Renix and HO bored throttle bodies available!!
I’ve got a Renix one on my Comanche. His website says this:
Quote
A note on Throttle Body finish- Lets face it, these T-Bodies are made from cast zinc and they're used. Their beauty fades quickly after a few years and the Renix units have been on the road for 20 years now.
If you are looking for a shiny showroom finish, I'm notgoing to have what you need. You can order one powder coated or send me one to bore but, I cannot promise a fancy finish otherwise.
This was not my experience at all. Mine came back looking like a brand new throttle body. Cannot recommend it enough!
I held off on buying one for over a year because I was worried about the finish.
Old TB:
IMG_2853.jpeg.b3b6d20d23737b886e27b1349a5d6cc4.jpegIMG_2854.jpeg.ae113635a34818c9abc5e96ea7b68beb.jpeg
New bored TB:
IMG_2773.jpeg.0d2cf7779971f43dd45abf9bc7327d91.jpegIMG_2852.jpeg.71d3628577ea5f6e72667b120dc595c4.jpeg
Old TB:
New bored TB:
Did you notice a difference in performance or throttle tip in from the larger bore?
HO myth buster
Renix in 90 made 182 HP. HO in 91 made 190 HP. That's 8 HP difference.
HO only made more HP than Renix at higher RPMs and not a bit more torque. HO had a 58 mm throttle body versus a 52 mm throttle body on a Renix. That’s 20% more air available through the HO throttle body. The HO also had a better design header. See where I'm going with this?
It’s only a 4% horsepower increase…..
The whole 8HP was not mostly from the head, but from the bigger TB and better exhaust manifold.
Put a 60mm TB from www.strokedjeep.com on your present manifold using the Renix head, eliminate the "crush" in your headpipe with proper re-routing, and go for it.
HO stands for Highly Overrated.
__________________
To be completely honest, I can not tell you for sure. There is a noticeable power difference with the bored TB, but I also did a high altitude CPS at the same time, which advances the ignition timing. Together they both made a difference in power and fuel economy.
Here is what I can tell you:
I gained about 1.5 mpg per tank, tested over a few tanks of gas. My truck accelerates much better now and cruises at highway speeds much easier. I can't tell you which one made the larger difference. I can't even for sure tell you that the difference didn't come from just having a clean throttle body, but I'd recommend it. At the end of the day, it is not a very expensive upgrade, even if it doesn't make much difference.
1 hour ago, TurboedMJ said:
This may be a dumb question, but I have an HO head, would I need bigger injectors if I switched to the 70mm tb from newcomer racing?
No, very unlikely, you tend to need a lot of work to improve airflow enough on an NA engine to need larger injectors.
2 hours ago, cruiser54 said:
HO myth buster
__________________
I was figuring that would be the answer.  For the money I think I'd rather purchase a nice Banks header.  My first Comanche had one, I believe the only engine mod it had, and it ran much stronger than my current one.
I've done the CPS mod to make it like a high altitude one, that definitely helped mine.  I haven't seen a noticeable increase in fuel economy, but I don't drive consistently enough to really catch that.
3 hours ago, cruiser54 said:
HO myth buster
Chiming in here on behalf of all past and present HO owners:
Quote
HO Is better because blah blah blah :wink:
I've been eyeing a bored throttle body and doing the IAT relocation, but I need to grab a spare throttle body first before having it bored. I don't want to have my vehicle down for a bit. I'd also love to record some data from my renix monitor before and after the swap to see if I can quantify the difference.
If I can push 200hp 200 ft-lbs and 25mpg, that's goals right there! :bowdown:
On 10/30/2023 at 6:04 AM, cruiser54 said:
HO myth buster
__________________
Bashing on our mopars again :laugh: :sad2:
I've removed the restriction on a few HO TBs. I also clean up the inlets cast taper. I put a taper on the outlet side too. So a 60mm bore.  I can't say how much HP a bore TB gets. I have noticed that I do much better on the hills on WV. Also, running a ceramic coated header and the Horseshoe (2000+) intake. I gave a few to a guy who does work on my Jeeps. He seems to like them. I can't find my RENIX TB to bore out. I remember a guy in Florida, Bell that would bore them to 60mm. Said 1 in 4 or 5 he had to scrap. Porosity in the casting.
  • 3 weeks later...
  • 2 months later...
I have received my 60mm throttle body from Jeff. I can't comment on performance yet as the Jeep is going to be idle for some time due to the interior being redone with new floor pans. I am very pleased with how clean the workmanship is on these TBs.  I do have one Q, however: With the upgraded TB, an instruction to adjust the TPS was issued.
What is the logic behind adjusting the TPS and is it 100% necessary? I do plan to follow through with it but I am also asking in case someone else has the same questions going forward.
