mjfreak Posted April 11 Posted April 11 I searched and didn't see anything like what I've got going on....my blinkers work perfectly....and then nothing....I've pulled fuse block apart and cleaned it....added all the suggested grounds, updated front bulb sockets to 97+, rear is a flatbed with led lights. When they stop working, I wiggle all the wires under dash with no change......then just randomly they work again....when they aren't working i have found that the purple wire on the multi function swith will be blinking with test light but blinkers aren't working....if i had hair I would be pulling it out. Open to suggestionsÂ
Pete M Posted April 11 Posted April 11 could be a loose or corroded connection in the wiring or in the multi-function stalk. those suck to have to track down.   did this happen before the LEDs were installed? Â
mjfreak Posted April 11 Author Posted April 11 Before and after....nothing I have done caused or helped situationÂ
Eagle_SX4 Posted April 11 Posted April 11 The most common issue with the blinkers is the front bulb sockets themselves. They get corroded and cause all sorts of strange issues. The only fix is to cut the old ones off and wire new ones in.
mjfreak Posted April 11 Author Posted April 11 10 hours ago, Eagle_SX4 said: The most common issue with the blinkers is the front bulb sockets themselves. They get corroded and cause all sorts of strange issues. The only fix is to cut the old ones off and wire new ones in. Been done when I upgraded to 97+ front clip.....
mjfreak Posted April 11 Author Posted April 11 Something else I noticed today. When blinkers are in FU mode.....and if hit brakes...both blinker indicators on dash light up solid......
watchamakalit Posted April 12 Posted April 12 Check your hazard switch in the column. I know mine can occasionally get bumped to the point its almost half engaged and causes my signals to do goofy stuff. I just pull it or push it (I don't remember which way is off ) and all is right again
mjfreak Posted April 12 Author Posted April 12 17 hours ago, Pete M said: ground loss somewhere? Thats what I'm leaning towards but not sure where to start.....guess with front blinker socket as they were used....not sure if the 97+ were known to have issues but I've watched a few videos whith identical problem and front blinker sockets fixed it....
Pete M Posted April 12 Posted April 12 make sure the little tab in the bottom of the socket isn't squashed flat and failing to make contact.
Eagle_SX4 Posted April 12 Posted April 12 Have you tried swapping the turn signal and hazard flashers yet?
ghetdjc320 Posted April 14 Posted April 14 On 4/11/2026 at 6:26 PM, mjfreak said: Something else I noticed today. When blinkers are in FU mode.....and if hit brakes...both blinker indicators on dash light up solid...... This tidbit is important. The most likely cause is a bad bulb or socket. You’ve got a short in the system. Look for a bad filament in the bulb or socket issue. Even though you swapped the front clip it’s still very common.Â
AnotherOldJeepGuy Posted April 14 Posted April 14 I'll throw this in because it worked for me. When I was having some turn sig issues maybe as much as 10y back, I installed 2057 bulbs in the rear even though the manual calls for 1156 in the rear and 2057 in the front. The gremlins went away and they all worked correctly after doing this and have continued to do so. I don't know what the difference in the bulbs really is, or why I even tried this, but regardless it was successful.
mjfreak Posted April 20 Author Posted April 20 I have 97+ fronts and leds in flatbed. Making these upgrades didn't change anything....I feel its in fuse block....I'm going to try to bypass with inline fuse if I can find correct wires
ghetdjc320 Posted April 22 Posted April 22 On 4/20/2026 at 11:51 AM, mjfreak said: I have 97+ fronts and leds in flatbed. Making these upgrades didn't change anything....I feel its in fuse block....I'm going to try to bypass with inline fuse if I can find correct wires The fuse block only provides power and contains the flashers. The turn signal switch itself may be the issue.Â
mjfreak Posted April 22 Author Posted April 22 8 minutes ago, ghetdjc320 said: The fuse block only provides power and contains the flashers. The turn signal switch itself may be the issue. The reason I was looking at fuse block was because in the beginning it would change from not working to working if I pushed on the fuse block
mjfreak Posted April 22 Author Posted April 22 On 4/20/2026 at 1:00 PM, Ωhm said: Create Signature. Add Yr & Eng info. I'm a bit slow, can't find where to add
ghetdjc320 Posted April 22 Posted April 22 13 minutes ago, mjfreak said: The reason I was looking at fuse block was because in the beginning it would change from not working to working if I pushed on the fuse block If you try the hazard lights, do they flash?
89 MJ Posted April 22 Posted April 22 11 minutes ago, mjfreak said: I'm a bit slow, can't find where to add This thread walks you through it very well
mjfreak Posted April 22 Author Posted April 22 Just now, ghetdjc320 said: If you try the hazard lights, do they flash? When blinkers magically work, hazards do also...when they quit, both does not work and hitting brake pedal makes blinkers light up....
mjfreak Posted April 22 Author Posted April 22 Just now, 89 MJ said: This thread walks you through it very well Just added
ghetdjc320 Posted April 22 Posted April 22 Just now, mjfreak said: When blinkers magically work, hazards do also...when they quit, both does not work and hitting brake pedal makes blinkers light up.... If you pull the brake light fuse, do the blinkers work?Â
mjfreak Posted April 22 Author Posted April 22 1 minute ago, ghetdjc320 said: If you pull the brake light fuse, do the blinkers work? Haven't tried that yet
