Hi all, I recently picked up an 89 renix 4.0 4x4 MJ and it's running pretty consistently at about 250. It was originally closed cooling, but I accidentally popped the pressure bottle and decided to go ahead and just swap over to the open system with a new radiator and overflow bottle. I removed the heater control valve as well. So, fortunately I don't have to futz around with the closed system, but I'm still running just as hot. Here's everything I've tried so far:
I flushed the originally coolant, which was not particularly cruddy looking, but figured that was a good starting point. I think I did a pretty good job cleaning out the engine and the heater core. I've since ran a few changes of cleaner fluid and distilled water through it.
I replaced what looked like the original thermostat with a new stat. I boiled both of them and they appeared to open at 195 as intended.
I have checked my gauge and read the sensor with an IR thermometer and I believe them to be working and reading correctly.
I have checked my fan clutch and it seems to be in great condition as well as the blades and my ducts.
My efan was not originally running, but I have bypassed the AC low pressure switch to have it running all the time (turns on if I jump the temp sensor from the rad as well but i haven't ordered a new sensor yet), but that has not helped temps.
I did a dry compression test and got a 130 across all 6 cylinders (didn't have any oil at the time, but numbers seemed good so I haven't done a wet test yet)
I am reading about 190F at the upper rad hose and about 170F at the lower hose. Someone told me on a facebook group that I should be getting about 20F difference which seems right, not sure if those temps themselves are high or low though.
My tailpipe is shot and leaking like crazy, and there is a small hole where the muffler dumps into the tailpipe, but I assume this is irrelevant. As best I can tell there are no leaks elsewhere in the pipes or around the cat.
I just failed emissions with high CO. Not sure if that's correlated.
As far as I am aware there is no smell of exhaust in the bay, nor any strange noises.
I am suspecting my water pump is pretty corroded or my head gasket leaking exhaust into the coolant. I also saw a video talking about the harmonic balancer wearing out that can cause overheating as well, but by eye it looks fine, not sure if there's any other clues without pulling it.
Keep in mind I'm just a dingus with some wrenches, if I missed any critical info please let me know, or if there are any tests I should be able to do. I'll keep the original post up to date with anything I might have missed as it comes to mind. Any advice appreciated!
  • Replies 63
Did you replace the hoses, especially the lower one?  Those are supposed to have an internal spring to keep the hose from collapsing from the water pump suction.  If the spring is gone or the hose is squishy, then the hose may collapse, restricting coolant flow.
Hi! The upper hose still had a clean sticker on it. The lower hose is suspiciously clean as well, so I think it's fairly new. I replaced the two heater hoses when I deleted the heater control valve. I actually checked for that spring this morning and it is not there. I ordered a spring someone else said fits, but I also checked and the hose looks to be fine even at high RPM. I am sitting at about 250 at idle though so I suspect even if I am collapsing at speed, I must have another issue elsewhere.
Welcome to the CC Forum.
You got your radiator shroud in place? You jumped your AC Low Pressure Switch, does your AC clutch engage when EFan is ON?
Here is the list of stuff to check whenever and MJ/XJ overheats:
1.  clean coolant.
2. good pressure cap or pressure bottle/cap  (This is surprisingly a commonly overlooked issue)
3. good viscous fan clutch  (its hard to test for this, so if the clutch is old, just replace it)
4. fan shroud (another overlooked, but critical, piece)
5. elect. cooling fan coming on as needed
6. good thermostat
7. a radiator that is free of external debris, and that is free of clogged passages (since it's hard to see inside an XJ/MJ radiator, use the coolant cleanliness as a guide to whether you should be considering a new rad.   A neglected cooling system will destroy even a brand new rad in short order.
8. firm/new cooling hoses.
Radiator shroud is in place. AC clutch does come on but I have it unplugged for now so I don't burn it out, I'm out of refrigerant.
1.  clean coolant.
6. good thermostat
1. Coolant cleaned
2. Pretty sure my rad cap is fine
3.  Fan clutch feels great but maybe I'll look into a new one anyways
4. All my shrouding is in good shape
5. Fan is on
6. Tested my new thermostat and working
7. Brand New rad and my water is staying pretty clean after a few flushes
8. Cooling hoses feel pretty good to me aside from the missing spring but I'm not collapsing
proper water pump? Some pumps have the blades facing opposite direction.  The belt spins the pump "backwards."   I don't know how to check it when mounted.
I think that'll be the next thing I check. I definitely have some flow that I can see at the rad cap but Ive seen quite a few that have corroded to the point they definitely effect cooling
29 minutes ago, jdog said:
Plain water or 50/50 mix?
I did a 50/50 mix after the first flush but it was still running hot. I'm running just water right now
I'd pull the water pump.
A bad radiator cap could also be an issue.
The spring was only in the hose to keep the hose from collapsing when the cooling system was filled using vacuum on the assembly line. Can't hurt to have it, but I've never worried about it and I live in Arizona FWIW.
You can rent/borrow a tester that checks for exhaust being present in the cooling system. Called "Block Check" IIRC. Might wanna do that first.
A rad pressure cap that won’t hold pressure WILL cause these engines to overheat.  Nominal operating temperatures are right about boiling point of water, and the combination of antifreeze and the pressure cap will raise the boiling point considerably.
Given the cost of a rad cap, I would put a new one on on general principles.
Thanks cruiser. I'll look into the tester. A few friends told me that you'd have to drive quite a bit for the gasses to leave enough trace for the tests to pick up, but certainly beats taking the head off and not finding a leak, I'll give it a go. I think I will pull the pump first this weekend.
I bought a brand new rad cap with the radiator. It's definitely not leaking any water past the cap, and it looks like the system has taken in some of the water from my expansion bottle, not sure if there's any other way to know if it's working properly. I suppose since I'm currently water only it could be boiling but not overpressurizing the cap and causing an issue? I will probably try another flush and a 50/50 mix after I do the water pump this weekend.
How do you know it's running at 250  degrees? There's no marked point on the temperature gauge for 250. Is the needle in the red?
20 hours ago, cruiser54 said:
Exhaust gasses show right up with the tester.
Cool, thanks, I picked up a tester yesterday. Once I check the water pump I'll drive a bit and see what it says!
I've been using an IR thermometer to read the temp at the block sensor. My needle spends most of it's time at or in the red.
I am not a chemist but this could be part of the problem.  I am pretty sure that the 50/50 antifreeze mix not only has a lower freezing point than straight water but also a higher boiling point.  I believe it will effect cooling just as it does freezing.  Better to return as much of the system to its design parameters before trying to chase a rabbit.
Water boils at 212*F at sea level.
Coolant just raises the boiling point and keeps the system from corrosion.
Everything else being good in the cooling system, it would run right at the thermostat rating.
5 hours ago, cruiser54 said:
The type of coolant mix, or the lack of it altogether, will not cause an overheat condition.
I disagree with you here. proper mixture is important to overheating issues.
Cruiser, the key thing you mentioned might be overlooked to ssome degree:  "everything else being good"
Plain water boils at 212*   Put a working 16lb pressure cap on the cooling system, and it raises the boiling point to 252*   Add a 50/50 mix, and the boiling point is now 267*
If the OP's engine is TRULY overheating (as in getting hotter than about 215* or thereabouts, I would suspect some sort of faiiure to hold pressure as the most likely culprit.  (Unless the dreaded head gasket failure that has been thrown out is proven to be a non-issue.)
