Everything posted by Me&my86MJ
Got some more goodies for the manche, blistiens remote resivors up front and monotubes rear. Also did k&n cold air intake system, and xprite leds for some fogs.
Hmmm, well both sides are working kinda sorta, driver side just seems to be super weak. I have already checked to make sure both pods illuminate when 12v is supplied and they did to same or similar brightness. Issue only happened once I extended/added wire from passenger side and it happens to be a lot larger gauge like 10 or 8 gauge compared to 18 gauge pods have.
Made brackets and painted them so I could install AUX lights, managed to reuse old AUX switch pannel for new floating switch. It seems when I made passenger side wiring longer and with larger gauge wire to meet power wire from switch it is now receiving 99% of power making driver side aux light look unpowered(if you look real close you can barely see a faint bit of illumination). I am going to rewire making harness look identical side to side, if anyone has had similar issues happen or can confirm that is or is most likely the issue, I would like to thank you in advance.
2.8l GM Rebuild I did in engine repair class
Me&my86MJ replied to Me&my86MJ's topic in Member Projects: Other Cool Stuff
Thank you -
Some videos from that news meet and drive. Definitely need some more of these trips!
Oh ok, but why not(curious)? Seems like they 3-D print almost everything.
Could 3D printing be an option?
Well hopelessly stuck looks a lot cooler then getting stuck before you even fully enter a pit.lol. Looks like you had a great time too.
Well 802 has some deep holes, didn't even manage to touch the bottom of this one as my front axle high centered the instant I entered it. Not sure lockers would have helped forward progress like that either, definitely could have helped trying to reverse out of it. Lucky I had some new friends with to help with a little pull backwards.
It did very well, no rubbing, or extra noises. My 2.5l struggles going up hills at highway speeds but has no issues at lower offroading speeds whatsoever. Also was able to make my way into play area over filter places at opening of it and had a ton of fun in there. Even got to watch a full size blazer get stuck and almost tip over.
Sometimes it's the littlest things that make the bigger/biggest things work. Had to cut the front fenders and add a little lift and bump for new tires.
Dang, would have been awesome to see another member and your awesome comanche. I believe that I was the only person with a comanche that day too. Yeah I knew that I was going to need some bumpstops or a trim or more lift or all of the above but I just could not resist taking down the trails. So I decided to correct/fix problem from all three areas with a little bumpstops, little coil spacer, and some fender triming
Opps,Oops, guess I should put one of those seizure warnings somewhere, probably be good near the end😂. Thank you mjeff. -
I managed to make it to 4xNation's May the Forest be with you clean up, got the comanche to there and back home with some mild fender carnages from tire rub, pulled apart and dropped my exhaust, and power steering decided to leak out of soft line.
Looking for victi....errr worthy canidates!!
Me&my86MJ replied to whowey's topic in Comanche of the Month (MJOTM)
Never ever, no matter how much changes we make, we never ever forget where we started/ came from -
Pete I think I found a worthy candidate for Comanche of the Month! Wish I knew who it belongs too. Definitely one BA comanche. -
1988 "lowmanche"
Me&my86MJ replied to Awinski's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Looks good -
Bored throttle bodies
Me&my86MJ replied to MeanLemons's topic in Vendors- members making products for MJs
My zip is 97023, how much you think it would cost to ship? I would definitely be interested to help you and see if and what is capable. -
What are your capabilities for 86 TB, I know they are hard to come by as that is what I have and also have spare. I would be interested in hearing more, I will read entire thread as well, and hopefully we can help one another. Edit: thread reads looks like you are still working out earlier 2.5 TBs, have you received any cores to practice/experiment with yet? -
I just got email coupons for harbor freight 34.99 for 6 tons jack stands(pair) but max height is only 23 3/4 inches. So those might not be the solution for you.
I set torque wrench to 105 for alloys rims and 85 to 100 for steel. Never used compounds on threads but do wire brushes them of dirt and debris it they look to need it. Only time I have ever had a problem is using stock steel ford rims on my jeep, they welded themselves to drums in rear and they just never seemed to stay tight.
