MiNi Beast Posted April 1, 2021 Share Posted April 1, 2021 blanket in the mj bed makes a great play pen.. Link to comment Share on other sites More sharing options...
Jesse J Posted April 1, 2021 Share Posted April 1, 2021 On 4/1/2021 at 12:54 AM, rylee144 said: 12 hours of Overtime today. 12 hour shifts and 2 kids under 3. Hurt the jeep time Expand wow I thought highschool took up my time Link to comment Share on other sites More sharing options...
Pete M Posted April 1, 2021 Share Posted April 1, 2021 sleep is overrated... Link to comment Share on other sites More sharing options...
rylee144 Posted April 1, 2021 Author Share Posted April 1, 2021 Got the rear axle in, drive shaft fits good. I need to pick up some ujoint straps or ubolts to mount it tho. My misalignment spacers came in, wrong ones again. Tried to put the old ones back in with a new nylon lock nut. Not sure if they cross threaded or it was the wrong thread pitch but its seized on now and needs cut off. Link to comment Share on other sites More sharing options...
rylee144 Posted April 4, 2021 Author Share Posted April 4, 2021 Still waiting for one portion of this project to go as planned. Got the old bolt cut off after I cross threaded the nut. New bolt is too long and the misalignment spacer broke in half. Now i gotta wait for a new one of those and a bolt. Hoping the bolt shop had the right bolt. XO Fab in enumclaw is going to do the alignment and make sure I didnt mess anything up. Heard good things about them. Link to comment Share on other sites More sharing options...
MiNi Beast Posted April 4, 2021 Share Posted April 4, 2021 what in the sam hell? tone down those biceps, not need to tighten them down that tight. Link to comment Share on other sites More sharing options...
rylee144 Posted April 4, 2021 Author Share Posted April 4, 2021 I think the spacer was already broken. The nut cross threaded before it was snug. Drive shaft fits well Link to comment Share on other sites More sharing options...
rylee144 Posted April 5, 2021 Author Share Posted April 5, 2021 Thought I was close to done. Started the truck in neutral foot on the clutch and al most ran into the front of my garage. What should I check? Bleed the clutch? Link to comment Share on other sites More sharing options...
MiNi Beast Posted April 5, 2021 Share Posted April 5, 2021 yeah check for air bubbles with someone while clutch pumping. I'm having same issues with my slave just an inch at floor. Link to comment Share on other sites More sharing options...
rylee144 Posted April 5, 2021 Author Share Posted April 5, 2021 Copy. Thx. Link to comment Share on other sites More sharing options...
Pete M Posted April 6, 2021 Share Posted April 6, 2021 yeah, no safety clutch anythings with the MJ. gotta be on your toes all the time. Link to comment Share on other sites More sharing options...
rylee144 Posted April 6, 2021 Author Share Posted April 6, 2021 Got the clutch and the brakes bled I think. Brakes are holding good. I can shift but it seems rough and clunky. It won't go into reverse, grinds. Does that mean my clutch is still messed up or what? Link to comment Share on other sites More sharing options...
Jesse J Posted April 6, 2021 Share Posted April 6, 2021 what is going on with your exhaust good sir? Link to comment Share on other sites More sharing options...
eaglescout526 Posted April 6, 2021 Share Posted April 6, 2021 On 4/6/2021 at 8:39 PM, rylee144 said: Does that mean my clutch is still messed up or what? Expand Internal or external slave? Link to comment Share on other sites More sharing options...
MiNi Beast Posted April 6, 2021 Share Posted April 6, 2021 was it a used trans? can be bad shift fork pads, but need to ensure pressure plate is good. kinda hard telling what your working with over here. Link to comment Share on other sites More sharing options...
rylee144 Posted April 6, 2021 Author Share Posted April 6, 2021 External. I shifted to reverse with I off and it worked fine. I backed out of the garage. Looks at this f-ing tire. Wtf is that lol Link to comment Share on other sites More sharing options...
rylee144 Posted April 6, 2021 Author Share Posted April 6, 2021 Link to comment Share on other sites More sharing options...
rylee144 Posted April 6, 2021 Author Share Posted April 6, 2021 Lifted it up and set it down again, rolled down the driveway. It's better Link to comment Share on other sites More sharing options...
Pete M Posted April 6, 2021 Share Posted April 6, 2021 On 4/6/2021 at 8:39 PM, rylee144 said: Got the clutch and the brakes bled I think. Brakes are holding good. I can shift but it seems rough and clunky. It won't go into reverse, grinds. Does that mean my clutch is still messed up or what? Expand does it go into reverse with the engine off? Link to comment Share on other sites More sharing options...
rylee144 Posted April 6, 2021 Author Share Posted April 6, 2021 On 4/6/2021 at 9:44 PM, Pete M said: does it go into reverse with the engine off? Expand It does. Link to comment Share on other sites More sharing options...
eaglescout526 Posted April 6, 2021 Share Posted April 6, 2021 Anything wrong with the flywheel? Broken bolts for the clutch plate? Bad internal slave? Link to comment Share on other sites More sharing options...
rylee144 Posted April 6, 2021 Author Share Posted April 6, 2021 It has an external slave, brand new clutch and fly wheel. After I bled the clutch and brakes everything seems to be doing fine. I just shift into reverse when it's off. Link to comment Share on other sites More sharing options...
eaglescout526 Posted April 6, 2021 Share Posted April 6, 2021 You could always do the ole shift into first then reverse while the engine is running. Link to comment Share on other sites More sharing options...
rylee144 Posted April 6, 2021 Author Share Posted April 6, 2021 Prolly have to. Good enough for me. Alignment scheduled for next week. Getting there will be the true test. Super happy to be this far! Couldnt have done it without the club's help. Link to comment Share on other sites More sharing options...
rylee144 Posted April 6, 2021 Author Share Posted April 6, 2021 I'd like to find an xj shifter stalk someday too. The one I have is taller and feels weird. Guess I could cut out a chunk and weld it Link to comment Share on other sites More sharing options...
