A-man930 Posted December 18, 2024 Author Share Posted December 18, 2024 On 12/16/2024 at 9:05 PM, 89 MJ said: My dad used POR15 on the rocker panels of his 2000 Silverado plow truck. The rockers eventually rotted away anyways. We’ve started using Chassis Saver instead. It seems to work much better and is only a one part product. I've become wary of any one-part product - it's 2k epoxy for me, going forward. Link to comment Share on other sites More sharing options...
89 MJ Posted December 18, 2024 Share Posted December 18, 2024 That’s always the best way to do it Link to comment Share on other sites More sharing options...
A-man930 Posted December 18, 2024 Author Share Posted December 18, 2024 This is going to be a long process... Link to comment Share on other sites More sharing options...
A-man930 Posted December 18, 2024 Author Share Posted December 18, 2024 1714685862_20241217_1539013.mp4 Link to comment Share on other sites More sharing options...
89 MJ Posted December 18, 2024 Share Posted December 18, 2024 Would it be easier to sandblast it? Link to comment Share on other sites More sharing options...
M.T.Hands Posted December 18, 2024 Share Posted December 18, 2024 On 12/9/2024 at 9:55 AM, A-man930 said: I decided to tackle a section of body work. Going to try and get the roof and cab down to just below the glass channels covered in epoxy. Impressively, I've discovered there has been rust forming below the factory basecoat... I worked in a shop as a teenager and the bodyshop guy told a friend of mine that drove an older Chevelle that was primer'd for YEARS, that the body would rust w/o paint, he stated that primer was pores and needed to be sealed with paint, sure enough surface rust showed up at about 5 years after nothing but primer not sure that happens at every case, but as mentioned, the Chevelle had been stripped down to bare metal and nothing but primer for 5+ years Link to comment Share on other sites More sharing options...
A-man930 Posted December 18, 2024 Author Share Posted December 18, 2024 22 minutes ago, 89 MJ said: Would it be easier to sandblast it? I plan to sandblast in the areas that I cannot get at with a wire cup and such. I have a feeling it won't perform any miracles just because of how hard this stuff is. Link to comment Share on other sites More sharing options...
A-man930 Posted December 18, 2024 Author Share Posted December 18, 2024 15 minutes ago, M.T.Hands said: I worked in a shop as a teenager and the bodyshop guy told a friend of mine that drove an older Chevelle that was primer'd for YEARS, that the body would rust w/o paint, he stated that primer was pores and needed to be sealed with paint, sure enough surface rust showed up at about 5 years after nothing but primer not sure that happens at every case, but as mentioned, the Chevelle had been stripped down to bare metal and nothing but primer for 5+ years I've heard similar regarding primer. But this is the OEM applied stuff, as far as I'm aware. Not what I expected to see Link to comment Share on other sites More sharing options...
neohic Posted December 18, 2024 Share Posted December 18, 2024 3 hours ago, A-man930 said: This is going to be a long process... Not doing it right unless you’re doing it twice. Link to comment Share on other sites More sharing options...
A-man930 Posted December 19, 2024 Author Share Posted December 19, 2024 3 hours ago, neohic said: Not doing it right unless you’re doing it twice. Now THAT'S a motto I could live by! I just checked, it was over 10yrs ago that I applied that POR15... I can live with that. Link to comment Share on other sites More sharing options...
M.T.Hands Posted December 19, 2024 Share Posted December 19, 2024 9 hours ago, A-man930 said: I've heard similar regarding primer. But this is the OEM applied stuff, as far as I'm aware. Not what I expected to see I agree it seems odd and an unlikely scenario and not what you'd expect on a factory finish, perplexing Link to comment Share on other sites More sharing options...
A-man930 Posted December 19, 2024 Author Share Posted December 19, 2024 10 hours ago, M.T.Hands said: I agree it seems odd and an unlikely scenario and not what you'd expect on a factory finish, perplexing Makes me even more glad I'm taking it down to bare metal. Link to comment Share on other sites More sharing options...
A-man930 Posted December 30, 2024 Author Share Posted December 30, 2024 It occurred to me that I should make sure there is actually adequate exhaust clearance before I commit to primer on the cab... this blossomed into fabbing the turbo down pipe and exhaust system up to the muffler inlet. Link to comment Share on other sites More sharing options...
A-man930 Posted January 11 Author Share Posted January 11 Finished up the heat shields on the downpipe this evening. Hoping the BBQ paint holds up 🤞 Link to comment Share on other sites More sharing options...
A-man930 Posted January 20 Author Share Posted January 20 Holes were cut. Decisions were made. Glad it'll be mostly out of sight when it's all back together. Link to comment Share on other sites More sharing options...
A-man930 Posted March 20 Author Share Posted March 20 Coming up on a milestone! I've waffled back and forth on how much of the body to tackle at once - settled on spraying the whole cab and "chassis" all at once; inside and out, top and bottom. Before this can happen, I want to have all conceivable cutting and welding completed. All locations for sensors, wiring, mounting brackets, Etc. It's taking forever! Link to comment Share on other sites More sharing options...
ghetdjc320 Posted March 20 Share Posted March 20 15 hours ago, A-man930 said: Coming up on a milestone! I've waffled back and forth on how much of the body to tackle at once - settled on spraying the whole cab and "chassis" all at once; inside and out, top and bottom. Before this can happen, I want to have all conceivable cutting and welding completed. All locations for sensors, wiring, mounting brackets, Etc. It's taking forever! This is the way Link to comment Share on other sites More sharing options...
A-man930 Posted May 17 Author Share Posted May 17 I have to keep reminding myself it's not a GAS pedal... Link to comment Share on other sites More sharing options...
A-man930 Posted June 19 Author Share Posted June 19 Scored a helluvuh deal on some 16" travel 2.0 Kings. 14" would have sufficed, but a deal is a deal! Link to comment Share on other sites More sharing options...
MancheKid86 Posted August 7 Share Posted August 7 On 6/18/2025 at 5:22 PM, A-man930 said: Scored a helluvuh deal on some 16" travel 2.0 Kings. 14" would have sufficed, but a deal is a deal! been looking for a deal on coil overs myself! haven't been able to decide between 14/16, doing lots of reading it online says 14 is more than enough, but in my town everyone has 46"+ tires so only 16's are on the marketplace until then I will be running my old coil springs with a sticker in the wheel well saying " I identify as a coil over" Link to comment Share on other sites More sharing options...
A-man930 Posted August 8 Author Share Posted August 8 9 hours ago, MancheKid86 said: until then I will be running my old coil springs with a sticker in the wheel well saying " I identify as a coil over" Perfect! Link to comment Share on other sites More sharing options...
A-man930 Posted September 8 Author Share Posted September 8 The things our society throws away... Link to comment Share on other sites More sharing options...
ghetdjc320 Posted September 21 Share Posted September 21 On 9/9/2025 at 6:05 AM, A-man930 said: The things our society throws away... Are those some sort of remote adjusters or a reservoir? Link to comment Share on other sites More sharing options...
A-man930 Posted September 22 Author Share Posted September 22 On 9/20/2025 at 7:36 PM, ghetdjc320 said: Are those some sort of remote adjusters or a reservoir? Remote reservoirs. Link to comment Share on other sites More sharing options...
iimafa Posted October 14 Share Posted October 14 Beautiful attention to detail, looks great! Link to comment Share on other sites More sharing options...
