Well my buddy acquired a 96 xj. he decided he would part it out because its 2wd and isnt worth all thats needed to be fixed up on it. He asked if i needed any parts so I looked it over and noticed it had the dual diaphragm booster(I'm guessing, its larger than mine) my question is how hard will this be to adapt in my MJ. its an 88. Will i have to change or modify the rod? I know the wj boosters need some clearance on the firewall. What about the lines going to the proportioning valve? will they bolt up or will I have to bend some new lines.
Also the jeep is equipped with an electric fan, will this bolt into my mj? i will wire it on a toggle switch so I am not worried about the wiring
thanks for the help guys
3/4 tons will be a good idea, some things to consider, does the axle drop on the right side? do you have the know how to swap the axles and make all the brackets line up? are you willing to clearance the floors for the new trans and t-case? are you up to the challenge of putting the 350 in? A few have done it in the past and the biggest issue is trying to keep it cool
If i were you, I would drop the truck down to 5 or 6 inches of lift and run 33s or 35s. It will be alot better on the road and trail. allso with 33s and maybe 35s you could keep your front dana 30 and swap in an 8.8 from an explorer or an 8.25 from a cherokee and be good to go. just another option for you to think about
He means put a socket on the crank and turn it. Its on the front of your motor, on the harmonic balancer. pull the spark plugs to make it easier to turn.
Go ahead and repost your questions in the technical section so you will get more views and answers.
truck looks good, pretty tall though. Is this going to be your daily driver? also do you know what gears are in the axles?
:wrench:
:no: slap you? what for!?!?!?! you are doing what is right :D sounds like you got a good score. and those old cjs are fun. My buddy had an early 5 we played with for a while but he got rid of it... wish he hadnt
well my friend got the cj stuck in the pond, so i pulled him out, ill try and get the video. then i had to give it a try. drove through the water pretty good... had it half way up my door at one point, then i got her stuck in the muck
he is a member on here.... there are a few other threads floating around about those, its pretty cool. I was on another full size chevy forum and someone mentioned getting a comanche magnet :D :wrench:
you are in my territory... and you are going back to my familys old stomping grounds (youngstown area).... werid. Tommy mclean is a mechanic in clover, about the only one i can think of at the moment
