mj_lover69
mj_lover69's Achievements
  1. I purchase the aluminum reservoir from macs radiator and before I install it I would prefer not to run it closed since the tank give you the option. should one of these little things off of amazon be fine? Do I need a bigger one? https://www.amazon.com/BLACKHORSE-RACING-Universal-Radiator-Reservoir-Heatsinks/dp/B07KR38757/ref=sr_1_4?crid=BZTXH7GVBXRF&keywords=cooling%2Boverflow&qid=1682816074&sprefix=coooling%2Boverflo%2Caps%2C137&sr=8-4&th=1
  2. well I already have a napa injector coming tomorrow I had planned on replacing it before the problem even started, am a little confused on how to check the fuel pump circuit even with your explanation maybe I'm just dumb lol.. is there a wiring diagram available somewhere? I am sure there is one somewhere but a simple google search did not suffice
  3. cps was the first thing I checked seems to be in working order, I have done all the grounds except for the fuel pump one behind the taillight even added the 2 grounds as well ill check the fuel pump circuit sometime before tomorrow I did not clean the CPS
  4. its an 86 ill check it out
  5. dies on startup right away if I don't give it any gas and if it does not die it runs roughish for bit until it evens out, was wondering if anyone had any ideas on what it could be to give me a head start
