Rear diff.
2 hours ago, Showgoer said:
Will a rear diff from a Cherokee bolt right in to a Comanche ?
it may if you force but it will end up in a mess, you better off get a comanche axle or modify the cherokee one, if you have a d35 is the perfect chance to upgrade...
are you talking axle swap so don't have to replace gear gear? you can replace the internal gears with any d35 from xj. will have to double check backlash but slap it together and run it. you can replace just the spider gears as well if thats the issue with out replacing the whole axle or carrier. but if want a bolt in axle consider the corp 14 bolt, as it bolts right in as a soa conversion. but that's 8 lug 1 ton stuff. but bolt in upgrade for about $150. :grinyes:
  • 3 weeks later...
5 hours ago, Showgoer said:
Ok gents Iv changed the whole rear . Now Iv got a bad vibration. Changed u joints as well. I’m thinking piñon angle is off. How do I correct the piñon angle . ?
what axle did you end up using?
Has your driveline angle or length changed?
Is the pinion in the new axle loose?
Those are the likely suspects for vibrations
Well I put new leafs in and it raised it a little. Is there any way to correct the angle?
