mjeff87
    8
Everything posted by mjeff87
  1. R&R the clutch while you have it all apart if you want to. Also, the rear main seal in a 2.5 is a one-piece deal (unlike the 2 pc one on a 4.0).....I'd suggest replacing it while you have the flywheel off. It only costs about $5 :D Check the other welch plugs as well on the side of the block. Jeff edit: Don beat me to it..... :yes:
  2. There's one in the back of the head above the bell, and yes, there is one in the back of the block. You have to pull the tranny and flywheel to access it. Jeff
  3. if I want to pound down beers, I gotta go light beer....I'm not as young as I used to be :cheers: If I want to seriously enjoy a good beer, I go for Duval (trappist monk Ale) :yes: If you haven't tried it yet, you should (bring your wallet though) ;) Jeff
  4. Not to stray off topic, but you STILL haven't gotten your harness yet?????? If you just need the engine-side, I can run down to the pick-n-pull (going there tomorrow anyway) and pull you an XJ one. No MJ's in there currently....lemme know. Jeff
  5. SW...there's like a .06 cent O ring in there that you need to replace. But if you went bonzaii on it with a mallet, odds are yer gonna need more than just the O ring..... :no: ;) Jeff
  6. finally came to a supermarket near me picked up a 12 pk of bottles on the way home from work today 9 beers in, and they are yummy that is all.... Jeff
  7. I have to disagree with you possum......you've got it backwards. The plug on the passenger side is in the trans body midsection, and behind it is a detent ball and spring. Plus, it's much higher up. The fill plug is on the driverside, on the front section of the tranny: Image Not Found
  8. yeah, I know.....it just really cheezes me off. This one is supposed to be the nice Jeep, that doesn't leak anything. I now have a leaking axletube and some kind of mystery coolant leak from the front of the engine somewhere that I can't find, that only drips when it feels like it wants to. H@ll, the 200K+ MJ that I frankensteined together, with Pat's old 4.0L doesn't leak a drop (from the engine, but I do have a small seep from the D44 cover in the rear......I used a paper gasket last time).
  9. I'm digging it..... "I shot your dog"..hillarious I might pick up a CD or two for some roadtrip music. Jeff
  10. nothing at the auto store, but I've done an alternator in an interstate rest stop area 90 miles from home and any part of civilization, a starter in a grocery store lot, and a fuel pump in a U-store-em place parking lot. Funny, all three were on the MJ...... :oops: I do carry almost every tool I own in the toolbox in the bed (and wonder why I only get like 12 mpg) Jeff
  11. Had to put rear brakes on the TJ last weekend, and discovered this bit of loveliness at the rear axle.........this thing barely has 100K on it, and has never been offroad. Anyone think some RTV around the tube would help any? :headpop: Jeff Image Not Found
  12. dash and taillights are connected, and for a reason. Some brainiac decided to wire them together so that if the tails go out the dash lights will also....to let the driver know they have no taillights. I troubleshot my dash lights for a long time when they went out a few years ago. Turned out that the wire going into the INST LIGHT fuse in the block from the back loosened up and was making intermittent contact.....I only found it by accident one evening when it was dark out and I was wiggling the fuse. I saw tiny, dim flashes coming from behind the fuseblock. Jeff
  13. mjeff87
    bear safety
    most of you are missing the funny part....... ;) Jeff
  14. mjeff87
    bear safety
    Image Not Found
  15. don't forget to hang yer laundry off the winch cable in the front yard too..... :D Jeff
  16. Tim fear not the 4.0 swap.....even in your 86 there's plenty of knowledge here to help you :cheers: Jeff
  17. I've always reused the originals...never had a problem. You might want to replace that torx plug with a regular hex head or pipe plug, though. I personally hate torx..... Jeff
  18. if that torx plug is on the driver side of the trans, about half way up the side, it is the fill plug. Alternately, you can pull the shifter out of the top of the trans and fill it from inside the cab. Jeff (the fill plug on my TJ is the same plug with the same warning.....I guess you're never supposed to change the fluid :shake: )
  19. our children…….from left to right, Speedbump, Cracker, and Autumn Image Not Found and before any of you say that we feed them too much…….we don’t :D . Here’s a shot of my wife’s aunt and uncle’s cat, Buttons. She comes in at a svelt 26 lbs (our Autumn is the largest of ours and is only a light heavyweight at 22 lbs :roll: ) Image Not Found Jeff
  20. negative....flywheel bolts are about 1/2" longer than flexplate bolts. Same thread/pitch, though. Jeff
  21. another possibility.....your original trans may have been bad, and it could have been a 21 spline output with a matching 21 spline input TC. The ZJ trans is a 23 spline. Your 21 spline TC will bolt up to a 23 spline output tranny, but there's no spline engagement between the two....the output just spins inside the input gear. Had it happen to me swapping an AX5 into a buddy's YJ in place of a TF909. Neither of us ever figured a 909 had a 23 spline output and didn't bother checking, just slid the 21 spline 231 onto it and couldn't figure out why it didn't move. :dunno: Oops... Jeff
  22. if it's an 87, there could also be a stamped plate on the driverside radiator support (beside where the end of the hood prop rod rests when it's stored in it's clip). The first code on the bottom set of numbers in the left corner are the paint codes. Per the FSM, "4M" is the code for Charcol Gray Metallic Clearcoat. HTH, Jeff
  23. Genovast new avatar FTW!!! :ROTFLMAO: :cheers:
  24. they are E12's..... if they're boogered up past the point of no return, you can use a set of those damaged fastener-head extractors. They work well. Replace those with regular hex head bolts upon re-installation and never go thru the frustration again Jeff
  25. this music is a variable blend of MANY different genres.....you really have to listen to more than just one of their tunes. F'rinstance....here's one for all you David Gilmore fans (and if you don't know who he is, well...shame on you): I've got the CD coming to me tomorrow. Good thing, 'cause the wife and I have to roadtrip up to PA on Thursday. At least we'll have good tunes for the trip. The album (CD) is titled "Meat the Meatbats". Enjoy. Jeff
