27
Everything posted by Eagle
Bleeding brakes - what am I forgetting?
Eagle replied to JefCooks's topic in MJ Tech: Modification and Repairs
Link (scroll down to the post by gogmorgo):
Actualy, if you go by historical posts it seems like more people are looking for the larger diameter ZJ sway bars than are choosing to delete the sway bar.
You guys do spectacular videos. Thank you so much for posting that. And I really admire the way you have your Comanche finished out. IMHO, that's the way I like to see a Comanche being used.
Not safe without a sway bar. Auto manufacturers don't put anything on if they don't think it's needed. Years ago, one of the original members of NAXJA rolled and totaled his XJ a block from his house because he was running on the street with no sway bar. He was in his own neighborhood, swerved sharply to avoid a dog in the road ... and that was all she wrote.
It will work, but it's a bit small. 800 ml is 8/10 of a quart. You need to start with some coolant in the catch container when cold, and then have enough free volume to contain the expansion from the radiator. I would look for something that holds around 2 quarts. This one appears to be made for the purpose, but they don't list the capacity: https://www.amazon.com/SPEEDWOW-Radiator-Overflow-Expansion-Aluminum/dp/B086D291F6/ref=pd_bxgy_vft_med_img_sccl_1/147-6051651-8154946?pd_rd_w=SYWw0&content-id=amzn1.sym.26a5c67f-1a30-486b-bb90-b523ad38d5a0&pf_rd_p=26a5c67f-1a30-486b-bb90-b523ad38d5a0&pf_rd_r=0W91DJR7YR1S62AGFDY5&pd_rd_wg=eWT2P&pd_rd_r=ea0c73e5-7374-4ff3-812a-49a0739fbd1c&pd_rd_i=B086D291F6&th=1
They are filming a movie somewhere in New England with comanches....(maybe)
Eagle replied to strictlyxjs's topic in The Pub
I would love to know where the video was taken. I've driven every mile of every interstate highway in Connecticut multiple times, but that was so grainy and so short that I couldn't even guess where it might have been shot. The MJs may be similar, but the wheels were different. That suggests that at least one will be a throw-away. -
Leaf spring shackles flipping forward
Eagle replied to CO MJ's topic in MJ Tech: Modification and Repairs
In a world of constant change, it's comforting to find one thing that never changes. -
Toyota drank the IFS Kool-Aid a long time ago. The Land Crusher, which I once admired greatly, used to be solid axle on both ends. Somewhere in the late 1990s they went to independent suspension and haven't looked back.
help Fuel issue driving me nuts, please help
Eagle replied to shortee1fourtee's topic in MJ Tech: Modification and Repairs
A whistle usually indicates a vacuum leak. -
If I remember correctly, glyphosate is Roundup, which has been shown to be carcinogenic. I have tried vinegar, without much success. However, it appears that I was using it wrong. I was spraying it on the leaves, and I have since read that the way to use vinegar is to add salt to it and soak the roots of the plants. That's on my agenda for this summer. The problem is that poison ivy is still poison ivy, even when dead. you'll still need to wear heavy rubber goves when handling it. DO NOT burn it. The smoke carries the toxin into the lungs.
Coker has been around forever, and I've never heard anything bad about them. I haven't bought from them myself, but I wouldn't hesitate to do so if I needed classic tires for a classic car.
I have no idea what you're talking about. I've never seen a car with a "little dryer duct" from the exhaust manifold to the carburetor.
Before we had throttle body injection, we had those old things called "carburetors." I don't think I can count how many cars I've owned with carburetors, and that's not including the other cars my parents and grandparents owned. Like throttle body injection, the fuel mixes with the air in the carburetor and they travel together through the intake manifold. I've never heard of a carbureted car or truck that had a heated intake manifold.
Why not just pop off the stainless trim, re-seal the glass, and reinstall the trim? If it doesn't work, you can always have the windshield replaced later. If it does work, you saved $390 ($400 less the price of a tube of RTV).
alternator Alternator Replacement/Upgrade 1988
Eagle replied to USFSOFFICIAL's topic in MJ Tech: Modification and Repairs
The "old style" alternator is the same Delco style that was used in hundreds of thousands of GM cars and trucks for decades. It's difficult to believe you have trouble finding one. -
Problem: You have found a [mostly] intact Comanche that you want to buy and fix and put on the road, but the seller doesn't have a title. Solution:
Fast forward to 22:34
The first tube from the source I provided a link to, the 2-1/2" x 2-1/2" x .238" wall tubing that has an inside dimension of 2.024", is listed as "telescoping" tubing and they say it has a smooth interior (probably DOM). I think that's the stuff for receivers. Or, as gogmorgo said, just buy the right thing per-made. Harbor Fright has it, in 12" and 18" lengths. https://www.harborfreight.com/class-iii-12-in-x-2-in-standard-receiver-tube-69879.html?_br_psugg_q=hitch+receiver+tube https://www.harborfreight.com/class-iii-18-in-x-2-in-standard-receiver-tube-69815.html?_br_psugg_q=hitch+receiver+tube
As to the receiver tubing -- it's not rocket science. Steel tubing is specified by the outside diameter and wall thickness, so the hitch part is 2" x 2". Here's the first vendor of steel tubing I found on-line. They sell 2-1/2" x 2-1/2" x .238" wall tubing that has an inside dimension of 2.024". You can't get much better than that. They also sell 2-1/2" x 2-1/2" x 3/16" wall. That would leave the inside dimension 2.125 (2-1/8"). Below the 3/16" wall the wall thickness is in gauge rather than fractions of an inch. https://www.metalsdepot.com/steel-products/steel-square-tube
Substitute? Looking at the images, I don't see any receiver tube at all, just a knockout for where the tube would go if you choose to install it. They offer a shop-welded rear bumper for the XJ -- for almost $900. It includes a 2" receiver, they have a disclaimer that towing is at the user's own risk -- and they don't provide any specs on the tubing used for the receiver. As for us MJ people -- they want us to pay $340 for a do-it-yourself kit in which the pieces aren't even bent to shape. The instructions call for clamping the pieces to a table and then bending then to specified angles -- after which we get to do our own welding. Thanks, but no thanks.
Advice on gaining more horsepower on the 4.0
I'm tempted to ask why you want to throw money away in search of more power if money is tight, but that's your call. However, I WILL ask what you mean by "power." Look at a torque/horsepower graph for any internal combustion gasoline engine, and you'll see that the torque curve usually has a peak somewhere around 2500 to 3500 RPM, after which it flattens or starts to fall off. The horsepower curve, on the other hand, keeps climbing right up to redline. So the simple answer is to run the engine at higher RPM (which means either gears, or don't use overdrive) if you want more power. But most of us don't want to drive around at 5,000 RPM on the freeway. It's noisy, and it wears out the engine pretty quickly. When most people ask about power, what they really mean is that they want better acceleration and low- to mid-range performance. What are you hoping to accomplish? -
If you stiffen up the front sway bar (larger diameter) and do nothing in the rear, you increase understeer (plowing). If you install a rear sway bar and don't run a front sway bar, you get oversteer (probably -- or at least a lot less understeer). What you're looking for, ideally, is a balance between the front and the rear anti-sway control so that under most conditions you don't get either massive oversteer or massive understeer. I believe the auto manufacturers prefer to build in a little understeer, because they think people can handle that better than oversteer -- and they're probably right. Personally, I prefer just a bit of oversteer under throttle, and neutral steer when coasting.
Look for a sway bar out of a ZJ V8 -- ideally, the 5.9L V8.
