28
Everything posted by HOrnbrod
Yes, a CYOA move for sure. The two lines were in fact touching on mine and I wrapped them with slit pieces of 3/8" fuel hose at that point so they're well insulated from each other. I'm sure all the 2012-2013 JK owners did the same, right? NOT!
Got one in the mail I knew was coming regarding the automatic transmission oil cooler tube rubbing against the power steering steering pump return eventually causing a hole in the cooler tube. I knew about this one months ago from reading JK forums and Chrysler finally made the formal recall after thousands of transmissions burned up. I have the lines tie-wrapped away from each other so they can't rub. Called the dealer to schedule an appointment and guess what? They don't have the parts yet to perform the recall. Until they come in, if they ever come in, JK owners are advised to keep an eye out for transmission leaks. This will really help someone cruising down the interstate heading for Florida or somewhere............ :fs1:
Your back yard sounds like it needs some work mate.
Steering Conversions. . .
HOrnbrod replied to ftpiercecracker1's topic in MJ Tech: Modification and Repairs
93-98 ZJ actually. -
What year HO?
Ball Joints...is This Right?
HOrnbrod replied to mpace6a's topic in MJ Tech: Modification and Repairs
How much up-down play did you have with the old ball joints? Looks like you may have had some as it appears the hole has been wallowed out a bit. Since you have already pressed them in, I'd use a washer thick enough so when torqued down the cotter slides snugly into a castle nut slot. Should be okay. Did you use an after-market ball joint set? -
You live in VB? Did they close the expressway to Norfolk? C'mon man............
Rough Idle And P0340 / P1391
HOrnbrod replied to Akula69's topic in MJ Tech: Modification and Repairs
Good to hear Jake. I'm a believer in using OEM factory parts whenever possible if available, especially electrical parts. Costs more up front, but usually saves big in the long run. I have a stockpile of most all the Mopar electrical OBD1 stuff I'll ever need. Unfortunately it's drying up quickly, especially the Renix stuff. -
My '89 Comanche - Getting an LS2
HOrnbrod replied to Korsch_RS's topic in MJ Hardcore Tech: Epic Journeys to Greatness
According to the Bilstein tech rep I talked to, your rear shocks are mounted upside-down. The correct mounting position for the Bilstein 5100 series shocks are for the writing and part number stamping on the shock body be right-side-up, like this, rod down:- 117 replies
- 6.0 ls2 chevy v8
- 4l70e
(and 3 more)
Tagged with:
Jeep Comanche Engine Swap To Diesel? Renault 2.1L
HOrnbrod replied to Mjobession's topic in MJ Tech: Modification and Repairs
These guys have rebuilt Renault 2.1 turbos. http://www.winnebagoparts.com/lesharo-phasar.php -
Would have been a lot better if they were using these:
Forgot about these too, because they were, errr, forgettable. Lincoln Mark V Emilio Pucci Edition Chrysler LeBaron convertible Mark Cross Edition AMC Matador Oleg Cassini Edition AMC Hornet Gucci Edition AMC Javelin Pierre Cardin Edition Ford Thunderbird Fila Edition Although the Matador was okay:
I've always thought naming cars/trucks after clothing manufacturers was pretty lame. Ford Explorer Eddie Bauer Jeep Grand Cherokee Orvis Edition Jeep CJ5 Levi Edition
onlyinajeep726, you are correct. I installed an XJ power antenna in my MJ a few years ago, but did not document the wiring diagram. But from memory, the 4-pin connector goes to the antenna relay, the 2-pin to the power antenna, and the small spade connector goes to the radio power antenna output terminal; the other to ground. It is a factory part, as that harness came with the power antenna.
Tsm Who Has It & Were To Buy From
HOrnbrod replied to hassyfoto's topic in MJ Tech: Modification and Repairs
Five seconds of searching. http://www.ebay.com/itm/1991-Jeep-Cherokee-Wrangler-Comanche-Shop-Service-Repair-Manual-Book-Set-BU-/380689326294?pt=Motors_Manuals_Literature&hash=item58a2da20d6&vxp=mtr -
These hard copy factory service manuals are exactly what you need, but those prices are crazy. If you are not in a hurry keep searching Ebay and you will find a much better deal. -
Who said anything about impossible? You need new HO brackets, belt, regulator, and ND alternator. Cheaper and easier to bolt on a built-up Delco.
Hard to do in a Renix..........
What Parts Do I Need To Swap To An Electric Fan?
HOrnbrod replied to Roggesound's topic in MJ Tech: Modification and Repairs
http://comancheclub.com/topic/7895-dual-oem-aux-fan-installation/?hl=fan -
Ssbc Or Willwood Or.... Proportioning Valve
HOrnbrod replied to skidoo_j's topic in MJ Tech: Modification and Repairs
both the Willwood and the SSBC have pressure switches to control brake lights... I guess if I mess up on the flat spot during the dual conversion I have a back up option. Good point. -
On the SSBC block, is that a pressure switch for brake lights? That would be an extra expense since I can't see any use for it. I'd opt for the Wilwood since it's a proven product for less $$. -
It sounds like you're the joke. lol!
Very splendiferous Bo. Nice chrome touches too. :cheers:
Intermittent Wiper Module & Headlight Delay
HOrnbrod replied to Keyav8r's topic in MJ Tech: Modification and Repairs
Sounds like you have the right stalk, but it's the multifunction switch in the column that the stalk operates that matters. The harness on the MF (multifunction, not what you're thinking :yes: ) switch has an additional two wires for the intermittent function. Plus the switch for tilt and non-tilt columns are different too. Anyhow, you'll need the wiper module anyway. Stick it in there and hopefully it'll work for you. If not, prepare for digging into the column to change the MF switch. And that was a MF for me, and this time I don't mean multifunction. Take a peek at the bottom of your steering column and count the wires terminating in the flat connector that plugs into the wiper delay module. There should be seven wires if it's an intermittent MF switch.
