep at it, twisting the line gently and they'll eventually pop off. Jeff
  9. mjeff87
    what is your DD
    '01 TJ (2.5L) Can't wait to trade it on either an 00-01 XJ, or a Dakota pickup... it's a lotta fun to drive, but not as a DD :ack: Jeff
  10. MJ - stick TJ - stick wife's Subaru - auto :chillin: manual FTW Jeff
  11. it wasn't pretty........but we'll take the win :chillin: Stillerz '09, off to a good start! Jeff
  12. X2 on the single reuse The bolts are called torque-to-yeild (TTY) and can be reused one time (and should be marked if so). But, if in doubt, I'd replace them. Be warned, they are not cheap.......about $8 EACH from the dealer. Don't forget to add sealant to the threads on #11 as it passes thru the water jacket. Jeff
  13. RE HD trackbar and brace on mine…..the brace is a PITA to get bolted in, but other than that it's a good setup. Image Not Found Image Not Found Jeff
  14. sig worthy........
  15. Budhound, props to you. You show a can-do attitude that, sad to say, is lacking around this country as of late. My wife and I moved here to VA about 10 years ago, her with a company transfer, and me jobless. Second day here I called a temp service, went and interviewed/tested (scored well) but they didn't have any jobs available and I said thanks and went on my way. Two days later they called me back and said they had a job, pretty crappy in an even crappier part of town, and it only paid minimum wage.....I took it becuase it was WORK. Ten years later, we're doing pretty good, I'm vested with the place that took me on as a temp and saving buttloads of cash for retirement (still 20 years off, but I'll only be 60 then). Life is what you make of it, with what you are handed. Jeff
  16. 1.31 jiggawatts...... :D Jeff
  17. viewtopic.php?f=7&t=11205 not a hard swap, but you need some very specific parts..... ;) Jeff
  18. .....and the Dirty O's for some french fries :yes: Jeff
  19. Brent....glad yer still alive and kicking :cheers: here's wishing the best for you and Tina....we'll always be here, so check in when/if you can. Jeff
  20. viewtopic.php?f=6&t=11077 :cheers:
  21. glad ya had a good trip Pete :cheers:
  22. I've seen them in the junkards from time to time as well, never checked what years they were. First one I saw made my head turn.....I thought whover owned it did some creative swapping of parts somewhere down the line. But then I saw a few others. Jeff
  23. just as soon as it drops below 100 degrees up here... ;) I might try to leave work early tomorrow and go (but it's supposed to rain, so we'll see) Jeff
  24. 24X20 here too in the new house (actually the door is only 20' wide, didn't notice that on the build as I was more worried about the height and if my MJ would roll in/out....it does but with only about 3" to spare :roll: ). I'm in the same boat as Pete...I've got a D-ring hitch mounted in the front receiver that I have to take out or else I smash my thigh trying to walk in front of it nosed-in. If I still had the stock step bumper I'm not sure if the door would close or not ;) Jeff Image Not Found Image Not Found
  25. eggzachary ;) Jeff
