mjeff87
    8
Everything posted by mjeff87
  1. 904/909's are 23 spline..... found that out the hard way converting my buddy's YJ from auto (909) to stick (AX5) go figure :roll: Jeff
  2. I swapped an 89 (4.0) engine side harness that didn't have the C101 into my 87 (2.5) that had the C101......it plugs up 100% Jeff
  3. and on this fine Veteran's Day eve, I wish you all in the Corps a happy belated birthday and a good day tomorrow (and every day) thank you for your service :USAflag: Semper Fi Jeff (USAR, E-5)
  4. when Pat and I SOA'd my D44, we just set the new perches parallel to the stock SUA ones and burned them in (to retain the original pinion angle, just as mvusee explained). I know you can't do that, since your axle came from an XJ, but IIRC the pinion angle was something like 7 degrees or so. I'll grab my angle finder and toss it on the axle in the morning and snap a pic for ya.....that should at least give you something to start with. Mine's sitting at ride height on 35's, and I don't have a single driveline vibe to speak of (axle wrap is another story, however.....) Jeff
  5. that 42" is correct, and it's from the center of the pin hole to center of the pin hole (not from either end of the perch). HTH, Jeff
  6. Just an update to the club, Pingpong (Pat) was in an accident last weekend at an annual run down here. It happened post-run last Friday night, after everyone was off the trails and back at camp. He was a passenger in, of all things, a golf cart :roll: , and got tossed out when the driver made a stoopid maneuver. He's got a broken tib/fib in his right leg below the knee, and a broken left foot, and will be in rehab for a good while. He's in good spirits, though (he called me from the back of the ambulance transporting him from UVA med center to the rehab facility). I'll post more details when I can......his wife is rigging up a laptop for him so he can commo from rehab, so he may check in also. Jeff
  7. mjeff87
    im moving
    I was born in Comanche County, Oklahoma...... :D (Ft. Sill) Jeff
  8. checked your exhaust....tailpipe, muffler, etc? Maybe you munched something. Jeff
  9. edited for clarity.... :rotfl2:
  10. Put your dog and your spouse in the trunk of her car. An hour later, open the trunk. Which one is really happy to see you? ;) Jeff
  11. I know that person who's cited on the Novak website, personally...... :D Jeff
  12. or you could eliminate the ballast resistor entirely.....the only reason it's there is to quiet the pump a bit. Just splice the wires together. Jeff
  13. XJ's got AW4's behind the 2.5's too.....my front axle (4.56) came out of one, and I saw another one at Harry's last summer (didn't have the tools or time to pull anything). Counting them, I've seen three other Jeeps with that setup, and they were all MJ's. I've got an AW4 2.5 bellhousing, TCU, torque converter, and TBI (with the extra TPS connector) sitting in my parts pile, in case anyone's interested....... Jeff
  14. The wife and I are going on a much needed and postponed vacation.....shoulda happened back in April but we put it off, and can't stand it anymore. Ocean....drinks....cigars....good eats.... leaving on Friday for Ft. Lauderdale to set sail on Saturday, and won't be back until ????? Y'all have fun :cheers: Jeff
  15. I've never bought anything off eBay (yet), but look at the bid history for those......something looks shady to me. Lotsa bumping by the same bidders within a short time frame. Wonder if they are friends of the seller...... I've worked plenty of live auctions in my day to see "bidding up" when I see it. Jeff
  16. Isn't that one of the signs of the Apocolypse?? :D Bet your wife is happy......
  17. I had the same problem with the Mopar perches (5/8"). I ended up installing the pins "backwards", with the pin ends and nuts into the hole in the perch. The nuts fit very snugly into the hole, plus they were 2X the height of the hex head on the pin and sit farther into the hole. So far no problems. I wasn't about to drill out all of the leaves..... Jeff
  18. did you install new u-joints? They tend to wear in at the fixed angle they've been operating at, and when you change the operational angle they aren't very happy. I'd swap them as a start..... Jeff
  19. there was a member on here that attempted to get an HO to run on a Renix engine harness only (was it Corey?), but the last I heard of that project he was selling it, saying it had some "issues".....couldn't get it right I suspect. You'd be better served finding an HO interior harness and swapping it in. If you can't find an MJ one, you can use an XJ one but you'll have to splice in part of your existing Renix cab harness (the subharness that connects the rear lighting and fuel pump wiring) Jeff
  20. mjeff87
    New Member
    sounds exactly like my grandfather, except all he ever drove were pickups (either Chevy or Ford, and never bought new) that were "3 in the trees". He'd always shift from first, after winding it waaaay out, to third......didn't want to wear out the clutch, and second gear, apparently. I'm happy to say I grew up just like him (cheap). Ask my wife about it sometime ;) Welcome to the club Dave. Jeff
  21. not my MJ per se, but it used to be......Pat (pingpong), me and another jeeper swapped my old 2.5/AX5 combo into his 90 MJ today in the rain..... in the wind.... in his driveway on sheets of plywood..... and it all purrs like a kitten. A most proper Jeep repair, complete with steaks and bakes on the grill, and plenty of beers :cheers: Jeff edit: couple pics....http://www.mpjai.com/vbulletin/showthread.php?t=8644
  22. you've got the same quill, it just plugs into the tailshaft of your 2WD tranny, not into a TC....just pull out the electrical-style quill on the new TC and insert. You may need to extend your speedo wiring, though. Jeff
  23. I'm running one of Jon's (5-90) full Renix wire kits.......good stuff. recommend X2 Jeff
  24. be careful when removing the old one from the manifold......I swapped one on my old 2.5 and the old one snapped clean off at the threads, flush with the manifold. I ended up having to use a fluted extractor to turn the remnants of it out and then clean out the manifold before installing the new one :fs1: It's a brass fitting into an aluminum manifold (dissimilar metals), and the factory loctite didn't help the situation any, either..... Jeff
