8
Everything posted by mjeff87
that, my fine feathered friend, is an XJ assembly as stated. I've got a brand spankin' new one of those, still in the box, sitting in the parts pile, anditdontwork ;) If anyone knows anyone looking for an XJ assembly, let me know. I'll sell mine for half the cost. Jeff
Dayum....for that price I'll unbolt mine and send them to you No extra charge for the hazing on the lenses, either :D Jeff
I've got a Renix sender/harness assembly that I pulled out of a junkyard 2.5 MJ. The only problem is that the faceplate has a couple (typical) cracks in it where the hard lines exit. I was going to have my neighbor buddy take it into his work and TIG it and keep it as a spare, but if you need it and can repair it locally, shoot me a PM and we can maybe work something out. I really don't want to sell it because of it's rarity, but if it means keeping another MJ on the road, I can be persuaded to ;) Jeff
still shooting for Saturday the 20th if you can swing it Greg. I promise it will be worth whatever torment you'll have to face with the Mrs. ;) For the record, there is now one unemployed "loan specialist" at the mortgage company we're dealing with. Sniff, sniff.....I don't tolerate incompetence. One more issue with the landscaping that I'm told will be resolved tomorrow, and we will set the official close date. Jeff
I'll say one thing about the axle housing and tubes......that darn 8.25 is a whole lot heavier than a '35 (and a '44 for that matter). Working by myself at the junkyard, it was a whole lot harder loading that thing into the wheelbarrow and then into the bed of the MJ than any 35 or 44 I've ever pulled alone..... Jeff
are the bolts snapped off inside the nuts? is there any of the bolt shank still sticking out of the framerail? If yes, a few good whacks with a deadblow ought to break the welds off the nuts. I know there's not alot of swing-room there with the bottom of the bed section so close to the framerail. I had to use a right angle drill on a couple of mine. Drilled thru the nut and the opposite side of the framerail and then ran a long bolt the whole way through with washers and nuts. If you take the bumper off you can look thru the ends of the framerails and see the nuts, but they're too far back in the frame to get on them with anything (that I can think of anyway....) Good luck. Jeff
Boilermaker, I hope you get your stuff. I've been following this post since the start, seeing how things pan out. Looks like things might finally work out for you :cheers: Some of you guys on here have bought some stuff from me before and can vouch for this, but this is the way I operate (and knock on wood, I haven't gotten pinched yet): 1. we agree on a price, method of payment, and wether shipping is included or extra 2. I send a couple pics of the item to the buyer to review to make sure it's what's expected and how I described it 3. if good on #2, I ship the item to the buyer 4. once received, I ask the buyer to confirm the part will work/function as desired and it is in the condition described 5. if yes to #4, buyer then sends me payment. If no to #4, buyer return ships the item to me at their expense and we both go along with our lives I know that process leaves me open to a bit of deceipt, but like I said so far everyone I've dealt with (on here and on other boards too) has been good. Might I get screwed somewhere down the line? maybe, but I'm just as choosey a seller as I am a buyer. If something smells even remotely fishy, I'll keep my stuff. Call me old fashioned ;) What 87mjdriver posted is a bit disheartening..... YMMV Jeff
I grabbed that axle yesterday, and tore it down this morning. It was actually a 96 XJ and I got a bit hopeful that it would be a 29 spine, but it's not. I'm gonna hit the yard again this weekend coming up and pull a carrier and shafts from a late model XJ and see if the spiders fit the carrier and if the bearings fit the shafts. I'll let y'all know what I find out..... Jeff
don't neglect a leaking clutch master cylinder.....
mjeff87 replied to mjeff87's topic in MJ Tech: Modification and Repairs
actually it wasn't the fuse that caused the problem with the brake lights, it was a splice I made last year to the brake light switch. I was messing around up under the dash yesterday, and I guess I must have pulled the wiring and loosened the connector :oops: Funny thing is, all of those things that used to be called fuses^^^ were still working when I pulled them (or pieces thereof). -
hey...I just said it was gonna be a good second period......I didn't say for what team :eek: :fs1: Jeff
remember the second period of game #4 :yes: Jeff
Driving back from the junkyard today, a guy in a car behind me pulls up and tells me I have no brake lights, so I drive the rest of the way toggling the parking lights when I stop so noone rearends me. Troubleshoot at home and fixed it (turned out to be a loose wire on the brake light switch I swapped in when I did the dual diaprahm booster upgrade last year) but in the process I pulled the 5A instrument light fuse to check it and it crumbled in my fingers. Started pulling the rest of them, same thing. I had a leaking clutch master a couple of years ago, and doused the entire fuseblock with electrical cleaner which cleaned the block ok, but I guess the fuses were a delayed reaction. Moral of the story, check your clutch master! Jeff Image Not Found
well, I'm in the parts gathering process to build a non-disco with 4.56's and a locker to replace the 200K+ disco open one I'm running now. I figure while I'm still working on it on the bench I might as well truss it a bit. I agree on the disposable part, if it was an open carrier and stock ratio, though. Thanks for the pic Wade. Jeff
low ratio carrier???????????
mjeff87 replied to 88mjmanche's topic in MJ Tech: Modification and Repairs
because as the ratio gets deeper, the pinion gear gets smaller. Like Genovast said, that increases the space between it and the ring gear. The carrier is thicker to make up the distance and gain proper gear face engagement. Some axles have "thick cut" gears available for them, and you can use the original carrier (the thickness of the ring gear makes up the difference) Jeff -
My wipers dont work!!!!!
mjeff87 replied to jeep_freek88's topic in MJ Tech: Modification and Repairs
congrats.....I'll have a beer or ten after work in celebration for ya :chillin: Jeff -
Who's running any kind of upper truss on the long side of a non-disco D30? Bought, homebrew, whatever......I'm looking for some design pics. Please post up if you have any. Thanks, Jeff
don't need straps JT, but if you want to bring handtruck(s) they would be helpful. We've got a crap-ton of boxes we can use them to move. Already have an appliance dolly for the fridge, and that's the only appliance that needs moving (all the other ones are already installed new ;) ). The other stuff that needs moved is the usual, living room/bedroom furniture and clothing, and a glass dining room table that we'll move first before we start drinking for obvious reasons :yes: The one monster that does need moved, and it's gonna take 3-4 guys, is a huge console flat screen TV and the stand it sits on. There's a couple big gallouts coming that I'm gonna sic on them. I also have a smaller flat screen console TV down at the storage shed (with all my Jeep crap) that a couple of us will need to ride down and bring up to the new house. It's a 2-person TV, but I want to put it upstairs in the bonus room......that may be a bit fun. Jeff
as much as I hate to say it, and I do mean this with all due respect to Detroit as an original hockey town.......their fan base is waining :( Not like D-town or any other city in the rust belt needs another kick in the crotch right now, but I think we have the momentum swing. Regardless of who you root for, whether they're playing right now or not, you gotta admit this final series is some of the BEST hockey being played in the last 10+ years. Whoever wins it will certainly deserve it. :cheers: Oh, and VERSUS coverage...........sucks. I want my Mike Lange on audio simulcast over the interwebz, so I can listen to the games in true fashion (you 'burghers understand :chillin: ) That is all. Jeff
still on-line for the weekend of the 20th.... got a few "issues" I'm working thru with the builder, the mortgage company, and the landscape subcontractor, but I'm fairly confident they'll see things my way, eventually ;)
series even now. It's a best-of-three :nanner: Jeff
well, I never did look to see exactly what all fuses and relays were still plugged into the fuseblock before I sent it to ya LOL..... sounds like that would be yer problem right there :yes: Jeff -
It's runnin', right? That's a good start :yes: Like I said, whoever the PO was on the donor vehicle I pulled the harness out of in the junkyard had an aftermarket (Viper) alarm system boogered into the cab harness. I un-spliced it all back out and tried to pair up the original connections by wire color. There were 3 splices, mostly all large gauge (high draw circuit) ignition wiring. Jeff -
I can't speak from experience, but I was under the impression that you needed a 29 spine carrier to swap the shafts....maybe bearings as well (the 29 shafts have a slightly larger OD). I might just go snag that axle anyway, just to have. Then I can play around with it and see what works and what doesn't. You could just put a full case locker in it and call it good, too :yes: Jeff
If he is, that's about all you need to get some satisfaction..... :ack: Jeff
