Custom Gaskets for HVAC
Fitting went well today! Everything other than the evap seal mates up well. I made the end piece of the evap seal a bit too large to poke through the hole, easy fix. The blower motor seal also has a slight gap at the top, may have to add just a bit of thickness to it or perhaps it will close upon tightening the nuts on the firewall studs. Will be cinching that down tomorrow (or the next time when it's not raining) to check and see.
Fills up the gap nicely!
The view from my fresh air intake. That hole the PO cut is at least useful!
PXL_20240527_201848210.jpg.98e160ec91bbb42ffe83f6762d7ba0e2.jpgDefogger attached.
Left side
Right side
Front view
Dash attached
Left side
Underneath
Right side (can't see much)
Evap seal. Couldn't get it to fit with the heater box, shoved it in by itself. Will be trimming to fit this week at work. Besides the outermost piece being too large it fits like a glove.
Blower motor. You can see a bit of a gap above the firewall stud. I'd imagine this will close when the nut is added and tightened. Will be experimenting with that ASAP. If it doesn't close the gap I'll add some more beef to this seal and try again.
Top half of blower motor
  • Replies 99
Made a few more changes and it looks like everything is working as intended!
New evap seal, added an insert for the vacuum grommet
Fits like a glove!
Good on this end as well
After tightening up the nuts on the studs the blower motor seal fit nicely
Also have a gasket on this piece, never mind the rust hole lol
Inside view
Hard to say what a fair price is from the purchaser side. Especially not knowing the amount of time you have invested. I have a feeling you can set your price anywhere you feel comfortable. People will buy or they won't. Good chance you sell several since we are all wanting your product.
Seriously though, definitely cover the costs of the material to make them.  And throw in a reasonable amount to cover your time at least.  Start with that as a baseline and see where you are.  Throw out a price and I bet many people will jump on it.
  • 3 weeks later...
57 minutes ago, H3ADBANG4L1F3 said:
I'm assuming the most recent one I made (reply above) matches your original, yes?
To be clear, this is not original to my 1990; the evaporator is from a later model XJ... But yes, it looks like this
  • 1 month later...
Alright, after working with A-Man a bit I've come to the realization that I'm going to need some test fitters. I'd like to get one from every year of Comanche, and Cherokee too (96 and below). Ideally getting feedback within a month, seals and shipping on me.
Shoot me a PM with your year model(s) if you're interested and I'll choose a random person with each year model. I'll draw the names next Friday, 8/9/2024.
I should clarify. I don't anticipate many issues, though I do want to try and cover all of my bases. I'd like to have feedback roughly by the end of September. The seals are easy to install, removal of the dash is as difficult as it gets.
