88mjmanche
    Colrain MASS.
  • Interests
    JEEPS DUHHHHHHHHHHHHH
88mjmanche's Achievements
Comanche Aficionado
Comanche Aficionado (4/11)
  1. correct the 96 transfercase has a 23 spline count and mine has a 21 spline count..... you are correct i want to keep the same drice shafts ALSO my speedo is cable driven not electric so theres a problem so i pulled out the 23 spline input very simple and I'm going to install it into my tcase problem solved..... but wil the ds stay the same i ask again and do i use the whole clutch assy with the ax15
  2. i have an 88 mj cheif, short bed, 4 wheel drive, 4.0 with the ba10/5... i have the whole transmission/t case from a 96 cherokee... the bellhousing,clutch assy...master cylinder with line and external slave....... its attached to a 231...... yes i know the 96 231 has a 23 spline count as to my poopy 21 in the ba10... so no match up on that. here's one my questions can i take the input outa the 96 t case and put it in mine. and put it in my t case onto the ax15????? Question two the transmission cross member how far off is it i got a welder sooooooo i can fab up some stuff..... BUTTTTTT my biggest question is the rear drive shaft length is it going to stuff my slip yoke into my t case cause that would suckkkkkkkkkkkkkkkkkkkkkk
  3. tooo late i ripped the axles out dana 30 aussi 3.07s dana 44 welded 3.07 700$ for sale in a month my friend might want them so i gave him a month
  4. hers a pict what do you guys think and o yea I'm ripping it apart right now :yes: i just bought some dana 60s and some leafs and also 39.5 super swampers
  5. yea the shock boots were put on about 3 hours prior to the event and the tool box tailgate was a last minute thing worked good though :dunno:
  6. are those H I D lights if so sweetttttttt
  7. can you say liberty wanabe i don't like it at all :ack:
  8. well yea that would cause some shimmy and i had my passanger side U joint break caused some wobble also look at your stearing stablizer :thumbsup:
  9. up it tells those toyota boys the name of a real truck
  10. crack don't smoke itself imagine yourself at home no power raining like a beotch and a broken comanche you might lose it too and yes my labtop had power thats it
  11. :agree: yup
  12. the last time i used paypal i got jipped out of 90$ that pissed me off :headpop:
  13. oooooooooooooooooo thank youuuuuuu :bowdown:
  14. soooooooo i just calculated my MPH with a top speed calculator ofline and it told me i will have a top speed of 50 mph at 4000 rpm?????? i have a 88 with the 4.0 low output , i put in .79 as a 5th gear ratio ( I have a five speed ba10/5 ), 2.72 as a transfercase ratio, and 4.10 as axle gears. i also have 32 inch super swampers. my question is...... is the topspeed right at 4000 rpm and 5th gear i will go 50 mph ?????????????????????????????? :nuts:
