  • Replies 506
Quite amazing how fast all that came out. The hardest part was the a pillars because at some point the windshield was replaced and they used so much glue it stuck the glass to the trim. Other than that everything came out easy. I got a new heater core for mine as I might as well change it when I go to swap the dash.
Found my old cable from the original dash. Wrapped it in the 2000 degree exhaust header wrap and then a 1000 degree aluminum fiberglass tape. Hopefully that takes care of the melting issue.
I knows it’s a dumb question but what kind of fuel mileage are you seeing so far? I had a couple early 2000s 5.3 silverados and they got 18-20mpg fairly consistently I’d driven right.
On my trip I was seeing around 16 to 20. But I hammer the gas any chance I get still lol. I image once I calm down I'll be seeing low 20s
This is very encouraging because the original reason I went LS was to get much better fuel mileage. Stroker's drink gas. I am lucky to get much more than 12-14mpg out of mine. What gear ratio are running?
Yeah it's definitely better than my Cherokee for sure. And that's average is 13mpg based on the overhead unit. And it's a 3.55 rear.  3000 rpm at 75.
11 hours ago, Limeyjeeper said:
Cool I went 3.55 gears too.
Nice. I have a new posi carrier and thought about 3.73 but that would be a little high in the rpm on the highways after seeing what 3.55 does
Got some new adjustable mirrors because the 86 I got had the trim piece. Also got my new seat belts.  Other than the color being off they seem super nice. Looks like it should work. I'll find out tomorrow when I'm swapping everything in.
Also got my new red head steering box. Got one in my Cherokee and it's super nice. I might put that in tomorrow too with the tan column.
That’s awesome. I’ve really been tossing the idea of an ls swap around but I’d hate to sacrifice my trucks mileage. Sounds like it’s capable of better economy than a 4.0 if you stay off the throttle 😂
See that's the hardest part of the whole thing. Trying not to mash the throttle every take off or tunnel lol
I will say after driving this thing and going back to my Cherokee, that thing definitely needs a V8 too
Rebuilt the new to me tan column. Wasn't too bad just so many little pieces in that thing. Also got the new steering box in at the same time. What a difference. Don't feel like I'm driving it like in the old movies where they are just steering back and forth going straight.
Also got the interior "done". Still need new seats and a new steering wheel but the dash and panels are all done.  Painted the lower dash piece and arm rests with SEM. That stuff works great.
On 5/30/2020 at 4:28 PM, onebigmj said:
Interior looks awesome! I love the sem paint. It’s held up fantastic in mine and matched almost perfect
Yeah I was shocked how well it matched
Got the hood vents in! Not bad for some eBay ones. They ship flat so you can use them as a template, then bend them once installed.  Also cleaned and painted the underside of the hood
13 hours ago, Limeyjeeper said:
How is she (he) running?
Really really well actually. Been driving it every day and other than a small oil leak all is good. Definitely want some new wheels soon though
Got the eurotec lights installed.  Pretty amazing how similar they are to factory. Just gotta put some blade terminal on the wires.  They clip right in. I might paint the trim tan to match but they honestly look good as is.
Didn't do the full bezel? I like your idea better but how well does it hold in place?
Perfectly fine. When the lights are on you can see the tiniest amount of light come through the edges because the bezel is ever so slightly smaller long ways, but the sides where the clips are, are the right size so it clips in and stays.  I like this way better too than using the huge bezel.
I don't know why I didn't think of that but too late now lol. I probably thought you couldn't mount them without the big bezel but evidently you can. Looks good!
