mjfreak
Everything posted by mjfreak
  1. Acquired these with a few trucks i bought but I went with a flatbed. $250.00 each pair includes s/h in lower 48
  2. Yeah i took fuse block apart and cleaned it the best I could and pumped it full of dielectric grease.......there's no way I'm tackling putting in a better one lol
  3. I think I found the problem....fingers crossed.....someone suggested pulling brake/hazard fuse to see if thats how it was back feeding......as soon as I touched it things started working.....so I bypassed that circuit and so far everything is working correctly.....so we shall see
  4. When blinkers magically work, hazards do also...when they quit, both does not work and hitting brake pedal makes blinkers light up....
  5. I'm a bit slow, can't find where to add
  6. The reason I was looking at fuse block was because in the beginning it would change from not working to working if I pushed on the fuse block
  7. I have 97+ fronts and leds in flatbed. Making these upgrades didn't change anything....I feel its in fuse block....I'm going to try to bypass with inline fuse if I can find correct wires
  8. I will be addressing the front sockets tonight
  9. Thats what I'm leaning towards but not sure where to start.....guess with front blinker socket as they were used....not sure if the 97+ were known to have issues but I've watched a few videos whith identical problem and front blinker sockets fixed it....
  10. Something else I noticed today. When blinkers are in FU mode.....and if hit brakes...both blinker indicators on dash light up solid......
  11. Been done when I upgraded to 97+ front clip.....
  12. Before and after....nothing I have done caused or helped situation
  13. I searched and didn't see anything like what I've got going on....my blinkers work perfectly....and then nothing....I've pulled fuse block apart and cleaned it....added all the suggested grounds, updated front bulb sockets to 97+, rear is a flatbed with led lights. When they stop working, I wiggle all the wires under dash with no change......then just randomly they work again....when they aren't working i have found that the purple wire on the multi function swith will be blinking with test light but blinkers aren't working....if i had hair I would be pulling it out. Open to suggestions
