Dammerung Posted September 13, 2019 Share Posted September 13, 2019 Finally got my new keys for my truck! NOS key blanks that a locksmith got when the Comanches were around. American made and he says he can’t get ones like these anymore. Also got some Euratech domes which I LOVE! They feel so nice! (P.S. how do I hook them up?) Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
DIRT_NASTYY_ Posted November 8, 2019 Share Posted November 8, 2019 You should have 3 wires, if my memory is right the switch wire goes in the middle, power to end of rocker switch, and ground on the other end. Just put these exact ones in with LED bulbs from O'Reilly's, so much nicer! Link to comment Share on other sites More sharing options...
Dzimm Posted November 8, 2019 Share Posted November 8, 2019 Leds are a must in them. Just don't look at them directly or you'll go blind. No dark spots in the cab tho. Link to comment Share on other sites More sharing options...
Maveric Posted November 10, 2019 Share Posted November 10, 2019 Anyone got a part number on those lights? I want a set! My original ones are broken. Link to comment Share on other sites More sharing options...
Warren Mohler Posted November 10, 2019 Share Posted November 10, 2019 get them on Ebay $9.95 a piece from some limo company, best price I found for the lights and they are nice Link to comment Share on other sites More sharing options...
Dzimm Posted November 10, 2019 Share Posted November 10, 2019 34 minutes ago, Maveric said: Anyone got a part number on those lights? I want a set! My original ones are broken. I believe it's: Euramtec A-7180-BC They are often marketed for the Delorean as they are direct replacement for the dome light. Link to comment Share on other sites More sharing options...
DIRT_NASTYY_ Posted November 11, 2019 Share Posted November 11, 2019 17 hours ago, Dzimm said: I believe it's: Euramtec A-7180-BC They are often marketed for the Delorean as they are direct replacement for the dome light. @Maveric Yeah these ^ are the ones I used in black, however I had to shave off some aplastic for them to fit as they were slightly bigger than OEM, just a heads up. Link to comment Share on other sites More sharing options...
Virginia Posted November 19, 2019 Share Posted November 19, 2019 On 11/7/2019 at 11:09 PM, DIRT_NASTYY_ said: You should have 3 wires, if my memory is right the switch wire goes in the middle, power to end of rocker switch, and ground on the other end. Just put these exact ones in with LED bulbs from O'Reilly's, so much nicer! I have a red, black and yellow wire going to my current courtesy lights. Which one is the power wire? Link to comment Share on other sites More sharing options...
coolwind57 Posted November 19, 2019 Share Posted November 19, 2019 8 minutes ago, Virginia said: I have a red, black and yellow wire going to my current courtesy lights. Which one is the power wire? Go here, Virginia: About 5 posts down. Link to comment Share on other sites More sharing options...
DIRT_NASTYY_ Posted November 20, 2019 Share Posted November 20, 2019 Link to comment Share on other sites More sharing options...
Virginia Posted November 25, 2019 Share Posted November 25, 2019 Here's what I have. Those are yellow, pink and black. I believe the red to be the power wire. And here's the schematic for my new lights. Link to comment Share on other sites More sharing options...
Warren Mohler Posted November 25, 2019 Share Posted November 25, 2019 red to A, yellow to B, black to C Link to comment Share on other sites More sharing options...
Virginia Posted December 1, 2019 Share Posted December 1, 2019 On 11/24/2019 at 8:49 PM, Warren Mohler said: red to A, yellow to B, black to C So, I hooked the lights up according to those instructions and the dome lights won't turn off even when I flip the lens up and down. I had to take the fuse out. Suggestions? Link to comment Share on other sites More sharing options...
Warren Mohler Posted December 1, 2019 Share Posted December 1, 2019 look at your lamp closely terminal for red should go to one end of lamp yellow and black should go to terminals that have a diode dohicky between them if that s all ok switch yellow and black and see what happens, remember to do this with doors closed and headlamp switch in dim position Link to comment Share on other sites More sharing options...
Dammerung Posted December 1, 2019 Author Share Posted December 1, 2019 So, I hooked the lights up according to those instructions and the dome lights won't turn off even when I flip the lens up and down. I had to take the fuse out. Suggestions? You have your grounds swapped. Flip themSent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Virginia Posted December 1, 2019 Share Posted December 1, 2019 54 minutes ago, Dammerung said: You have your grounds swapped. Flip them Sent from my iPhone using Tapatalk Will do tomorrow. Link to comment Share on other sites More sharing options...
Virginia Posted December 1, 2019 Share Posted December 1, 2019 13 hours ago, Warren Mohler said: look at your lamp closely terminal for red should go to one end of lamp yellow and black should go to terminals that have a diode dohicky between them if that s all ok switch yellow and black and see what happens, remember to do this with doors closed and headlamp switch in dim position I'm not sure which position is the dim position now Link to comment Share on other sites More sharing options...
Warren Mohler Posted December 1, 2019 Share Posted December 1, 2019 turn switch clockwise, turning counter clockwise till it clicks will turn on interior lamps Link to comment Share on other sites More sharing options...
Virginia Posted December 2, 2019 Share Posted December 2, 2019 6 hours ago, Warren Mohler said: turn switch clockwise, turning counter clockwise till it clicks will turn on interior lamps Turned it all the way to the right and switched the yellow and black wire. Still stays on even with door closed. Switched the black and yellow back to their original position per the schematic that came with the lights and still stays on even with doors closed. I also moved the lens up and down and that didn't change anything either. Link to comment Share on other sites More sharing options...
JMO413 Posted December 2, 2019 Share Posted December 2, 2019 Just guessing but I bet your dome light switch is bad. Link to comment Share on other sites More sharing options...
Virginia Posted December 2, 2019 Share Posted December 2, 2019 4 minutes ago, JMO413 said: Just guessing but I bet your dome light switch is bad. Well crap. I don't even know where to begin on that. Link to comment Share on other sites More sharing options...
JMO413 Posted December 2, 2019 Share Posted December 2, 2019 It's the top part in the picture. It just unscrews it of the door jamb. As you can see mine is trashed. The plunger in the middle should be out with the door open. Link to comment Share on other sites More sharing options...
Virginia Posted December 2, 2019 Share Posted December 2, 2019 5 minutes ago, JMO413 said: It's the top part in the picture. It just unscrews it of the door jamb. As you can see mine is trashed. The plunger in the middle should be out with the door open. Mine does pop out when the door is open. I'll try taking it out and cleaning it or something. Link to comment Share on other sites More sharing options...
Ωhm Posted December 2, 2019 Share Posted December 2, 2019 Dome light is a three position switch. Center position is OFF. Link to comment Share on other sites More sharing options...
Virginia Posted December 2, 2019 Share Posted December 2, 2019 2 minutes ago, Ωhm said: Dome light is a three position switch. Center position is OFF. I had it in the center position with the switch turned all the way to the right and the light stayed on. I flipped the dome light down. No changed. Flipped the dome light up and no change. Nothing broke the power to the dome light. I had to pull the fuse. Link to comment Share on other sites More sharing options...
