4th Generation MJ project
Got the rear axle in, drive shaft fits good. I need to pick up some ujoint straps or ubolts to mount it tho. My misalignment spacers came in, wrong ones again. Tried to put the old ones back in with a new nylon lock nut. Not sure if they cross threaded or it was the wrong thread pitch but its seized on now and needs cut off.
Still waiting for one portion of this project to go as planned. Got the old bolt cut off after I cross threaded the nut. New bolt is too long and the misalignment spacer broke in half. Now i gotta wait for a new one of those and a bolt. Hoping the bolt shop had the right bolt. XO Fab in enumclaw is going to do the alignment and make sure I didnt mess anything up. Heard good things about them.
1 hour ago, rylee144 said:
Got the clutch and the brakes bled I think. Brakes are holding good. I can shift but it seems rough and clunky. It won't go into reverse, grinds. Does that mean my clutch is still messed up or what?
does it go into reverse with the engine off?
