pingpong
Everything posted by pingpong
  1. Do a search on the net... I know there is a class of racing for 4 cyl at the local dirt track, so I am sure there are plenty of ways to get some serious power out of them. Keep in mind the 2.5 has been sold for yrs... and came in just about every configuration possible.... I even had one in a Fiero... that car was way fast even though all it had was a 4 popper
  2. BY cut off I mean engine stops running, then I pop the clutch and she starts right back up. So far it seems that it could be either the IAC, or he fuel pump.... at least that is what I kinda figured before too, just don't want to through parts at a problem if I am not sure what it is. Time to go buy a new tool .... fuel pressure tester :D
  3. Well I have beat my head against the wall trying to figure this out. Ride is a 90 my with 2.5 and a 4 spd the issue is it will just cut off while driving. so far it has only happened when I let off the gas, but she runs fine at idle, so far I have done an ignition tune up. I really don't know much about the rig, but It appears to have had the intake and head off, for what reason I do not know. She does burn oil ( know this by she smokes a lil, and has a anti fouling plug thing on it) any help would be appreciated... the wife likes this ride, and if I don't figure it out soon.. I will be selling it
  4. who needs shocks :brows:
  5. Yeah I am still kicking. Totally swamped at work. Transfered to a different dept though.. now I unload trucks all day :nuts: The money I have been making is going to upgrade/improve my house.. Pong is on hold til I fnd an industrial junk yard I can raid for parts :brows: I did buy a sweet lil 90 SWB with a 2.5 and a 4 spd... but I am still trying to diagnose a problem with it. It just cuts off when driving :eek: Yeah jeff came by and got a basically complete renix 4.0 I had stashed in the back of my garage... don't know why I had the complete motor and frame mounts back there... but it was there :oops: Hopefully I will get more time to check in once in a while... but burning the candle at both ends is getting me ahead a lil
  6. 1.5 hours south of Richmond... and 2hrs north of Norfolk. In middlesex VA
  7. pingpong
    Online game
    what do you mean? I never had one to begin with :nuts:
  8. Whats the question.. timing a motor.. is timing a motor.. now if it is ford specific.. then that is different
  9. He is on here.. I think his screen name is Hell Creek
  10. Thats awesome... I got one of the lower end vehicle GPS systems for my rig... and love it. Yeah it don't have all the bells and whistles like the higher units, but works great. If I had a lap top... I would have did what you did :oops:
  11. pingpong
    Online game
    OK some of you have sent me your will.. more will be appreciated.... game ID no is 7426
  12. I just got a lead on a local recycler that has 6 mj's sitting in his yard.. I shall go and look into these shortly (mon or tues) from the pics a friend sent me... they look good
  13. This is kinda a trick question... You can fit 31's with no lift.. just remember not all tires are the size they say they are. As for rubbing... anything bigger then stock is going to rub at full stuff and hard turning unless you adjust your steering stops. I have fit 33's on 2" but had almost no up travel.. then again I fit a set of 31's on a XJ with no lift/ trimming tires were more like a tall 30"
  14. I wouldnt... it will seal in moisture. Personally.. I would remove all the bad metal and make a patch panel... Use sheetmetal screws to fasten said panel in.. then find a "jeeping" buddy with a flux core welder.. and have him weld. remove one screw.. place a tack.. you wil find you might be able to get help if all the hard work is done
  15. I just heard someone wallet scream... keep the pics coming
  16. I am not sure how the auctual valve works in the rear. I wondered about it.. then I decided it was just easier to do away with it. and only have one brake line to worry about rotting :brows:
  17. The design of where the alt is, makes it prone to the failure you describe. I suppose with a lot of work and research you can find a way to relocate it to the top. Personally I wouldn't buy one of them fancy expensive alternators cause of the design. Find a 140 stock alternator... that has a similar mounting patern.. and swap it out... also get the life time warranty
  18. thats the correct way.. there is an easier way if it is a through away rig.... you can put a seal in the outer part of the vacum disconnect housing. I got the seal number somewhere.
  19. pingpong
    Online game
    For those of you who have signed up and do not play can you please log in and send me all your will bottles they gave out for christmas. I go by the screen name Bugsy_Siegel now since I am in the Mafia
  20. YUP.... she needs a new home.. call a domestic violence hotline.. she has been abused and shown no love in a while
  21. Alternator is going bad. Get what ever one you want.. just make sure it is a NEW one. Also if you get it from advance be prepared to replace often. Remember not to overtighten the sepertine belt as it will cause premature failure, of the bearings in the alt
  22. Sounds like you need a valve job, and rings. New bearings wouldn't hurt. Also verify that you really are only seeing that low oil pressure with a mechanical gauge...
  23. I did a SYE and a new driveshaft, and when I welded on the perches I put the pinion pointed at the t-case output. It all depends on how much money you have to spend on what will work best for you.
  24. Yup and they work like a charm. just make sure you do one tire at a time.. furthest first... then so on and so forth. I needed to different sizes on my rig... fronts were different from the rear. Best to take a bleeder out from the front and rear.. and bring them down to the store. There are 2 possible choices front and rear, and thats if no one changed the parts.
  25. Well I did pretty good this year. Seaon pass to Busch Gardens 100 bucks cash Magellan Maestro 4210 vehicle gps 5 work shirts pair of slippers Gerber multi tool Caballoes jerky making kit Box of jerky seasoning One of them head lamp things Prison break season 2 on DVD And to work Christmas eve and Christmas day at 3x plus a day off later Porbrably the best gift was helping a friend put together one of them wood play sets on Saturday and Sunday. Then watching their little girl walk out and see it Christmas morning.
