1990 short bed resto; TDi, 3-link, coilovers, doubler, JK axles
On 12/16/2024 at 9:05 PM, 89 MJ said:
My dad used POR15 on the rocker panels of his 2000 Silverado plow truck. The rockers eventually rotted away anyways. We’ve started using Chassis Saver instead. It seems to work much better and is only a one part product.
I've become wary of any one-part product - it's 2k epoxy for me, going forward.
  • Replies 275
Posted Images
On 12/9/2024 at 9:55 AM, A-man930 said:
I decided to tackle a section of body work. Going to try and get the roof and cab down to just below the glass channels covered in epoxy.
Impressively, I've discovered there has been rust forming below the factory basecoat...
I worked in a shop as a teenager and the bodyshop guy told a friend of mine that drove an older Chevelle that was primer'd for YEARS, that the body would rust w/o paint, he stated that primer was pores and needed to be sealed with paint:dunno:, sure enough surface rust showed up at about 5 years after nothing but primer:crazy: not sure that happens at every case, but as mentioned, the Chevelle had been stripped down to bare metal and nothing but primer for 5+ years:(
I've heard similar regarding primer. But this is the OEM applied stuff, as far as I'm aware. Not what I expected to see
I agree it seems odd and an unlikely scenario and not what you'd expect on a factory finish, perplexing:dunno:
Coming up on a milestone!
I've waffled back and forth on how much of the body to tackle at once - settled on spraying the whole cab and "chassis" all at once; inside and out, top and bottom.
Before this can happen, I want to have all conceivable cutting and welding completed.  All locations for sensors, wiring, mounting brackets, Etc.
It's taking forever!  :sad2:
This is the way :L:
On 6/18/2025 at 5:22 PM, A-man930 said:
Scored a helluvuh deal on some 16" travel 2.0 Kings.  14" would have sufficed, but a deal is a deal!
been looking for a deal on coil overs myself! haven't been able to decide between 14/16, doing lots of reading it online says 14 is more than enough, but in my town everyone has 46"+ tires so only 16's are on the marketplace
until then I will be running my old coil springs with a sticker in the wheel well saying " I identify as a coil over"
