88_mj
    Dickson, TN
88_mj's Achievements
  1. Engine and tranny are in. Crossmember lacks an inch to bolt up. Has anyone ran into this? It's an inch behind the rear most set of holes in the frame. I'm just curious before I fab a new crossmember.
  2. Good news is I'm now working again!!!!! Bad news is, it's 7 days a week. Progress will suffer for now but money is rolling in..
  3. Nabbed a couple of HP 44's at the LJY. That's for later.
  4. You cut the XJ perfect for making a 4door MJ. Looking good so far :thumbsup: I'll be watching your build.
  5. Looks good in the photo. As long as the left side looks as good, I would say you will be fine. RHD will be cool.
  6. Dash guts mounted up B pillar ready for new style latch '99 pump in '88 unit
  7. So I'm two weeks into the swap. Things are going smooth so far. I will have some pics soon. I have the dash mounted and the wiring harness in. I started mounting the'99 fuel pump to the '88 pickup unit. (will show how in pics) :wrench:
  8. Thanks man, I have to say, you have one sweet rig.
  9. Now that is dedication :bowdown: Kudos for resurrecting her. :popcorn:
  10. Thanks, I plan on bypassing the Neutral safety. I will also lose the 4WD indicator light(91 xfr case). Not a big deal. If it bothers me down the road, a micro switch on the shifter will fix that. I'm at the point in the build now where I have to make a bunch of changes to do any one change. Being unemployed gives me plenty of time as long as I can keep it cheap. This is what I have. My currently running 88 short block. '91 HO head, already ported and valves ground. '99 intake and injectors. '99 full wiring harness, short the headliner stuff. someone beat me to that. '99 fenders and doors. AX/15 w/ internal slave. (hey it was free and freshly rebuilt) funny story on that. I picked up a '91 HO engine/tranny and xfr. It had started knocking shortly after it was rebuilt. :hmm: Can't complain about free..... After removal of the oil pan the problem was apparent. :doh: a little blue shop towel sucked up in the pickup. Needless to say the crank and rod bearings are shot. Half of the rod caps were on backwards anyways so at least I got a head and barely run .060" over pistons out of the deal. Job hunting this week so progress will be slow.
  11. Converted to the hand brake and got the XJ carpet installed. Built a much more sturdy rear console mount while I was at it.
  12. 88_mj
    Roll Call!
    Robert Harrington Dickson, TN 88 4WD short box pioneer.
  13. A little progress over the weekend. Used the XJ for a patch panel Much better :yes: I also got the xj seat brackets welded in and the seats mounted.
  14. Ok... So the XJ is an auto. Is the ECM going to be happy without the auto tranny connected? I can't bring myself to go auto. I know I will have to tap the neutral safety switch. What else am I going to run into?
  15. Nice find. I'm noticing a 97up 5 speed is hard to find. At least in my area.
