MJOTM May 2020-ghetdjc320's 91
May 2020-ghetdjc320's 1991 Eliminator
Build Thread:
YEAR/MODEL
1991 MJ Eliminator
DRIVETRAIN
Engine: Seasoned 96’ 4.0 block from XJ bored .060 decked .025 align honed, rotating mass balanced, king bearings, all arp bolts, custom stage 2 cam, hylift-johnson s-series lifters, adjustable roller rockers, melling hv oil pump, cloyes timing set, Edelbrock aluminum head, 99+ Intake, 63mm throttle body from strokedjeep.com, 24# injectors, silvolite hypereutectic pistons, NEW 4.0 crank.
Tranny: AW4 flush and filter, external upgraded tube and fin oil cooler, new transmission mount.
Transfer case: 1994 np232 with full rebuild. JB conversions sye, Tom woods custom rear cv shaft, Adams driveshaft custom front cv shaft.
Axles: Dana 30 HP non disco front, new spicer front u joints with larger d44 style joints. Revolution axle and gear 4.56 gears with timken master install kit. Rear “Super” Dana 35 with revolution axle and gear chromoly shafts, Detroit truetrac, TNT truss.
COOLING
Double core aluminum radiator with triple 10” fans and digital controller. Flowcooler billet water pump, Hesco high flow thermostat housing
ELECTRICAL/IGNITION
Optima yellow top, ZJ alternator upgrade (+/- 140A). Heavy duty wiring upgrade with 2/4awg welding wire, master waterproof fuse.
SUSPENSION/STEERING
ZJ moog steering with JKS dampener, JKS adjustable track bar, metal cloak control arms, rocky road control arms brackets, axle stripped bare and all new Artec bracketry installed, Bilstein 5150 shocks with double eye mounts, rear soa
INTERIOR
ACC carpet over dynamated interior, seats restored using original fabric, new headliner.
BRAKES
Electric brake assist with dual 8” booster and corvette MC. Drilled and slotted front rotors
LIGHTING
Black flame customs 5x7 morimoto retrofit bi-xenonprojectors with morimoto 5500k H1, morimoto relay harness and ballasts, Kc flood patter led’s installed in bumper fog light location and wired to oem connections.
EXTERIOR
Every body panel straightened and all rust removed. 2020 Aston Martin Cinnabar Orange paint (ppg dimzler code)
WHEELS AND TIRES
2019 factory JL gunmetal alloy wheels, 33” Yokohama tires
MISC
There is just so much more to list that it would take up a small book. What I can say is that it drives like new with great steering and brakes and has awesome AC. To me, anytime you can modify something and still get it to handle like new then your doing something right.
 Remember That One Time?... Tell Us Your Best MJ Story
There are too many to tell! Ultimately, this MJ has traveled the world with us and is now on the island of Guam. It is no where near the MJ I picked up that cold night in St Louis. I would say the craziest story was just the drive home. I bought it at night after making a 5 hr drive from Arkansas to St Louis, MO. It was raining out so I pretty much just started it and then handed the guy the cash. It was an absolute beater. Almost no interior except for the dash and seats which were in very rough shape. The headlights were useless to me and the heater wasn’t doing anything in 20 degree weather. It also felt very anemic which I would later discover came from a massive vacuum leak and a cracked block. When I finally pulled the rubber mats and shabby leftover carpet out, I found there was very little drivers side footwell left. I honestly can’t say how I was able to drive home that night but that little MJ made the 5hr return journey and I was hooked. My dad and I have worked on cars since I was a little kid and this is the last project we have worked on together. Plenty of good memories along the way I won’t forget.
CC is Awesome!... Why Do You Think So?
Super helpful group of people who are very modest and genuine. I appreciate that everyone here is just an MJ enthusiast plain and simple. I really appreciate the support and
help!
te
Congratulations and what a beauty @ghetdjc320!
2 quick notes
1. Stop drooling
2. If you would like to see your MJ as a future MJotM, please send me a PM.
  • 3 weeks later...
Well, after 20+ tire kickers and ridiculous low ball offers I’m keeping it and shipping it to Micronesia with us. One guy offered 15k some offered 10 or less. Some guys said they would only go off of kbb value which just shows how ignorant people really are. One guy said he didn’t like it modified and asked if I would return it all to stock and he would offer me 10k lol. What a joke. Anyways, I just don’t have the ambition to keep dealing with these ridiculous offers. Before I set off for Micronesia I’m really trying to dig up some parts that I’m hoping someone will be generous enough to part with. I really need a set of mud flaps for this truck. Where we’re moving to is one of the wettest places on earth so trying to keep everything in as good of shape as possible. Going to be going over everything at least once every couple of weeks and making sure no rust tries to form. If anyone has a set of mud flaps they’d be willing to part with please let me know. And yes, I know it’s a big ask 😆
4 hours ago, fiatslug87 said:
I for one am glad you are keeping it. After all that hard work you should enjoy it for a while. for front flaps:
https://www.ebay.com/itm/NOS-OEM-Jeep-Cherokee-Front-Splash-Mud-Guards/264694052668?hash=item3da0feb73c:g:IAkAAOSwcLlejjiZ
@fiatslug87 Thanks a ton! Just picked those up. Now just need to find some rears. These will help so much to keep the truck in good shape
I believe @Minuit did a write up on modifying either fronts or XJ rears to fit on the rear of an MJ.
There is an old writeup with some pics in my signature. Nothing complicated about it - flip the brackets around from the way they're "supposed" to go and drill two new holes in them straight across from where the existing holes are.
yep I saw your write up. I’m thinking about just getting another set of fronts and the scarfab brackets to install in the original location. I’ll just trim them to match the original rears if I can’t find any. Need to find another set of fronts now
On 5/28/2020 at 5:36 AM, fiatslug87 said:
@ghetdjc320 That eBay vendor has been listing and selling fronts for a while, contact them to see if they have more.
Just picked up a second set from him for the rears. I’ll trim them with the templates I posted for the rears. Ordered the brackets already so they will look completely stock. Thanks for the tips!
4 hours ago, bruceb said:
Love your truck and I have been to Guam many times!  Did all the work on your truck take place on Guam? I have two Comanches - one 2WD street and one 4WD for camping.
Thanks
I did 95% of the work stateside. But as with most projects, I keep working in it while here on island too
