6000 miles in an MJ
GonzoTheGreat
Ok, it's time for a quick update. The MJ is still safely stored in Costa Rica, but the girlfriend and I are on a brief sojourn in Europe, and since this forum loves amc/chrysler oddities, I thought Id show everybody what we've got.
She was impressed with the Comanche's performance on our trip, and decided she had to have an XJ at home in Italy. So, we found a '96 XJ with the 2.5L VM Motori Turbo Diesel, AX-15, NP231, dana 30/35 with limited slip rear.
It needed a lot of work, which I will detail here.
The ultimate goal is to drive from Turin to Palermo, with many stops in between, and return it to her parents house before heading back to Central America.
The above picture was taken in Colonnata, a town famous for marble quarrying and ...marble box-aged pork fat. It was actually delicious.
We also made a pit stop at the world's most famous engineering mistake,
the Lavazza coffee museum,
and the oldest producer of balsamic vinegar.
I'll probably post one or two times more from this continent depending on what we see.
And don't worry, the MJ is not forgotten. I'll probably have an update on that come January. :beerchug:
oh and another pic of the XJ, because I know you all want to see it.
  • Replies 92
Always been curious about the 2.5 diesel. How it compares to a 4.0 or 2.5 gasser. Every so often I window shop the 2.5td/ax15 ZJ. Seems to be a few of them cheap in Italy, but I’m a long way from when I’d be able to import anything. Seems everyone in Europe thinks they’re junk but that’s the overall opinion of Jeeps in general there so… yeah.
Out of curiosity does the XJ have headlight height adjustment on the dash? I’m pretty sure it was a euro requirement. Both my Ladas have it, at least, and I’ve seen it on the ZJ but I haven’t found any info about it on the XJ.
The 2.5 has been great so far. Plenty of torque. The only issues I’ve consistently read about are the 4th cylinder head cracking from overheating, and the EGR clogging up the turbo.
The PO had the engine “overhauled” in 2018. I don’t know what that means, and neither did he. He’s a pasta maker, not a mechanic. But he did mention a new water pump, and head gaskets, and I could see the EGR delete. So that was good news.
So far we’ve had no issues, and the exhaust doesn’t have a speck of soot. The crank case breather has an oil trap in-line, but there’s still quite a bit of oil making its way back to the intake, so I’ll have to take a look at that at some point.
and yes! It did come with adjustable headlights. The switch is in the center console. They don’t work after the PO swapped in LED headlights, but I may be able to resurrect them. There is a servo that hangs off the bottom of the header panel under each light bucket with an arm that attaches to the bucket. I’ll try to get pics when I take it apart. We nabbed some original glass lights from a junkyard. They’re very different from the North American sealed beam. There’s a socket inside the glass housing for a replaceable hi/lo light bulb, and a little socket for a daytime running light. I’m not sure if it’s the same for you in Canada. I had a Canadian XJ at one point with daytime running lights, but I never looked into it. Again, I’ll try to get pics of all this when I take it apart.
On 10/13/2024 at 9:22 PM, schardein said:
Very cool.  Interesting that it's a 96 but has the 97-01 rear view mirrors.  I wonder if it's original or an owner upgrade?
This guy “upgraded” a lot of things, but I think the mirrors might have been original. Getting parts here is tricky, new or used, so I’d be surprised if someone put in that much effort.
On 10/13/2024 at 7:31 PM, Salvagedcircuit said:
Aww yeah, this is gonna be good. I wonder if the pizza rims are made in West Germany like the 10 spoke rims another CC member posted a while back. Nuts!
it actually came wearing a set of turbines, which ironically, are all made in the USA. They’re in rough shape, so we stuck with the gamblers. They’re original, at least they match the spare, but the turbines are stashed at her parents house in case I ever want to strip them and make them pretty.
EGRs plugging things up is pretty typical to all diesels, especially if they’re just poking around town in heavy traffic, running cold on short trips with lots of low rpm and idle time.
I think they call those little bulbs in the housings “city lights”. If I understand it correctly they’re for cruising around a well-lit city where you don’t need extra light to see, but need to be seen by traffic without blinding anyone. A “nighttime running light” if you will. The ECE low beam kicks a fair bit of light up and right for reading road signs which can be unpleasant for anyone in eyeshot. I don’t know if the housings with the city lights would have been factory or not, but they’re definitely common. ECE sealed beams were definitely a thing but there’s a very strong preference for H4 housings.
The DRL on North American spec Jeeps from the era is accomplished with a step down module that sends 5V to the high beams, its a little square box on the driver’s side inner fender up by the firewall. It uses the same sealed beams as the non-DRL setup. They like to fail and stick the high beams on. It works alright with OE wattage halogens but doesn’t always play nice with higher powered aftermarket lights, especially LEDs that don’t expect the 5V. I don’t know if the European Jeeps used the same system, or even had daytime running lights at all. I know European cars did have them but I don’t know if it was mandated or just a premium feature.
The Canadian-spec Ladas I have had the DRLs added at the port with a couple relays that turn on some function of the headlights. There’s no documentation about them that I’ve found anywhere and I’ve never bothered decifering how they’re supposed to work. But this is still very early post-Soviet stuff and even today the Russian market isn’t exactly a typical example of European regulation equipment.
But the ‘93 Samara I have has OE molded H4 housings with city lights. The ‘96 Niva has standard 7” round lights. It may have had sealed beams in it when I first got it, but I put some cheap aftermarket H4 housings with blue neon halos shortly after buying it that also had the city lights, also in blue. I had to pull the DRL relays to keep the headlights off so you could see them while driving around town. It looked cool but I don’t know how I didn’t get ever stopped for them. But one of the lenses cracked and I replaced them with some OE H4 assemblies. I don’t remember if they have city lights or not, but they’re for sure much better at being headlights than the cheap ones were.
  • 1 month later...
Ok. Time for another update. 5k km and about 5 weeks of travel, and I've probably gained 5kg from all the food here. :laugh: We drove from Turin to Palermo in a zig-zaggy path, stopping for major tourist locales, and local cuisine. We also made a quick stop in the towns where my great-grandparents were from, and I randomly met a distant cousin. That was pretty cool.
In the end we took a ferry from Palermo to Genoa (22hrs) to return home. Fuel is super pricey, and the highway tolls are insane, so it was actually cheaper to take the ferry. Plus I don't love the sounds coming from the trac lok in the dana 35 lately, so I think it was best not to risk all those highway miles.
I'm 6'2" so in hindsight if I do this again, it's going to be in a 2-door, or at least with 2-door front seats. we bought an Ikea futon mattress that fit perfectly in the back, but I would have fit a lot better if the front seats folded forward.
The only big issue we had was with the rearmost driveshaft U-joint. I somehow missed this until a few hours before the trip started, at which point I had eliminated enough shimmies and wobbles to notice a driveline vibration.
Apparently at some point the PO broke a retaining tab off the rear pinion yoke. His solution was to tack a washer on in its place. Long story short, the tack weld cracked, the caps spread out a little and the u-joint beat itself up. Through some extreme good fortune, I had a u-bolt kit I had bought years ago and never used. I had thrown it in my bag before this trip thinking "I'll never need this, but why not bring it?" The old u-joint looked pretty shiny, so I'm wondering if an old one recently broke while driving, and that's what tore off the retaining tab. The PO seems to be a bit of a meat-head, so that's the theory I'm going with. We got the new u-joint installed, with u-bolts, and a little JB weld where the tab is supposed to be. That did the job.
In other news, we got back to the north, and spent a little time in the lower alps. It was good to get a little dirt (and snow) under the tires.
As some of you may also know, Turin is the "Detroit of Italy," due to the founding and production of FIAT. So of course I had to visit a former factory-turned-shopping center downtown that still maintains the original FIAT test track... on the roof of the factory!
The site is now a garden/sculpture park with a cafe and a small museum. Some benches in the garden had slogans that may or may not be intended to poke fun at FIAT.
And finally, @eaglescout526, as a fellow eagle scout, this really stood out to me. In southern Sicily, in some no-name beach town, there is a plaza/parking lot dedicated to Baden Powell. Totally random. I didn't expect to see that, but I think you might appreciate it as well. :laugh:
And that's a wrap (or a panini?) in Italy. At some point in the next couple months, I'll be back to Costa Rica to pick up the pickup, and continue on with that venture.
Woah!!! That’s really cool!
Having worked with many Italians, it would be a panino.  Panini is the plural, sandwiches.
Absolutely awesome adventure!  I drove from Marseille, France via Nice and onto Genoa, Italy before turning north or Milano last year for work.  The Mediterranean coast was amazing, the blue water like in your one shot was incredible.
Glad you are enjoying Italy.  I couldn’t wait to get out of there.  I was in Sigonella for a month, followed by Napoli for 5 months.  I kept getting the non-Italian speaking discount, among other things….  I enjoyed Italy so much, I started to pronounce Italy with an "Sh" in front of Italy.  I did look at a ‘97+ 2.5TD while I was there.  Seemed to drive okay.  I wouldn’t mind purchasing a 2000 / 2001 2.5TD eventually, from Europe.  I did want to get a few European parts, but between google translate on Marketplace and the prices they wanted for used parts, I found it easier to bring parts in from elsewhere to Italy.
Hahah I’m not surprised. Napoli is an absolutely madhouse. I’ve never seen a dirtier, more chaotic city. And Catania is a close second!
and yeah, the pricing on parts here is absolutely wild. I had a super hard time finding lights. To be fair, the price of a crown export taillight in the states is almost $100, but then people wanted the same money for basically any used part here. You really gotta know what you want.
On that note, I have a pair of oem export tails on their way to the states now. Don’t know what I’m gonna do with them when they get there, but they felt like they were made of gold here, so why not keep ‘em.
you’re totally right. Though maybe pizza portafoglio would have been a better choice of words. :laugh:
2 beers and a folded pizza for €7.50–Best investment of my life.
On 12/3/2024 at 6:19 AM, Salvagedcircuit said:
Excellent update indeed!
So you're saying there's a 2 door XJ in the works :brows:
Ok. So I’m not saying anything, but I’ve sailed with an Australian captain who said I could keep an XJ at his house if I ever find one there..
8 minutes ago, fiatslug87 said:
Is the trip from Costa Rica heading south or north?
Haha, we’ll see. If it means I have to store it somewhere again, I’m really gonna have to think on it. There’s a significant level of anxiety that comes with parking a collectible vehicle in a foreign country for several months. :laugh:
  • 5 months later...
Welllllll, it's time to dig this thread back up. I'm here about 6 months later than planned, but no complaints. After a little bit of work and travel, I was finally able to return to Central America and retrieve the Comanche. Long story short, I'll be staying in Panama for a little while.
Whilst here, I took a bus up from Panama to Costa Rica, and broke the MJ out of importation purgatory. As some have probably seen, it didn't want to start right away. Eleven months parked in the tropical heat and rainy season were not friendly conditions for outdoor storage, but as I still have my "foreign" registration, I didn't have much of a choice on locations. Fortunately it ended up being incredibly cheap to keep it there, and it eventually did start. Notice the plants that had begun to grow up through the engine bay... :brickwall:
On a happy note, when I was looking to find spare parts to get the engine running, I ended up finding a super cool local guy, who owns a shop specializing in older Jeep vehicles. He daily drives a ZJ, but one of his pet projects is none other than a 2.5L 2WD MJ! Gracias Danilo! Siempre Tendras un amigo en los Estados Unidos!
During the 6 hour drive from San Jose down to Panama we made a quick stop around Puerto Viejo and saw the blackest black sand beach I could have imagined.
Then we went on to Sixaola, Costa Rica for the worst border crossing of this trip so far. This is my third consecutive year finding myself in Latin America for Semana Santa (holy week), and you would think I would have learned by now. It's madness. Apparently everyone, and quite literally their mother, is traveling somewhere to celebrate Easter, and the border offices were absolutely swamped. It was about a 6 hour process, consisting of queuing up in various lines, and standing in the sun. Fortunately all my paperwork ducks were in a row, and although there is a silly amount of various fees and taxes to get a vehicle into Panama, I got my Permit, and it was on to Bocas Del Toro. One more ferry ride, as Bocas town is on an island, and we finally arrived!
This has been home base for several weeks now. The Panamanian vehicle permitting is a little bit of a pain. I am granted 30 days, but I can renew twice, so essentially the truck has a total of 90 days allowed within the country.
I was hoping to travel a bit while I have a vehicle here, but things have taken a strange turn politically, and many of the major roads in this country have been blocked by protesters. I still have a fair amount of things to do in Bocas, but when that is over, if the political situation hasn't calmed, we may just head straight back to Costa Rica.
I had also debated shipping the truck to Colombia, around the Darien Gap, and continuing south, and if I had the reliability of a stick shift and 4wd, I probably would, but barring that, I think its best to turn around here and head back to the states. Or at least start heading that way. I just can't imagine having some serious drivetrain issues and being forced to sell or abandon the MJ. Maybe I'll take an XJ next time so it's a little more disposable. :laugh:
Aww yeah, the update of all updates. Always cool to read these man. Good luck with it!
:beerchug:
  • 3 weeks later...
  • 4 weeks later...
Ok. We're back at it. Things were weird for a bit in Bocas del Toro. Public protests evolved into rioting and violence, and eventually a police state developed and everything got a bit nasty. Fortunately we were safe out on the islands. Unfortunately our trip was delayed quite a bit, as the ferry did not run for several weeks, so we were essentially trapped. I can't complain too much about being trapped on a tropical island. While fresh produce became a bit scarce after awhile, everybody was still well-stocked with beer. I continued put my little 2.5 2wd MJ in places it should not be :laugh:
But we had a road trip planned, so the first day the ferry resumed, we jumped ship, and were the first tourists to cross the freshly liberated road out of Bocas province.
We spent a day up in the mountains in Boquete, then on to Panama City. It was nice to see a little civilization for a change. You can find anything you need in Panama, and the public transportation is amazing. We enjoyed a few modern amenities like supermarkets, proper restaurants, and for the first time in my life I was happy to go to a shopping mall. We saw the old city, and visited the canal. I really enjoy this city. I would have liked to have spent a little more time here, as well as everywhere in this country, but time is ticking on the truck's permit, so we had to keep going.
At the end of the first half of the Pan-American Highway is the little village of Yaviza. I had read quite a bit about the Darien gap and all the nasty stuff that happens there, so I was really only interested in going to the end of the road, and coming back. It turns out I was completely wrong. Darien province is amazing. The plants and animals are incredible. Everything is super super green. Everyone we spoke to was incredibly nice. They love their region and are very proud of it. I think it might just be my favorite part of panama.
Not to be neglected: I found TWO other Comanches in Panama. One of them I already put in the registry. The other is a young couple in Bocas with an '89 4.0, 5 speed, 4wd that's lifted on 33s. I urged them to make an account on here, if for nothing else, to add theirs to the registry, but they also had some questions about clutch issues. Hopefully we hear from them soon.
Next up, it's back to Costa Rica, probably in 2 days or so.
And here is a general photo dump:
  • 1 month later...
I'm way past due for an update, so if people are still following along, I'll post some progress.
Costa Rica was good. We crossed at Paso Canoas on the Pan-American Highway and mainly followed the Pacific coast. First stop was Pavones, to see the world's second longest left. I'm still not much of a surfer, but the girlfriend had see some instagram documentary or something about the town, and wanted to see it, so we went. Super chill locals, beautiful nature, and a lot of hippy gringos. Everything was as-advertised. We continued from there up to Uvita, making a quick stop in Golfito, and also a historical site with a lot of big balls. Actually, pre-columbian natives made these giant stone spheres for spiritual/political reasons. It was pretty cool. A banana farmer found them buried under his field. There's now a little museum and a ton of info about the site, and Costa Rica's archaeological history in general.
We saw some cave beaches, a whale-tale shaped beach, black beaches, white beaches public beaches, private beaches, salty beaches, brackish beaches, fresh-water beaches. I was starting to feel an Anakin Skywalker aversion to sand, but then we spent a couple days up in the mountains.
It was sorely needed. I was amazed how much cooler it was, and it was nice to spend a few days not soaked in sweat. If I do something like this again, I'll make sure the vehicle has AC. :slap:
Monte Verde is neat little town. Kind of touristy, which isn't really our speed, but tourists often accompany breweries, which is definitely my speed, and I can highly recommend Monte Verde Brewing co.
I was also constantly reminded how terrible the Costa Rican roads are once you leave the highway. Despite having some of the highest taxes in the region, and being much more "developed" than its northern neighbors, Costa Rica has a pretty deficient ways and means situation. Despite my one-wheel-peel and the automatic, I managed to dodge a few hairy situations. :))
