Ξ©hm Posted 2 hours ago Share Posted 2 hours ago On 4/10/2026 at 9:09 PM, mjfreak said: when they aren't working i have found that the purple wire on the multi function swith will be blinking with test light but blinkers aren't working....if i had hair I would be pulling it out. Β If your testlight was on pin C156_K, this would be normal and a testlight would blink. Try same hookup but instead use C156_L with KEY ON. Should make testlight blink. Β Link to comment Share on other sites More sharing options...
mjfreak Posted 1 hour ago Author Share Posted 1 hour ago I think I found the problem....fingers crossed.....someone suggested pulling brake/hazard fuse to see if thats how it was back feeding......as soon as I touched it things started working.....so I bypassed that circuit and so far everything is working correctly.....so we shall see Link to comment Share on other sites More sharing options...
