OBD1
Thanks a lot for the info!
how do i check out when i should have problem&where can i pick up after market on line for the comanche!
Are you looking for a scan tool for your MJ? If it's a 1991 or newer, it'll be OBD1, and you won't need one.
For 1990 and older (i,e, Renix) there is a scan tool, but good luck finding one in working order for less than you paid for the MJ.
  The Renix diagnostic ports are located on the pass side wheel well near the battery.  If memory serves there are 2 ports, usually covered with yellow weather tight plugs.  They are under the black plastic cover that hides some of the relays.  Snap-on has (had) the Renix adapter for some of their older scan tools.  I hooked up to Meg with the MT2500.
The OBD1 port on 91 and newer is next to the computer on the drivers side and any obd1 scanner with a Chrysler plug will fit it but as stated you don't need one.
The only one i have seen that will scan a Renix is the old Snap On brick (mt2500) and they are getting hard to find anymore.
It's not the DRB3, its just the DRB for that vintage. You need the Jeep Eagle adapter for it as well. I am lucky enough to have one, it works good at live streaming data and testing certain systems and sensors, but there are no stored codes with it.
This^.  There is not an underdash port like for OBDII but there is a port under the hood by the ECM. Any McAuto parts place can loan you a scanner for OBDI
This has been an interesting thread. I have an Actron 9145 scanner I've had for years that I use for my OBD2 vehicles. From this thread, I've learned that I can purchase an Actron CP9129 Chrysler adapter cable like the below (~$25) and my Actron 9145 OBD2 scanner can read my 91 MJ OBD1 fault codes by plugging it into the test port near the ECU. I never knew this.
But what I don't know is how much good it will do me. Does it do more than just "read" the codes? I can already do that with the IGN key trick. Any benefits besides saving wear and tear on my ignition switch?
I have the Chrysler OBD I connector for my Vetronix/Bosch MTS3100 and, in addition to streaming data,  you can also run through various test sequences (injector balance test for example).  I primarily use the MTS3100 on my GM vehicles (it's basically at Tech 1A brain with additional features) and there are some GM things you simply can't do without it (crank variation learn on a Vortec engine or cycling ABS motors to finish bleeding a brake system).
  I don't recall having a library of test sequences for the Renix system on the MT-2500.  The Solus and the OTC/SPX Genisys didn't come with Renix cables and I didn't seem them listed in the catalog.  I think the DRB and MT-2500 are the only ones that can speak Renix...
