89eliminator Posted March 27, 2009 Author Share Posted March 27, 2009 lol. that has been the first thing to pack ever since then Link to comment Share on other sites More sharing options...
89eliminator Posted March 28, 2009 Author Share Posted March 28, 2009 well i went to JeepCoMJ offroad park today. Link to comment Share on other sites More sharing options...
500 MJ Posted March 30, 2009 Share Posted March 30, 2009 Looks like a fun place to be this time of year! I've still got rock hard snow up here. :doh: Link to comment Share on other sites More sharing options...
89eliminator Posted March 30, 2009 Author Share Posted March 30, 2009 yeah, we just got about 5" last night. most of it melted today though. Link to comment Share on other sites More sharing options...
89eliminator Posted May 3, 2009 Author Share Posted May 3, 2009 got my limiting straps mounted also put new rear brake shoes in and rotated my tires Link to comment Share on other sites More sharing options...
dakal Posted May 3, 2009 Share Posted May 3, 2009 :yes: :yes: Link to comment Share on other sites More sharing options...
comanche13 Posted May 3, 2009 Share Posted May 3, 2009 you should make me long arms :cheers: Link to comment Share on other sites More sharing options...
freakjeep93 Posted May 4, 2009 Share Posted May 4, 2009 thats really nice comanche man and just for tyhe record all comanches look god red Link to comment Share on other sites More sharing options...
89eliminator Posted May 4, 2009 Author Share Posted May 4, 2009 haha, yes they do. Link to comment Share on other sites More sharing options...
89eliminator Posted May 5, 2009 Author Share Posted May 5, 2009 new bumpstop configuration. just adding extensions to the coil bucket did not work. the upper stop passed it up cause of the angle during flex. i split the difference, keeping the lower portion adjustable while adding an aluminum spacer to the upper stop. finally put my pins on for when the swaybar is disco'd limiting straps at ride height. was worried about them contacting the d-shaft or tire. The upper arm prevents it from hitting the shaft while the brake lines prevent it from hitting the tire. Link to comment Share on other sites More sharing options...
1987JEEPMJ Posted May 5, 2009 Share Posted May 5, 2009 Whats that you have for pins for sway bar quick disco's? :idea: well i went to JeepCoMJ offroad park today. Link to comment Share on other sites More sharing options...
89eliminator Posted May 6, 2009 Author Share Posted May 6, 2009 Whats that you have for pins for sway bar quick disco's? :idea: yup. came with the RE Gen2 discos Link to comment Share on other sites More sharing options...
89eliminator Posted June 3, 2009 Author Share Posted June 3, 2009 steering box brace is in. won't have time till saturday to install it. Link to comment Share on other sites More sharing options...
500 MJ Posted June 4, 2009 Share Posted June 4, 2009 Let me know what you think of that. I made my own cause I just didnt think that these ones looked beefy enough... Plus - it's not hard to make a new one if you have problems with this one, the clamp is the main thing I needed to make my own. Hopefully it works fine for you though. Link to comment Share on other sites More sharing options...
89eliminator Posted June 5, 2009 Author Share Posted June 5, 2009 Let me know what you think of that. I made my own cause I just didnt think that these ones looked beefy enough... Plus - it's not hard to make a new one if you have problems with this one, the clamp is the main thing I needed to make my own. Hopefully it works fine for you though. well i attempted to put it on tonight. i think its gonna take a while to get this to fit right :mad: . none of the holes are even close. i might cut off the pass side mounting plate and make a new one. Link to comment Share on other sites More sharing options...
89eliminator Posted June 8, 2009 Author Share Posted June 8, 2009 steering box brace installed. Link to comment Share on other sites More sharing options...
89eliminator Posted July 8, 2009 Author Share Posted July 8, 2009 is it good when you pull an axle shaft and a bunch of steel balls come out too? the carnage Link to comment Share on other sites More sharing options...
freakjeep93 Posted July 9, 2009 Share Posted July 9, 2009 ouch man that aint good :eek: :no: :ack: :shake: Link to comment Share on other sites More sharing options...
89eliminator Posted July 9, 2009 Author Share Posted July 9, 2009 no its not. still trying to figure out what went wrong. sucks cause i just replaced that bearing. maybe it was faulty cause everything was put together correct and it had enough oil in it. Link to comment Share on other sites More sharing options...
MiNi Beast Posted July 9, 2009 Share Posted July 9, 2009 no its not. still trying to figure out what went wrong. sucks cause i just replaced that bearing. maybe it was default cause everything was put together correct and it had enough oil in it. apparently not :shake: So that was the rear? when and where? what the hell details man, details? Link to comment Share on other sites More sharing options...
89eliminator Posted July 9, 2009 Author Share Posted July 9, 2009 no its not. still trying to figure out what went wrong. sucks cause i just replaced that bearing. maybe it was default cause everything was put together correct and it had enough oil in it. apparently not :shake: So that was the rear? when and where? what the hell details man, details? yup, driver side axle shaft. driving home from school doing about 60, heard and felt a pretty awesome vibration. turned down country road and got out to look. diff fluid all over my tire and everything else under the truck for that matter. the fluid was actually flowing out of the drum. only had a 3 mile or so drive home so i kept it under 25 the whole way and then pulled the shaft out to find the carnage. Link to comment Share on other sites More sharing options...
MiNi Beast Posted July 9, 2009 Share Posted July 9, 2009 no its not. still trying to figure out what went wrong. sucks cause i just replaced that bearing. maybe it was default cause everything was put together correct and it had enough oil in it. apparently not :shake: So that was the rear? when and where? what the hell details man, details? yup, driver side axle shaft. driving home from school doing about 60, heard and felt a pretty awesome vibration. turned down country road and got out to look. diff fluid all over my tire and everything else under the truck for that matter. the fluid was actually flowing out of the drum. only had a 3 mile or so drive home so i kept it under 25 the whole way and then pulled the shaft out to find the carnage. Kind like my hubs, didn't go untill just driving around on the road, not beating on it offroad :shake: that's DD carnage right there :rotfl2: Link to comment Share on other sites More sharing options...
oregonman Posted July 10, 2009 Share Posted July 10, 2009 damn that is a sweet jeep. Link to comment Share on other sites More sharing options...
jpdocdave Posted July 11, 2009 Share Posted July 11, 2009 wow wade, i've never seen a rear wheel bearing fail, especially like that. Link to comment Share on other sites More sharing options...
TNT Posted July 11, 2009 Share Posted July 11, 2009 If you have a SYE did you raise the diff fill hole to compensate for the extra rotation of the diff. Rotating the pinion up lowers the fill hole. If thats a D44, I have a 3/8" thick cover with a raised fill hole. :cheers: Link to comment Share on other sites More sharing options...
