Giffer
    Didsbury, Alberta
  • Interests
    jeepin and huntin
Giffer's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. tail lights on these units are damn near impossible to find for under $100 a peice. and I'm sure that some of you also refused to pay that, so what I'm wondering is what is the easiest swap?? i know nothing will mount exact but whats the closest?? XJ??
  2. so what did everyone figure out?? I'm looking to do a 3/4 on the MJ and this post is perfect. but since i won't be starting for a couple of weeks i would like to know how everyone made out.
  3. what do you mean by "blade" on the tractor?? everytime ive ever got the tractor stuck i just tilt the bucket to the inside, pick up the front end and lift the bucket to the outside. pushes back about 6 inches. i found it works really good. saved me a time or two for a pretty sticky situation.
  4. while digging the holes for my fence this past spring i found a set of vise grips, they were about 36 inches down. they were messed. while taking a brake i through them in a pale and covered the vise grips in vep 45. the rust was still there but they work as if they were new. i have since cleaned them up with a wire wheel. no rust and no shiny finish.
  5. well it time for pay back. them them some random thing is going, like the differencial fluid pump is going do to the mud. thats always fun, unless you like your job.
  6. as a good ol' alberta boy, I'm kinda lost where wainwright is?? haha, wicked good hunting up there. planning a jeepin trip for summer 2011 up to alaska. its gonna be great. have fun
  7. i know. like i said before they were on that jeep when i purchased the YJ and I'm not 100% on what they came out of. but I'm having one hell of a time finding conversion brackets though. i think i might have found some.
  8. ill have to check them out. i can't seem to find what I'm looking for on the ruffstuffs site. lots of goodies but i can't find the dana 44 to coil conversion or brackets.
  9. its the front. I'm not 100% on what they were out of but the YJ is leafs and i need a kit/mounting brakes to convert the front to mount coils. but i will have to look up those ruff's. thanks
  10. ive got a dana 44 out of my YJ and was looking for mounting brackets to mount to the MJ. anyone know of any companys that would makes and sell them?? the welding is not an issue but i don't want to waste my time on cutting them off the MJ and then rewelding them.
  11. wow its been a week for ax15's. i pulled mine out of a 91 yj also, but took the np231, clutch, and all the other goodies
  12. the top is the crank position sensor if I'm following you correct. is there like a 2 inch oval hole??
  13. i think when the clutch was installed something was forgotten like the clutch release bearring or something along that line. i was just think about having a spare.
  14. got my ax15 and np231 today, 4wd here i come.
  15. is the clutch of the pukegoat the same as the one in the ax-15?? i just pulled my donor ax15 and np231 out and the ax15 was having clutch problems, so i was wondering if a could just take the clutch out of the pugeot and drop it in the ax15. would it be the same through out, etc.
