  • Replies 897
Mike to some really good photos.  I wish my truck had been ready so I could have gone with you.  Yellow Jacket hill looked like it would be pretty tough with all that mud making the rocks so slick.  How did the ARB's work are you loving them?
Ron
Ron
I would not have made it up Yellow Jacket Hill without them.   :D
Willy
  • 4 weeks later...
The original shift linkage I created for the two transfer cases utilized the stock bushings on each end.  They held up fairly well over the years but have caused some problems at times by popping out of the shift levers.  I decided to replace them with some rod ends that should eliminate that problem.
Old linkage on the left.
Willy
Returned to Copper Creek Road Saturday to play in the snow.  The tow straps and winches were well used by the end of the day.
One rig broke a motor mount which resulted in the engine shifting enough to put a hole in the oil filter.
Duct tape to the rescue.
More pics here.
Willy
  • 3 weeks later...
Back to some cage work.  I added some down bars.
Gussets at the main hoop.
As well as a couple of short pieces connecting to the main hoop on the inside of the down bars.
Some gussets for the rear.  The holes should make a convenient place to attach tie down straps.  It seems like I can never have too many of those.
I'll also add a mount for the CO2 tank and Hi-Lift.
Willy
  • 3 weeks later...
did you keep track of how much tube you used for your cage?  or do you have a rough guess?
Wade,
Sorry about the late response.  I didn't completely forget about this....except when I was in the garage with my notes.  I originally purchased 4 tubes that were approximately 20' long.  I do remember going back for another tube because some of our first attempts didn't turn out so well.  Hope this helps.
Willy
thank you.  i bought 80'.  based off my extremely rough measurements, i needed 71'.  i know i will need to do a few test bends.
Are you planning on going with the same style cage we built?
Willy
How do the bars that go down the windshield pillars into the fenders mount?
They bolt to these plates that are welded to the unibody just in front of the door hinges.
Willy
Willy
 maybe not exactly the same, but probably similar.  i will be tying mine into the rock rails.
Willy
Nice!  I look forward to seeing what you do.
Willy
Willy
Willy
me too haha.  this will be my first attempt at bending up a cage.  been reading a lot about tips on bending tube.
