MiNi Beast Posted October 4, 2021 Share Posted October 4, 2021 12 hours ago, Muncher said: 13 hours ago, strictlyxjs said: What happened? Lugs rattled them selves off and my tire fell right for and hit someone else's car Oh snap. Link to comment Share on other sites More sharing options...
Pete M Posted October 5, 2021 Share Posted October 5, 2021 every time you rotate tires you need to torque them to spec, drive around the block, and retorque them. then check again after a few miles. thankfully it wasn't even worse. Link to comment Share on other sites More sharing options...
Muncher Posted October 8, 2021 Author Share Posted October 8, 2021 Yeah thankfully. I'm going to buy new wheel hubs that come with the bearing and the studs for now till I replace My axles so I can get back to driving. Link to comment Share on other sites More sharing options...
Top C Posted October 9, 2021 Share Posted October 9, 2021 I have a leak somewhere in my MJ, what is the power trick to locate the leak? I suspect it's coming from the front Wind Shield. I was thinking I might go to an auto window shop to see if they can reseal it but I'd like to confirm that's where its coming from. I see a small puddle when its sitting after a rain storm or when I wash it on drivers side. Mike Link to comment Share on other sites More sharing options...
Pete M Posted October 9, 2021 Share Posted October 9, 2021 3 hours ago, Top C said: I have a leak somewhere in my MJ, what is the power trick to locate the leak? I suspect it's coming from the front Wind Shield. I was thinking I might go to an auto window shop to see if they can reseal it but I'd like to confirm that's where its coming from. I see a small puddle when its sitting after a rain storm or when I wash it on drivers side. Mike I like to sprinkle a small amount of baby power in the suspect area. the water will make little trails through the powder and lead back to the leak location. Link to comment Share on other sites More sharing options...
Muncher Posted October 13, 2021 Author Share Posted October 13, 2021 On 10/9/2021 at 6:12 AM, Top C said: I have a leak somewhere in my MJ, what is the power trick to locate the leak? I suspect it's coming from the front Wind Shield. I was thinking I might go to an auto window shop to see if they can reseal it but I'd like to confirm that's where its coming from. I see a small puddle when its sitting after a rain storm or when I wash it on drivers side. Mike My drivers side leak was a body plug. I used bed liner to seal it lol Link to comment Share on other sites More sharing options...
Muncher Posted October 13, 2021 Author Share Posted October 13, 2021 Yeah so I think this rims never going to be balanced again .... also I got those new hexagonal brake rotors. Snapchat-690611426.mp4 Link to comment Share on other sites More sharing options...
Pete M Posted October 17, 2021 Share Posted October 17, 2021 daaaaaaaaaammmmmnnnnn...... Link to comment Share on other sites More sharing options...
Muncher Posted October 17, 2021 Author Share Posted October 17, 2021 yeah just a little nasty Link to comment Share on other sites More sharing options...
Muncher Posted October 18, 2021 Author Share Posted October 18, 2021 New hubs rotors pads and calipers along with rubber hoses. And now of course some electric bs is causing it not to start. Off to the shop! Link to comment Share on other sites More sharing options...
Muncher Posted December 4, 2021 Author Share Posted December 4, 2021 Well the trucks not running again. Had some fun on the trails and i was on my way home going up a hill and it felt like it was pushing me back and knocking. Shut it off and checked and it didn't start again. Link to comment Share on other sites More sharing options...
strictlyxjs Posted December 7, 2021 Share Posted December 7, 2021 Have you had anyone with a renix scanner look at it. Link to comment Share on other sites More sharing options...
Muncher Posted December 7, 2021 Author Share Posted December 7, 2021 I have the rem but it doesn't seem to be saying anything, Link to comment Share on other sites More sharing options...
Muncher Posted February 17, 2022 Author Share Posted February 17, 2022 Sadly this mj project is coming to a end... jk lol I'm shipping out to the army the 28th and it will continue once I'm done. That sign on bonus is going to a stroker and a super charger . But it will basically just be getting a full restore at this point. Plans 95 xj harness swap. 4.6l stroker Boost tech super charger Hp 30 Keeping rear dana 44 but possible 8.8 swap Going to go with a 6 speed from a newer tj paired to a np242. Probably going to just have the whole thing re painted as it was not done the best and I just want it done properly. Link to comment Share on other sites More sharing options...
Pete M Posted February 19, 2022 Share Posted February 19, 2022 how exciting! you've been running every day, right? Link to comment Share on other sites More sharing options...
Muncher Posted February 19, 2022 Author Share Posted February 19, 2022 4 hours ago, Pete M said: how exciting! you've been running every day, right? Yes currently extremely sore from running on the treadmill Link to comment Share on other sites More sharing options...
Muncher Posted March 13, 2022 Author Share Posted March 13, 2022 Some pictures I haven't posted before. Snapchat-61544396.mp4 Link to comment Share on other sites More sharing options...
Muncher Posted April 20, 2022 Author Share Posted April 20, 2022 Engine and harness swap along with renovations. Link to comment Share on other sites More sharing options...
Muncher Posted May 1, 2022 Author Share Posted May 1, 2022 Rear main, oil pan, and the timing chain sprockets and gasket all done. Next is to paint the rest of the block and do waterpump and thermostat along with valve cover. But besides that I'm almost done. Just finish painting accessories and I'll be done Snapchat-159108800.mp4 Link to comment Share on other sites More sharing options...
Muncher Posted May 5, 2022 Author Share Posted May 5, 2022 Thinking of once I get back to work I'll buy another car and get my truck completely re painted. Not sure I want to keep it red but keep it a Comanche cheif definitely what color suggestions do you guys think I should do? Link to comment Share on other sites More sharing options...
89 MJ Posted May 5, 2022 Share Posted May 5, 2022 Red. That is the iconic Comanche Chief look. Link to comment Share on other sites More sharing options...
MiNi Beast Posted May 5, 2022 Share Posted May 5, 2022 Classic red all the cool kids do. Be different eh!. 🤔 Purple was different. Grey is plain. Orange is good for Halloween. Yellow be like the sun 🌞. But if you don't redo red would you have to change out the headliner?? Link to comment Share on other sites More sharing options...
Pete M Posted May 5, 2022 Share Posted May 5, 2022 red. Link to comment Share on other sites More sharing options...
Muncher Posted May 5, 2022 Author Share Posted May 5, 2022 11 hours ago, MiNi Beast said: Classic red all the cool kids do. Be different eh!. 🤔 Purple was different. Grey is plain. Orange is good for Halloween. Yellow be like the sun 🌞. But if you don't redo red would you have to change out the headliner?? The head liner is planned to be chanced out to a nice Mexican blanket anyways. Link to comment Share on other sites More sharing options...
MiNi Beast Posted May 5, 2022 Share Posted May 5, 2022 Then go teal. Link to comment Share on other sites More sharing options...
