April 2021-88mjsally's 88 V8 Pioneer
April 2021
88mjsally's 88 Pioneer
D53AE9CF-C240-4ABB-8E26-6FBB278ED8ED.png.6ccb3ca05498fca5ad88a73d7fb7e42a.png.8580c8447e6563ba8520dc87665ceafb.png
Build Thread-
A College Students V8 Comanche
Year/Model -
 1988 Jeep Comanche Pioneer SWB
ED79BEF8-6927-4ABF-A8BC-60CD4A63CBFB.jpeg.f0d499260bea902a7aeb4acea990be83.jpeg.ab467225ae4dfdd414e8a19e4fa835d9.jpeg
Drivetrain-
1997ish Vortec Small block 350 from a Chevy truck which is stock other than a edelbrock intake
Headman center dump shorty headers
Exhaust is all 2.5” tubing with thrush welded mufflers
Engine accessories from a 1995 Chevy truck
Novak conversions engine mounts
C10 th350 transmission
Custom trans mount using a factory crossmember
Factory length rear driveshaft but new from carolina driveline
Dana 44 rear with 3.07s and a factory trac-lok
2wd beam front axle
F154AF4E-48D9-47A4-9464-17A7351DDE2F.jpeg.f0bc7c307fcb4fd7bfe2d02361e68662.jpeg.915668682731f9f889a9de045d592581.jpegDC9405CA-AFFC-4686-8171-382D9B4F25F6.jpeg.2f56d5004a4461b55e641018dbd90d9d.jpeg.f77d7b341be75db540c22e2ed921e86d.jpeg
Cooling-
Speedway motors universal v8 swap radiator
Flex a lite 18” fan
eBay aluminum shroud
eBay aluminum overflow
C95D2AB1-E400-47EC-B9CD-9CB6AAE80018.jpeg.5d48578ef908a9f365e66d667a5d543a.jpeg.924236b5d7e7891baf485e24b1ebe6f8.jpeg
Electrical/Ignition-
Factory dash harness with factory cluster hooked up
Holley Sniper EFI
Hyperspark distributer
Summit racing coil
Holley display screen mounted on the clock delete panel
Suspension/Steering-
Rebuilt Stock steering
Rough country double shear adjustable track bar
3” Rusty’s lift kit with add a leaf in the rear
Interior-
Black seats from a 86 four door xj on factory mj bucket brackets
Insulated under the carpet and inside the doors
New black acc carpet
TCI ratchet shifter mounted under a 97+ xj console
Blue face cluster from a 87 xj
XJ rugged ridge floor mats
All vinyl door panels and manual regulators from a 95 xj
Factory RX-173xj radio
Black tilt column from an 87 mj and grey leather wrapped wheel from a 92 xj
DB2AD23E-C54C-4F56-BEAA-1BBAD89261CA.jpeg.753aa1dff4d502e8ecd244ba215b3d04.jpeg.54cb7a3ed4f55e961f6e704179320ffc.jpeg59A40B4C-5226-4C6D-8DF1-C26741535E9E.jpeg.c3ff0b9767ffdb949e409e8f3eb4329b.jpeg.e03da9981682a19434de163dfa42a41c.jpeg
Brakes-
Stock rebuilt front disks
Stock rebuilt 10x2.5 drums in the rear
Lighting-
Amazon LED headlights
LED marker and taillight bulbs
Headlight harness
Exterior-
Faded single stage grey paint with old shop decals faded onto the doors
Factory bedliner from an 87 MJ
Minty factory rear bumper that I still need to install
Uhaul MJ tow hitch
Chinese stock xj front bumper with aftermarket tow hooks
Wheel & Tires-
04 tj ravine wheels
33x10.5r15 BFG all terrains
Washers under the steering stops so it doesn’t rub
Best MJ story-
When I first got my truck, I pulled it out from under a pile of junk in a guys garage. I didn’t have room to store it at home since I was about to start college so I stuck it out in my friends field. It sat there for about a year before we tried to load it up to take home. The trailer didn’t have a winch so we used a rope and my tj. My friend didn’t get it lined up right so the front fell off the ramps with the back still sitting up on the deck. It bent the steering and about made my friend inside the truck steering crap his pants. We started over and it was still crooked so we ended up having to Jack the rear up and slide it across the deck. I’m amazed looking back that it didn’t turn out worse but we got it home and vowed not to do that again
CC is Awesome! Why?
Lots of great information and friendly advice
38E91AF8-0A29-42A2-ADFA-2A506DA43CDA.jpeg.fb2291d6734545a66f602ff1d042d827.jpeg.c6457ded111053782a3ab4364600db07.jpegA837C8AE-55B7-4277-BC8F-DD55D1DBA955.jpeg.cd77aff31483e3cccba8f32ab2a315af.jpeg.c85f21e8e4b2dccd54ee985397a96cc7.jpegF0F8D02F-6A40-41B0-B6FF-06E673CAFA8D.jpeg.074e7b0e535a1dea5311edba76ca9e9b.jpeg.412ae95db898fc4d41bdc0e36eff5a57.jpeg8B26F353-42A6-4412-828D-3DA66055D8CA.jpeg.100912dce8faa633cbed6760422fee78.jpeg.733ac3bb134b4f72403d1a2d5ff782fe.jpeg
Congrats @88mjsally! This is a really cool truck!
